Always up to date!
Problemas con la Instalacion de lion
  • Please log in to reply
25 replies to this topic
#1
penril28
penril28
    Member
  • Members
  • PipPip
  • 51 posts
Me descargo lion de App store y lo intento instalar desde un USB pero cuando arranco el ordenador y me aparece la manzanita me empieza a cargar y no arranca el instalador
#2
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,585 posts
Take a look here > http://www.osx86.net...-installer.html
Asus P8Z77-V LK Firmware 1001 / Core i5-2300 Sandy Bridge / Geekbench
#3
penril28
penril28
    Member
  • Members
  • PipPip
  • 51 posts
instale lion siguiendo la guia y me aparece la manzanita y empieza a cargar y ahi se queda.saque una foto pero no se como ponerla aqui pq no me la reconoce el formato de la imagen que es jpg.
#4
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,585 posts
Place on ImageShack or TinyPic and put the link here...
#5
kchetz
kchetz
    Junior Member
  • Members
  • Pip
  • 4 posts
can someone help me i install iatkos l1 all succesful but after the first boot u know it says plug in keyboard why doesnt detect my laptop keyboard..
#6
penril28
penril28
    Member
  • Members
  • PipPip
  • 51 posts
Creating ram disk for /Volumes
Initialized /dev/rdisk1 as a 512Kb HFS Plus Voume
Creating ram disk for /Var/Tmp
Initialized /dev/rdisk2 as a 512Kb HFS Plus Voume
Creating ram disk for /Var/run
Initialized /dev/rdisk3 as a 512Kb HFS Plus Voume
Creating ram disk for /Systam/installation
Initialized /dev/rdisk4 as a 512Kb HFS Plus Voume
Creating ram disk for /var/db
Initialized /dev/rdisk5 as a 512Kb HFS Plus Voume
Creating ram disk for /var/folders
Initialized /dev/rdisk6 as a 6 Mb HFS Plus Voume
Creating ram disk for /var/root/library
Initialized /dev/rdisk7 as a 2 Mb HFS Plus Voume
Creating ram disk for /library/ColorSync/profiles/Display
Initialized /dev/rdisk8 as a 1024 kb HFS Plus Voume
Creating ram disk for /library/preferences
Initialized /dev/rdisk9 as a 512 kb HFS Plus Voume
Creating ram disk for /library/preferences/systemconfiguration
Initialized /dev/rdisk10 as a 512 kb HFS Plus Voume
Creating ram disk for /library/Keychains
Initialized /dev/rdisk11 as a 1024 kb HFS Plus Voume
Using 64-bit Bootcache playlist
bootcache:Unable to open/var/db/bootcache.playlist:2 no such file or directory
Nstat_lookup_entry falled:2
Applesmbuspci: :Start failed to get acpi path for provider
Previous shutdown cause:0
facksmc:key not found mstf.longth -1
acpi_SMC_platformplugin: :start -waitforservice(resourcematching(appleintelcpupowermanagent)time out
dsmos has arrived
Edited by penril28, 17 November 2011 - 01:04 AM.
#7
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,585 posts
dsmos has arrived
Delete all video kexts from the installer (AppleIntelGMA*, AppleIntelHDGraphics*, ATI*, GeForce*, NVDA*) and use this flag`s to start the installation > -f -v
#8
penril28
penril28
    Member
  • Members
  • PipPip
  • 51 posts
perfecto muchas gracias
como puedo instalar mi tarjeta grafica ati radeon 5570 hd
#9
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,585 posts
Try this > InsanelyMac Forum > ATI Radeon 5400 or 5000 series on Lion Full QE CI
#10
penril28
penril28
    Member
  • Members
  • PipPip
  • 51 posts
despues de actualizar a lion 10.7.2 no me permite entrar en icloud y en mac store.y estoy trabajando con el y de pronto se me queda en la pantalla en gris y se me cierra todo lo que tenia abierto
#11
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,585 posts
Update your Chameleon to the release 1684 and reboot...
Also check with Chameleon Wizard if you have the option "EthernetBuiltIn" enabled...
#12
penril28
penril28
    Member
  • Members
  • PipPip
  • 51 posts
Inastale el chameleon active ethernetbuiltin.Pero cuando entro en mac store me dice No se pudo verificar tu ordenador o dispositivo. Ponte en contacto con Soporte técnico para recibir ayuda.
#13
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,585 posts
Take a look at this thread > http://www.osx86.net...t-verified.html
There`s many different ways to fix this error...
#14
penril28
penril28
    Member
  • Members
  • PipPip
  • 51 posts
muchas gracias ahora si puedo entrar en app store.
tengo instalado voodooHDA.kext y no tengo sonido,applehd.kext no lo tengo instalado
#15
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,585 posts
Try this, if you need help just ask > olarila.com • View topic - VoodooHDA - problemas comuns
#16
penril28
penril28
    Member
  • Members
  • PipPip
  • 51 posts
perfecto.una duda cuando instalo adobe flash no puedo ver los videos de youtube y cuando entro a cualquier pagina de internet me dice que no lo tengo instalado
#17
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,585 posts
You are using Safari or Firefox???
Search at the adobe site for the Flash Plugin Uninstaller and after you uninstall, install again...
#18
penril28
penril28
    Member
  • Members
  • PipPip
  • 51 posts
firefox porque safari se me bloquea cada vez que intento entrar
#19
kyndder
kyndder
    OSx86.net Crew
  • Supervisors
  • 9,585 posts
OK...
Try to uninstall like i told above...
#20
penril28
penril28
    Member
  • Members
  • PipPip
  • 51 posts
lo desistale y lo volvi a instalar y sigue igual no me deja ver videos en youtube
