Always up to date!
Request - Graphics Power Management for GeForce 8400GS 512MB DDR3 64-bit
  • Please log in to reply
2 replies to this topic
#1
asyifa13
asyifa13
    Junior Member
  • Members
  • PipPip
  • 12 posts
Please, somebody help me...!
I have ZOTAC nVIDIA GeForce 8400GS @ 512 MB DDR3 64-bit PCI-e VGA.
Using Mac OS X Snow Leopard 10.6.3 - Lion 10.7.3 on my Lenovo L-IG41C1 Mobo with Intel 82801G Southbridge ICH7 the Q/E & C/I work perfectly by using modified NVDANV50Hal.kext.., but my USB Mouse "jittering, leak, I couldn't move it on and then my System freeze"...!? If I'm using the G41 OnBoard VGA (x4500); my System work fine with no Q/E & C/I.
So, I assume that Graphics Power Management for my PCI-e caused the problem.
Please, somebody generate & build this one for my 8400GS PCI-e VGA...
Thanks & regards.
#2
angkung
angkung
    Member
  • Members
  • PipPip
  • 35 posts
Try use EFI and put in device propertise at Boot.plist you can try mine:
<key>Kernel Flags</key>
<string>npci=0x2000 USBBusFix=yes GraphicsEnabler=yes EthernetBuiltIn=yes</string>
<key>device-properties</key>
<string>6c0200000100000001000000600200000d00000002 010c00d041030a000000000101060000010101060000007fff 04001e00000072006f006d002d007200650076006900730069 006f006e0000002e0000006e5669646961204765466f726365 2038343030204753204f70656e474c20456e67696e65205b45 46495d22000000400030002c00640065007600690063006500 5f00740079007000650000000b000000646973706c61791000 00004e00560043004100500000001800000004000000000003 000c00000000000007000000000e0000006e0061006d006500 00000b000000646973706c617914000000400030002c006e00 61006d0065000000120000004e5644412c446973706c61792d 41100000006d006f00640065006c0000001a0000006e566964 6961204765466f72636520383430302047530e0000004e0056 0050004d000000200000000100000000000000000000000000 000000000000000000000000000014000000400031002c006e 0061006d0065000000120000004e5644412c446973706c6179 2d4220000000400031002c0063006f006d0070006100740069 0062006c00650000000e0000004e5644412c4e564d61632200 00005600520041004d002c0074006f00740061006c00730069 007a0065000000080000000000002020000000400030002c00 63006f006d00700061007400690062006c00650000000e0000 004e5644412c4e564d616322000000400031002c0064006500 76006900630065005f00740079007000650000000b00000064 6973706c61791c0000006400650076006900630065005f0074 0079007000650000000f0000004e5644412c506172656e74</string>
ASUS G53SX
Core i7 QL2670Q 2.2 GHZ
8MB DDR3
NVIDIA GTX560M 2048MB DDR5
Lion 10.7.3
Windows 7 Premium ASUS original
FOXCONN G41MD-V
Core2 Quad Q8300
NVIDIA GS8400 512MB DDR3
Lion 10.7.1
Hazard 10.6.8
Windows7 Ultimate
#3
asyifa13
asyifa13
    Junior Member
  • Members
  • PipPip
  • 12 posts
BTW, with same VGA but other CPU Chipset, it run perfectly with no problem (on my nForce 630i for example).
Some problems occur on my Lenovo G41 Mobo. I've using a lot of methods from many forums to fix this problem; modify xxx.kext, EFI String, Natit, but nothing work.
But, someone on another forum say that:
"...if you're experiencing slow performance with any nVidia card (namely the Quadro and Fermi platforms) just disable/remove the AppleGraphicsPowerManagement kext in /S/L/E/ and you'll see that you'll write to disk less (??? I have no idea why) and you'll also have a bunch more free RAM."
What do you think about this, should I remove my AGPM to the trash...!? Thanks and regard...
