Always up to date!
Intel 82567LM-3 Gigabit Network Connection at HP dc7900
  • Please log in to reply
19 replies to this topic
#1
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
Hello Everyone,
I Need Help With My Network Card at HP DC7900 Minitower
i've iAtoks 10.5.5
the problem is
wen i go to Network To Put the IP Address
It says : Cable Unplugged
thanks for help ~ :)
#2
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
HDD : 160 GB For The MAC OS Only
RAM 4 GB
Graphic card : ATI X1300 RADEON
Sound Card Bulit in
#3
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
Hello Everyone,
i've iAtoks 10.5.5
the problem is
Take a look at this thread and see if helps > InsanelyMac Forum > IntelE1000e kext (82566MM, 82577LM, etc)
Asus P8Z77-V LK Firmware 1001 / Core i5-2300 Sandy Bridge / Geekbench
#4
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
the same problem
Status : Cable Unplugged
The Cable For Ethernet Adaptor (en0) is not plugged in
#5
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
the same problem
Try this flag at cahmeleon`s boot device selection > EthernetBuiltIn=Yes
Exactly was i write (case sensitive)...
#6
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
I Tried but i don't know how ... i've google it but i didn't find how to change it :)
help me ..
thank u
#7
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
help me ..
thank u
Follow this thread > http://www.kexts.com...der-basics.html
And add this key to your com.apple.Boot.plist...
<key>EthernetBuiltIn</key>
#8
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
it doesn't work :(
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
	<key>Kernel</key>
	<string>mach_kernel</string>
	<key>Kernel Flags</key>
	<string></string>
	<key>UHCIreset</key>
	<string>y</string>
	<key>GUI</key>
	<string>n</string>
	<key>GraphicsEnabler</key>
	<key>ForceWake</key>
	<string>y</string>
	<key>ForceHPET</key>
	<string>y</string>
	<key>EHCIacquire</key>
	<string>y</string>
	<key>Boot Graphics</key>
        <key>Quiet Boot</key>
        <string>No</string>
        <key>Timeout</key>
        <string>5</string>
#9
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
it doesn't work :(
Download this app, run, take a picture or Screen Shot, place at imageshack or tinypic and paste the link here > System Info.app.zip
#10
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
it's need java .. i can't Update it
The Version on the internet its for 10.5.8 or Greater
and I am Using 10.5.5
I am trying to install iPC 10.5.6 Mac OS X
Edited by pirlo911, 21 June 2011 - 10:21 PM.
#11
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
pirlo911,
I just made a research over the net about your HP DC7900, and seems that no one get
this controller working...
Take a look here and see if you find something that help you > Main Page - OSx86
Or buy another NetworkCard for you...
#12
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
i've put
Compaq NC3121 Network Card
#13
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
i've put
Try this > AppleIntel8255x.kext.zip
Install, repair permissions and rebuild caches using Kext Wizard > Kext Wizard 3.7.3 - Downloads - Kexts.com
#14
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
You Connot Use This Version Of The Application Kext Wizard With this version of mac OS X.
i've use 3.7.3
and 3.6
i've got the same problem :S
#15
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
i've use 3.7.3
and 3.6
Sorry, I forgot it !!!! :o
Install using Kext Helper > http://www.kexts.com..._helper_b7.html
Then run Kext Utility > http://www.kexts.com...ts_utility.html
#16
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
i've got problem :S
You Need To Restart Your Computer. Hold Down The Power Button ...... etc
#17
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
i've got problem :S
At chameleon boot device selection, move the selection to your OS X disk and type "-f -v" without quotes, note
that the text you type is shown on the bottom left corner, then press enter, when the system stop loading, take a picture
of the screen, host on tinypic or imageshack and paste the link here...
#18
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
ok I Will Do it right now :)
#19
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
I Will Re-Install The OS :)
No need reinstall, se my post above...
#20
pirlo911
pirlo911
    Junior Member
  • Members
  • PipPip
  • 11 posts
it's done .. and Its enter the OS and it didn't stop loading
Now I am On OS & got the same problem
I Am Downloading A Newer Version ...
I WIll Try it
Edited by pirlo911, 22 June 2011 - 03:18 AM.
