Always up to date!
Intel High Definition Audio - ALC888b - Azalia
  • Please log in to reply
1 reply to this topic
#1
ChazZeromus
ChazZeromus
    Junior Member
  • Members
  • Pip
  • 2 posts
Hi, I'd like to know what exactly I need to do after a clean installation of iATKOS s3. So the current version of OSX that I'm using is 10.6.3, and I'm about to do a combo update from apple to 10.6.4, and then to 10.6.5.
I haven't installed any updates yet, but I'm updating because of what's said here. After I installed v10.6.5, I'll backup my s/l/extensions folder and delete the AppleHDA kext, then I'll use a kext utility to install the VoodooHDA kext for my ALC888b.
Is there anything I need to do first? I heard after these updates, sleeping/shutdown/restart becomes broken.
#2
evanage
evanage
    Junior Member
  • Members
  • Pip
  • 4 posts
Did you use sleeping/shutdown/restart kexts or similar?Or use dsdt fixed?
