easynote
Intel High Definition Audio not working
Hey folks out there,
I've got my hackintosh working on my Packard Bell EasyNote LM85 using iAtkos L1. Wifi works fine, only audio is not working. I've tried several VoodooHDA's, but every time I'm getting a kernel panic on boot (yes, I have deleted AppleHDA.kext). Does anyone has a solution for it?
5 Series/3400 Series Chipset High Definition Audio
Vendor ID 8086
Device ID 3b56
Mac OS X 10.7.4
Thanks in advance :)
_____________
Intel Pentium P6100 Dual-Core (2,0GHz)
4GB DDR3 Memory
500GB HDD
Check here for other solution:
olarila.com ? View topic - VoodooHDA - common problems
Problem: kernel panic.
Solution 1: remove AppleHDA and restart the system before installing VoodooHDA.
Solution 2: edit Info.plist, replace the key IOPCIClassMatch by IOPCIPrimaryMatch and put the PCI ID of your audio card in string.
Before
Code:
<key>IOPCIClassMatch</key>
<string>0x04030000&0xffff0000</string>
After
Code:
<key>IOPCIPrimaryMatch</key>
<string>0x3b568086</string>
0xDeviceIDVendorID
How to find device and vendor ID
viewtopic.php?f=18&t=63
Use this app to find out your device & vendor IDs
http://www.osx86.net/view/1479-system_info.html
To edit a kext, copy/paste it to Desktop, right click it, choose Show Package Contents, and inside you'll find Info.plist.
After editing, put it back to S/L/E or Extra, repair permissions, rebuild mkext/cache and you're done.
