Always up to date!
X-Fi Platinum (PCI) Kext /Workaround
  • Please log in to reply
6 replies to this topic
#1
ALEXROWE
ALEXROWE
    Junior Member
  • Members
  • Pip
  • 9 posts
Does anyone know if its possible to get audio from the Creative X-FI platinum (PCI) on a SL 10.6.6 Installation?
Thank you for your time.
#2
keteflips
keteflips
    Junior Member
  • Members
  • Pip
  • 3 posts
Did you find any solution? I'm looking for a long some kext for this sound card and find nothing.
#3
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,598 posts
Take a look here > Creative Open-Sources Their X-Fi Driver - InsanelyMac Forum
Asus P8Z77-V LK Firmware 1001 / Core i5-2300 Sandy Bridge / Geekbench
#4
keteflips
keteflips
    Junior Member
  • Members
  • Pip
  • 3 posts
Thanks, this confirms my suspicions, the X-FI PCI are abandoned.
#5
cesarmari
cesarmari
    Junior Member
  • Members
  • Pip
  • 4 posts
I installed another distro, the iATKOS L2 with Lion 10.7.2, and my Creative X-Fi works. This distro installed so easy, it boots so quick, everything works so smooth... You should try it.
Hope this helps.
#6
keteflips
keteflips
    Junior Member
  • Members
  • Pip
  • 3 posts
Hope this helps.
¿Your Creative X-Fi it's PCI?
Thanks.
#7
cesarmari
cesarmari
    Junior Member
  • Members
  • Pip
  • 4 posts
Thanks.
Yeah it is.
