Always up to date!
[GUIDE] Clover EFI Bootloader
* * * * * 1 votes bootloader efi linux mac os x windows
  • This topic is locked This topic is locked
3063 replies to this topic
#1
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
This topic still being useful at meaning of troubleshooting issues and usage concept, but for updated
instructions on Configuration Files and DSDT Patches, keep your eyes here > http://clover-wiki.zetam.org/Home
Hi everyone!
I'm here to present you Slice's new EFI Bootloader!
Clover v2
It is open source based on different projects: Chameleon, rEFIt, XNU, VirtualBox. The main is EDK2 latest revision.
Credits and copyrights remain in the sources. http://cloverefiboot.sourceforge.net/
Main features:
- boot into 10.4 - 10.8 OSX, Windows EFI and Linux EFI
- boot into LegacyOS (WindowsXP, Linux, DOS) by their bootsectors
- this is EFI bootloader so it provides RuntimeServices for OS that impossible for Legacy Bootloaders
- mostly Clover do automatic detection of hardware and set all properties by default. But user can change them by config.plist
- With Clover you may restart into other OS from Startup Disk prefPane
- With Clover you boot your OS X's Recovery HD, impossible for others bootloaders
- config autodetect by OEM product name
- UUID written into config.plist will be the same as in OS
- autopatch OemDSDT for working OSX
- SMBIOS will be corrected to standard 2.6
- ACPI will be corrected to standard 4.0. Custom DSDT will be loaded from booted partition or from EFI folder
- MADT table may be corrected to resolve problem with NMI on some hardware
- ACPI tables loading (SSDT-xx, APIC, BOOT, SLIC, SLIT, SRAT, UEFI...)
- correctly set PowerProfile for laptops (notebooks), desktops, workstations
- customizable RestartFix
- sleep/wake fixes
- PCIRootUID value (0,1) for device-injection for those who can't edit DSDT
- Graphics Properties Injector for ATI, NVidia and Intel for wide range of supported cards. Also customizable.
- Custom EDID for non-DDC monitors
- USB fix (LegacyOff, Ownership, Builtin, clock-id) up to USB 3.0
- HDA injector, HDMI fix.
- Ethernet builtin injector
- CPU turbo
- P- and C-states generator
- PLimitDict and UnderVoltage for CPU Speedstep
- patch kernel on the fly for unsupported CPU like Atom and Ivy Bridge
- Patch AppleIntelCPUPowerManagement for native Speedstep (Intel Processor) of ASUS ownwers
- patch kexts inside kernelcache for unsupported hardware
- extra kexts loading
- security mode for FireWire
- default boot after timeout
- customizable GUI: themes support, own icons, fonts, animations.
- there is a possibility to implement national languages and fonts. F1 - multilingual help
- saving boot.log in OS and preboot.log from GUI by typing F2
- save original (OEM) ACPI tables by pressing F4
- test DSDT patching with F5
- save videoBIOS into EFI/misc by pressing F6
- saving screenshots from GUI typing F10
- CD/DVD eject by F12 and refresh menu after CD insertion
If you have questions please provide outputs from DarwinDumper (Trauma tool). Thanks Trauma!
Continued by blackosx and STLVNUB. > DarwinDumper
Links to Active Clover Topics
Downloads
CloverGrower
Installation
About Legacy Boot
How to Use
DSDT and Calculator for Automatic DSDT Fix
SMBIOS
Kexts Injection
Graphics Injection
Themes
Final Thoughts
FAQ
Manually Add Clover Boot UEFI Option
Adding Custom EDID to Adjust Resolution in UEFI Boot or EDID injection by m.gbt
Creating a Bootable OS X Installer with Clover by fau7i (broken)
Installing OS X on a RAID set by magnifico10 (broken)
Messages.app Fix by ElNono_ (broken)
Clover's Wiki (broken)
Kext Info.plist Patch (broken)
Manually Install Clover (broken)
Fix [AGPM controller: unknown platform] on-the-fly by m.gbt
#2
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
Here I'll list the most active Clover topics...
Project OS X > http://www.projectos...?showtopic=2562
InsanelyMac > Clover v.2 - The X Labs - InsanelyMac Forum
AppleLife > Clover | AppleLife
All answers for any question that you may have can be found on any of those links...
Research and Read before ask...
Edited by fau7i, 11 April 2013 - 11:42 PM.
#3
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
I'll place here always the latest Clover revision...
Official Clover EFI download at SourceForge > http://sourceforge.n.../cloverefiboot/
Compilation, Package and ISOs made with CloverGrower, thanks STLVNUB!
Clover v2 rL887 > Clover EFI rL887 - Downloads - OSx86.net
Clover v2 rL855 > Clover EFI rL855 - Downloads - OSx86.net
Clover v2 rL828 > Clover EFI rL828 - Downloads - OSx86.net
Clover v2 rL810 > Clover EFI rL810 - Downloads - OSx86.net
Clover v2 rL801 > Clover EFI rL801 - Downloads - OSx86.net
Earlier revisions can be found here > Clover - Project OS X Forums
Edited by kyndder, 11 December 2012 - 03:18 AM.
#4
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
As Clover is a OpenSource project, everyone who wants
to compile may compile...
To make the things a lot easier, STLVNUB made a script
that makes all the hard work for you, this way you can
have Clover always at the latest revision without the need
to wait till someone publish a new package and also, make
your own changes to the code if needed...
You will need to have Xcode and Command Line Tools in order
to use the script...
Additional tools to compile Clover will be automatically
installed by the script.
New Git Repository > https://github.com/S...UB/CloverGrower
CloverGrower by STLVNUB > How To Make Efi Bootloader - Project OS X Forums
Edited by kyndder, 14 January 2013 - 03:21 PM.
#5
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
Download and run the installer...
Posted Image
Press continue and when you reach the customisation section, change the install location if needed then press "Customize"…
Posted Image
Read carefully the instructions given for each option after you select a entry at the bottom of the window, if you don't understand exactly which option you should choose, you can use the options selected at the image below…
Posted Image
Click "Install", write your password, wait till the installation finishes and reboot...
Posted Image
If you installed Clover using "boot1f32alt", you own the ability to have and use more than one bootloader on the same disk...
boot1f32alt gives to you 2 seconds to press the number of your desired boot file and choose the Bootloader that you want to use...
For example, assuming that you installed 64bit Clover as default option, you can use the 32bit one by pressing "3", or if you rename Chameleon's "boot" file to "boot1", if you press "1" you can use Chameleon as Bootloader...
There's also the possibility to have XPC and Revoboot, for detailed instructions take look here > One Fat32 Usb Stick With Many Hackintosh Bootloaders/managers - Project OS X Forums Thanks to dmazar for this awesome tip!
Edited by kyndder, 27 October 2012 - 07:08 PM.
#6
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
Clover main goal is EFI booting...
If you plan to use Clover, keep in mind that Legacy boot (non EFI boot) may work or not, so,
maybe you can't boot your current Windows or Linux Installations through Clover...
In this case, you can use the "tip" at Installation section and have the ability to use Chameleon
to boot your "Legacy" OS and have all Clover's benefits to boot OS X...
This does not mean that in the future this will not be completely fixed...
For those having issues with Legacy Boot (non UEFI boot) using the default option...
<key>LegacyBoot</key>
<string>PBR</string>
You can try using the option below...
<string>LegacyBiosDefault</string>
Edited by kyndder, 05 November 2012 - 02:05 AM.
#7
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
Boot process will go as the follow:
BIOS boot: BIOS>MBR>PBR>BOOT>CLOVERX64.EFI>OS
UEFI BIOS: UEFI>CLOVERX64.EFI>OS
From GUI you have the ability to make changes to the Defaults Settings and try your own
settings before use as Clover Defaults...
Posted Image
Main Options
Posted Image
DSDT Fix Mask
Posted Image
CPU Tuning
Posted Image
Graphics Injection
Posted Image
Binaries Patching
Posted Image
To use Special Startup Options like, Skip Caches ("WithKexts" option, -f doesn't exist in Clover), Verbose Mode, Single User Mode, 32bit, etc..., press "space" key when your desired boot device is selected...
You make your tests and want to set your changes as defaults, just add the needed information to the "config.plist" located at "/EFI/CLOVER" or "/EFI/CLOVER/OEM/System Product Name" folder like the example below (viewed from Xcode)...
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Here you can find a brief description for each option that you may set at your config.plist. Thanks to beta992 > Clover Instruction @ProjectOSX
Edited by fau7i, 12 May 2013 - 12:25 PM.
Updating Info
#8
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
Clover can patch your DSDT on-the-fly...
With this function, now everyone can have a patched DSDT without the risk of use someone's DSDT
or the need to ask someone to made one for you...
Just select needed patches, apply and enjoy...
Posted Image
There's also a tool made by cVad to calculate the DSDT Fix Mask > BootDiskUtility.exe / Home / cVad MAC
Posted Image
Or if you wish, you can use your own patched DSDT...
<key>ACPI</key>
<key>DsdtName</key>
<string>dsdt.aml</string>
Edited by kyndder, 27 October 2012 - 07:06 PM.
#9
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
Clover automatically detect your Hardware and choose the
best SMBIOS for your system and this should be enough...
But if you want, you may set your desired SMBIOS...
<key>SMBIOS</key>
<key>ProductName</key>
<string>iMac12,2</string>
Or you can set only a specific entry...
<key>SMBIOS</key>
<key>SerialNumber</key>
<string>XXXXXXXXXXX</string>
In both cases above, Clover will automatically fill the no specified entries...
You can also customize all information you want...
Posted Image
#10
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
Copied and pasted here from Slice's post at ErmaC's Topic > InsanelyMac - Clover v2 Instructions
©dmazar
[UPDATE] Rev 1351 : Kext injection has changed again. Check @ Project OS X - Kext Injection
[UPDATE] Rev 1277 - 1350 : Clover directory has been changed as users may notice when using r1284+ installer (officially uploaded at Sourceforge). In addition, WithKexts has been splitted to 2 options; NoKexts and NoCaches. So, you got 3 options when you press space bar;
  • Boot Mac OS X without caches
  • Boot Mac OS X without extra kexts
  • Boot Mac OS X without caches or extra kexts
New directory: \EFI\CLOVER
NoKexts: Any kext in \EFI\CLOVER\kexts\10.x will not be injected.
NoCaches: Skip/ignore kernelcache
When kext injection is working, then any caches should be ignored (kernelcache, Extensions.mkext) and boot.efi should load kernel and kexts separatelly - slower boot with lot of dots on a screen. Also, if any kexts are loaded, then they should be visible in system as they would normally be. For example, FakeSMC would write some line in kernel log and can be seen with;
kextstat | grep -i fake
Plus, boot.log will have something like;
FSInjection: OS=xx.x Injecting kexts from: 'xxxxx' done!
If above is not happening, then this kext injection is not working.
A short info how this kext loading is working. Maybe it will help you to see what went wrong:
  • FSInject.efi is loaded on startup from \EFI\drivers \EFI\CLOVER\drivers - this is file system proxy driver that is just loaded initially. will get activated later if needed.
  • Volume selection screen is shown - you can mark the volume and press space to get boot options and then choose "Boot Mac OS X without caches" (going into details to avoid confusion).
  • This searches for appropriate folder where kexts could be located;
    • -> EFI\OEM\xxx\kexts\xx.y \EFI\CLOVER\OEM\xxx\kexts\xx.y(version speciffic) or
    • -> EFI\OEM\xxx\kexts\Other \EFI\CLOVER\OEM\xxx\kexts\Other or
    • -> EFI\kexts\xx.y \EFI\CLOVER\kexts\xx.y or
    • -> EFI\kexts\Other \EFI\CLOVER\kexts\Other
  • First one found is used, no metter if it is empty or not (possible mistake: if you are booting 10.8 and have kexts\10.8 which is empty and kexts\Other with FakeSMC, then kexts\10.8 will be used and no kexts will be added).
  • If one is found, then FSInject.efi is activated - this replaces existing file system driver with our proxy implementation. this one is able to block OSX caches and inject drivers to /S/L/E.
  • boot.efi is started - it can not load caches (blocked by FSInject), so it loads kernel and kexts from /S/L/E (FSInject will take care to report our extra kexts as being in /S/L/E).
  • Lot of dots should appear on screen during kext loading.
So, this is what is required:
  • FSInject.efi in \EFI\drivers \EFI\CLOVER\drivers.
  • Kexts in appropriate folder.
  • Boot with "Boot Mac OS X without caches" or just write manually boot-args=NoCaches.
Edited by fau7i, 22 April 2013 - 11:42 AM.
Updating info
#11
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
The widely known Chameleon's "GraphicsEnabler" is called "GraphicsInjector" in Clover…
As Clover does with SMBIOS injection, your device is automatically detected and recognised
by the bootloader…
The only thing that you must do is enable "GraphicsInjector" at Clover's Menu Options
and/or add the following entry to your config.plist file…
<key>Graphics</key>
<key>GraphicsInjector</key>
If you need more detailed instructions for your Video Card, this information can be found an ErmaC's topic at InsanelyMac… Thanks ErmaC!!!
There you will find the most detailed information about ATI Cards and EDID Injection…
Detailed GraphicsInjector instructions > Clover v.2 - The X Labs - InsanelyMac Forum
Detailed ATI Connector Patching > Clover v.2 - The X Labs - InsanelyMac Forum
Detailed EDID instructions > Clover v.2 - The X Labs - InsanelyMac Forum
Edited by kyndder, 27 October 2012 - 07:35 PM.
#12
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
Like Chameleon, Clover also have different Themes but with plus more
features like Mouse interaction and Theme Animations...
The installer already have the following Themes to be installed...
Default Theme black_green by blackosx
Posted Image
metal by Slice
Posted Image
The Down by Slice
Posted Image
Buttons by Trauma
Posted Image
hellfire by lllevelll
Posted Image
wooden by iROOTa
Posted Image
aluminium by iROOTa
Posted Image
simple_gray by hijeane
Posted Image
There's also Themes that isn't on the installer...
steampunk by Xmedik
Posted Image
Download steampunk
os_one by kyndder (Updated)
Posted Image
Download os_one v2
os_box by kyndder
Posted Image
I'm currently updating os_box theme, sooner as I can I'll updated the link...
Bluemac by fau7i
Attached File  screenshot_bluemac.jpg   13.88KB   204 downloads
More info at post #215, post #2717, and post #2759.
Download Bluemac [Updated 18th May 13]
MagnificoTheme by magnifico
Attached File  screenshot3jo.jpg   13.6KB   104 downloads
Download > [ATTACH]4084[/ATTACH]
Edited by fau7i, 19 May 2013 - 03:29 AM.
Updating Bluemac theme settings
#13
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
What Clover does???
With few words, for those that have the "old" regular BIOS, he replaces him with his own
(U)EFI BIOS making every OS running from within Clover "believe" that he is running under
UEFI Firmware…
And for those that already have a UEFI Firmware, he helps the Firmware "see" OS X by giving
needed resources to boot OS X that is impossible for a regular PC Firmware…
This plus lots and lots of improvements, for example, you can have a patched DSDT to be used
with OS X and another "clean" and "unmodified" to be used for Windows if booted using Clover's
Firmware like I did before I flash my UEFI BIOS….
You will have a Hack more kind a Mac, for example, you are using OS X and needs switch to
Windows but don't want to edit any configuration file or even select the Windows entry at Clover's
GUI (or have Silent Boot enabled)??? Simple, just go to "System Preferences > Startup Disk", select
the Windows Disk and press reboot, Clover will boot straight to Windows… Impossible for any other
bootloader…
Well, I believe that for now it's enough…
I hope that Slice, dmazar, blackosx, STLVNUB, pene, apianti and all developers involved with Clover
Project may gift us with his visit from time to time to make this thread increasingly better...
#14
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
Here I'll try to list the most common user doubts...
Before anything, check the items below... (Thanks Elclaudio to sort this out!)
> Do not put anything more in /efi/acpi/patched except your DSDT
> You have patched DSDT ? : you just need to put it to /efi/acpi/patched (assuming you have nothing in /efi/oem folder) and set in Clover ACPI/FixDsdtMask=0
> GFX patches in DSDT ? : you do not need GraphicsEnabler in Chameleon : no need for it in Clover also: set Graphics/GraphicsInjector=No
> Audio patches already in DSDT ? : set in Clover PCI/HDAInjection=No
> When you put CsmVideoDxe-64.efi to drivers64UEFI, this driver replaces your original graphics driver and offers more resolutions from your card, but at the cost of additional boot time
> Clover is not selecting highest resolution when CsmVideoDxe-64.efi is loaded because that driver can reveal some resolutions which are not usable on current monitor
> PatchVBios in config.plist : Some nVidia users are having success with this, and some not. nVidia patching is not reliable. But you can try.
>> What FSInject-XX.efi does?
It's a driver responsible for Kext Injection, so, It's installed as Default for UEFI and Regular BIOS users.
>> What OsxFatBinaryDrv-XX.efi does?
It's a driver responsible for add support for FAT Binary data, Mandatory to UEFI users.
>> What HFSPlusXXX.efi does?
It's a driver responsible for add support to HFS Filesystem, Mandatory to UEFI users.
>> What VBoxExt2-XX.efi does?
It's a driver responsible for add support to EXT Filesystem, optional for Linux users.
>> Why Clover takes longer than Chameleon to reach the Bootloader's GUI?
Keep in mind that Clover need some time to Inject his EFI Layer when powering the machine...
Chameleon doesn't do this so, you can reach Chameleon's GUI more faster...
BTW, reaching the bootloader's GUI faster does't mean that your OS X boot is/will be faster...
On Real UEFI System this delay doesn't exists as Clover doesn't need to inject his own...
>> How I boot Ignoring Caches ( -f ) ?
The Chameleon's Boot Flag -f to boot OS X Ignoring System Caches doesn't exist in Clover...
On his place we have the WithKexts option that haves the same functionality of Chameleon's -f...
To use this option, at Clover's GUI press Space Bar on your desired boot entry to have access to
various Boot Options including WithKexts...
If by some reason you want this option as Default, just ad as boot-arg on your config.plist file...
<key>boot-args</key>
<string>npci=0x2000 darkwake=0 WithKexts -v</string>
>> Why OS X boot always freeze without use WhitKexts option?
There's a known bug that may prevent some machine to boot using Kernelcache...
After long research, bcc9 was able to find a fix for this issue > Waiting for root device when kernel cache used; only with some disks +FIX - OSx86 10.8 (Mountain Lion) - InsanelyMac Forum
I don't know why, but apparently you can have this issue even if you never had using Chameleon as
happened to me...
>> How I can use mouse in Clover's GUI?
For UEFI users, just move your mouse... :)
For Regular BIOS users, add UsbMouseDxe-XX.efi
>> How I can change the Theme?
Add the Theme folder to /EFI/BOOT/themes/ and replace the refit.conf file on /EFI/BOOT/
with the one provided with the Theme...
>> How I can change Clover's GUI resolution?
Clover automatically set the highest available resolution for Regular BIOS users...
If you want a lower resolution, add the entry below to your refit.conf file...
screen_resolution WHIDTHxHEIGHT
For UEFI users, unfortunately there's no way to set a higher resolution, we are stuck at
1024x768...
BTW, we don't need to reach Clover's GUI as we don't need his ability to load any other
EFI capable System, so, we just need to use Silent Boot and boot straight OS X, just
like a Real Mac, I reach my Desktop on about 20 seconds or less and I don't have any SSD... :)
To use Silent Boot, set Timeout to 0 on your refit.conf file...
>> How I can prevent Clover to boot Straight to Windows after boot the OS?
Follow Elclaudio's instructions here > http://www.osx86.net...html#post126871 Thanks Elclaudio !
Edited by kyndder, 24 November 2012 - 04:58 AM.
#15
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
And we open!
Please, read before ask.
Asus P8Z77-V LK Firmware 1001 / Core i5-2300 Sandy Bridge / Geekbench
#16
fau7i
fau7i
    OSx86.net Crew
  • Super Moderators
  • 1,794 posts
Hi Kyndder, I've been 2 days testing Clover on my Vostro. Just to figure out how Clover works in comparison with Chameleon. I already use 2 USB flash drives FAT32. Both work after some tweaks in config.plist and placing my custom DSDT and SSDT (not using fixdsdtmask and OEMSSDT). Finally, I can boot into ML and Windows with no issues. Since it's triple boot setup (MBR layout), I just couldn't understand why I have constant reboot loop with Lion. It happens after a split second I press Enter. Retweak the config.plist but no avail.
It's not happening with Chameleon even I use the same DSDT and the bootloader itself. I see Clover automatically detects this laptop as MBP 8,1. That's good but it just can't boot Lion partition :confused:
Z77 Extreme 6 i5-3570K | HD4000 / HD7870XT [ Clover UEFI > Win8 + ML10.8.5 + Mavericks 10.9.1 ]
Dell Vostro 3550 i5-2450M | HD3000 [ Chameleon r2269 > Win7 + Mavericks 10.9.1 ]
#17
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
Hi fau7i!
Please, make the steps below...
Enable boot log by editing your refit.conf file on the /EFI/BOOT/ folder like the example below...
#nolog
Reboot your machine, and if possible, run DarwinDumper.app to send us a full dump of your system > DarwinDumper - New Releases and Updates - InsanelyMac Forum
Sorry for the external link, I'll ask to blackosx if he could place a link for his awesome tool at this thread...
If you can't run the app, place here only the boot.log file that you can find at /EFI/misc/ folder...
#18
fau7i
fau7i
    OSx86.net Crew
  • Super Moderators
  • 1,794 posts
Ok thanks for helping me out...these are the files;
[ATTACH]2925[/ATTACH]
[ATTACH]2926[/ATTACH]
#19
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,587 posts
I can't see anything unusual at your files...
Could you please show your config.plist file...
#20
fau7i
fau7i
    OSx86.net Crew
  • Super Moderators
  • 1,794 posts
Maybe it will helps us, lets look
	<key>ACPI</key>
		<key>DropOemSSDT</key>
		<key>FixDsdtMask</key>
		<string></string>
		<key>GenerateCStates</key>
		<string>No</string>
		<key>GeneratePStates</key>
		<string>No</string>
	<key>SMBIOS</key>
		<key>BiosVendor</key>
		<string>Apple Inc.</string>
		<key>Family</key>
		<string>MacBook Pro</string>
	<key>SystemParameters</key>
		<key>CustomUUID</key>
		<string></string>
		<string>-v</string>
		<key>prev-lang:kbd</key>
		<string>en:0</string>
	<key>Graphics</key>
quite scratched btw
Also tagged with one or more of these keywords: bootloader, efi, linux, mac os x, windows
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
