Always up to date!
Laptop battery kext
- - - - - acer battery laptop
  • Please log in to reply
8 replies to this topic
#1
alex95sv
alex95sv
    Junior Member
  • Members
  • PipPip
  • 14 posts
Hello, I successfully installed my Mountain Lion, but now I have some weird problem, related to my laptop battery. I can still use it on battery, but I can't see little battery that should be there on the menu bar near the clock.
And yes, I tried to check the "Show battery status in menu bar" from the System Preferences, but it doesn't work.
Where can I find a working kext for laptop battery?
My laptop is Acer Aspire 5738G, 4GB DDR3, 2.20 GHz Intel C2D (if needed, I can provide other specs).
Thank you in advance.
#2
alex95sv
alex95sv
    Junior Member
  • Members
  • PipPip
  • 14 posts
*bump*
So, no one installed ML on hackontosh laptop?
A little hard to believe...
#3
guitmz
guitmz
    Junior Member
  • Members
  • Pip
  • 7 posts
installed here... im looking for an working kext
Done! Found one working and its pretty good!
http://www.osx86.net..._need_dsdt.html
Install both files with kext utility or whatever and repair permissions (kext utility does both at same time - installing and permission repairing)
Edited by guitmz, 05 August 2012 - 02:12 AM.
#4
alex95sv
alex95sv
    Junior Member
  • Members
  • PipPip
  • 14 posts
Actually, I solved my problem a few days ago too, just forgot to post and mark the topic as solved :)
I solved it with other Smart battery kext, also working with iStat :)
Thanks for the help though! :)
#5
guitmz
guitmz
    Junior Member
  • Members
  • Pip
  • 7 posts
can you share the kexts you used? :D
#6
alex95sv
alex95sv
    Junior Member
  • Members
  • PipPip
  • 14 posts
No problems, here they are :)
[ATTACH]2337[/ATTACH]
#7
iTEHb
iTEHb
    Junior Member
  • Members
  • Pip
  • 1 posts
kext work on 10.8?
#8
anhnldev
anhnldev
    Junior Member
  • Members
  • PipPip
  • 10 posts
work with 10.8?
#9
panama58
panama58
    Junior Member
  • Members
  • Pip
  • 1 posts
work on my espire 5740
Also tagged with one or more of these keywords: acer, battery, laptop
