Welcome to osx86.net
noname
{GUIDE} macOS High Sierra 10.13 BETA
26 posts in this topic
Did you use my tutorial after all or did you use USB method? As far as I know, there is some kind of issue with USB install, it takes ages for install to complete, and often it get interrupted with some error. So I recommend to use my method, installing with Core.pkg to some spare partition or SSD or HDD and using boot.efi from BaseSystem.dmg.
Also can you post a pic where exactly it got stuck?
Thanks!
gils83 likes this
No no, this is not the installation problem, these are just my usb ports that do not work :)
The core installation method is perfect :)
noname likes this
I just installed High Sierra 10.13 Beta on my Lenovo Thinkcentre M58, with ATI HD5450 0x68E11002, but I am having problems getting QE/CI.
With El Capitan and Sierra all I had to do is put in the Device ID in info.plist of the AMDRadeonX3000 kext and it worked. The DeviceID is already present in the AMD5000Controller Kext native. (very strange?)
Also tried fake GPU ID with clover and setting it to 68E0, but it is not working, keeps showing 68E1
I hope anybody can help me.
CS
CS
InjectATI on false or true?
noname likes this
