I have a Thinkpad X220 with OSX mountan lion working install on separate partition with Chameleon bootloader.
I can't use WiFi because my Intel 6205 wifi card is not supported.
Since I don't have much harddrive space I'd like to run OS X in a virtual machine from windows from the existing physical partition.
vmware workstation allows this very easily but now I get this (see image below) : "Can't find" (just that)
I've tried several -rd:diskXsY combinations but it doesn't help.
So ... Can any of you help me any further?
Thanks so much!
Cheers!
Remko
p.s. If anyone had advise on which wifi card to buy as a replacement: please (I had a crappy chinese ordered through ebay Dell thing that fell apart when I installed it).
Posted
Hi all,
Thanks so much!
Cheers!
Remko
