Always up to date!
need a driver for BROADCOM 4312 (or dell 1395) for lion
  • Please log in to reply
15 replies to this topic
#1
kkffiirr
kkffiirr
    Junior Member
  • Members
  • Pip
  • 6 posts
the snow leopard's driver not working for me
#2
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
You already tried this > IOPCIFamily FOR BROADCOM WIRELESS 10.6.6 - Downloads - Kexts.com
If yes, try adding you DeviceID on the "info.plist" file inside of the kext...
You can use this app to know your DeviceID > System Info - Downloads - Kexts.com
And take a look at this thread to add your DeviceID > http://www.kexts.com....html#post75196 (Translate with Google)
Asus P8Z77-V LK Firmware 1001 / Core i5-2300 Sandy Bridge / Geekbench
#3
kkffiirr
kkffiirr
    Junior Member
  • Members
  • Pip
  • 6 posts
thanks,
i tried to change info.plist
i think that the right lines are:
<key>IOPCIMatch</key>
<string>0x00261011</string>
from the program i got:
vendor id: 14e4
and for device id i got 4315
so what should be the string after the change?
thanks
Edited by kkffiirr, 24 July 2011 - 09:26 PM.
#4
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
thanks,
vendor id: 14e4
thanks
Leave a clean copy of the kext on a sefe place...
Open the "info.plist" file with TextEdit.app...
Change the key that you found...
For the key below...
<key>IOPCIPrimaryMatch</key>
<string>0x431514e4</string>
Save the file and see if TextEdit don't change the extension of the file to .txt ...
Open a terminal window, type the commands below and drop the modified kext into the terminal window...
chown -R 0:0 [COLOR="#FF0000"](DROP THE KEXT HERE)[/COLOR]
chmod -R 755 [COLOR="#FF0000"](DROP THE KEXT HERE)[/COLOR]
Install the kext on /System/Library/Extensions and run the Maintenance rotines using Kext Wizard > Kext Wizard 3.7.3 - Downloads - Kexts.com
Reboot and boot again in Verbose Mode ( -v )...
#5
willzz32
willzz32
    Member
  • Members
  • PipPip
  • 51 posts
Try the Broadcom kext i have uploaded. Works for my bcm 4312 10.6.7, 32 bit.
Not tested 64bit or in lion but worth a shot.
Install E/E
#6
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,595 posts
Install E/E
Make a little easy for kkffiirr...
Place the link for him > http://www.kexts.com...oadcom_fix.html
#7
willzz32
willzz32
    Member
  • Members
  • PipPip
  • 51 posts
How easy have i gotta make it. Maybe a big flashing neon sign.
#8
kkffiirr
kkffiirr
    Junior Member
  • Members
  • Pip
  • 6 posts
thanks you all. going to check it later
#9
Darkcode31337
Darkcode31337
    Junior Member
  • Members
  • Pip
  • 8 posts
btw do i have to use SL IO80211.kext/IOPciFamily.kext/. mine not working after following all the instructions above!!
#10
kkffiirr
kkffiirr
    Junior Member
  • Members
  • Pip
  • 6 posts
well, i modified the kext as instructed, installed, and i got kernel panic/
#11
Darkcode31337
Darkcode31337
    Junior Member
  • Members
  • Pip
  • 8 posts
i use Airportbrcm43xx.kext 4.21.91 works fine.. but when im using r755 boot file it wont appears instead r947
#12
kkffiirr
kkffiirr
    Junior Member
  • Members
  • Pip
  • 6 posts
is it fully working on lion? do you have bcm 4312?
can you please supply a link and instructions?
#13
Kian1991
Kian1991
    Junior Member
  • Members
  • Pip
  • 3 posts
damn i need it to u had success in time kkffiirr???
#14
kkffiirr
kkffiirr
    Junior Member
  • Members
  • Pip
  • 6 posts
i don't have time to try, maybe next week.... too busy....
#15
platinum95
platinum95
    Junior Member
  • Members
  • Pip
  • 1 posts
Anyone get this working?
My device id is 4320, but I'm not really sure what to do with it
#16
raizdepi
raizdepi
    Junior Member
  • Members
  • Pip
  • 3 posts
kkffiirr,
I had the same problem on Lion 10.7.3 32bits and i fixed by removing the original kexts (sudo rm -rf /System/Library/Extensions/IO80211Family.kext /System/Library/Extensions/IONetworkingFamily.kext) and installing the kexts of this topic 'Lion 10.7.1 installed on intel dual core cpu.. BCM 4312 Now working.. - InsanelyMac Forum' with Kext Wizard. And this new kexts are for 32bits and 64 bits.
Using the SystemInfo of this site Kexts (System Info - Downloads - OSx86.net) or lspci -nn i get this info.
SystemInfo:
14e4 Broadcom Corporation 4315 BCM4312 802.11b/g LP-PHY Network controler Network controler
lspci:
0b:00.0 Network controller [0280]: Broadcom Corporation BCM4312 802.11b/g LP-PHY [14e4:4315] (rev 01)
Check if your device id is present in one of the Info.plist that are in the IO80211Family.kext of that topic. I've found mine in here:
IO80211Family.kext/Contents/PlugIns/AppleAirPortBrcm4311.kext/Contents/Info.plist: <string>pci14e4,4315</string>
