HackinDoge
Gigabyte GA-Z77-D3H (Rev 1.0) Hackintosh Build
Hey everyone,
Here's my current Intel Hackintosh build! It is as follows (updated periodically, not original condition):
macOS: High Sierra 10.13
CPU: Intel Core i7-3770K @ 4.5GHz
CPU Cooler: Arctic Liquid Freezer 120
Motherboard: In title! :)
RAM: 2 x G.Skill RipJaws DDR3-2400 RAM
Graphics: Gigabyte GeForce GTX 1080 G1 GAMING 8GB GDDR5X
Storage: Samsung 840 120GB SSD (OS X), Samsung 850 EVO 120GB (Windows), Seagate ST2000DM006 (Games), Seagate ST31500341AS (Storage)
PSU: Seasonic SS-620GB 620W
Wifi: TP-Link Archer T8E
Case, Misc: Thermaltake Versa C22 RGB Snow Edition, Gamdias GKC1002 Hermes Mechanical Keyboard Combo, 2 x Logisys 12" 18 LED Sunlight Stick Red
Here's how I installed:
  • Perform a vanilla installation.
  • Install the following kexts to EFI/CLOVER/kexts/Other:
    • AppleALC
    • AtherosL1cEthernet
    • FakeSMC
    • Lilu
    • NvidiaGraphicsFixup
  • Install the NVIDIA Web Drivers.
  • Generate an SSDT with ssdtPRGen.sh, then copy the patched SSDT to EFI/CLOVER/ACPI/patched.
That's pretty much it, folks! After these steps, users can go about their usual customizing.  Here's a generic overlook of my Clover config.plist, very straightforward:
Spoiler
	<key>ACPI</key>
		<key>DSDT</key>
			<key>DropOEM_DSM</key>
				<key>HDA</key>
				<true/>
			<key>Fixes</key>
				<key>DeleteUnused_400000</key>
				<true/>
				<key>FixRegions_10000000</key>
				<true/>
				<key>NewWay_80000000</key>
				<true/>
		<key>SSDT</key>
			<key>DropOem</key>
			<true/>
			<key>Generate</key>
			<false/>
	<key>Boot</key>
		<key>DefaultVolume</key>
		<string>LastBootedVolume</string>
		<key>Timeout</key>
		<integer>3</integer>
	<key>Devices</key>
		<key>Audio</key>
			<key>Inject</key>
			<string>5</string>
	<key>KernelAndKextPatches</key>
		<key>KextsToPatch</key>
		<array>
				<key>Comment</key>
				<string>Fix yellow icons</string>
				<key>Find</key>
				<data>
				RXh0ZXJuYWw=
				</data>
				<key>Name</key>
				<string>AppleAHCIPort</string>
				<key>Replace</key>
				<data>
				SW50ZXJuYWw=
				</data>
				<key>Comment</key>
				<string>TRIM Enabler</string>
				<key>Find</key>
				<data>
				AEFQUExFIFNTRAA=
				</data>
				<key>Name</key>
				<string>IOAHCIBlockStorage</string>
				<key>Replace</key>
				<data>
				AAAAAAAAAAAAAAA=
				</data>
		</array>
	<key>RtVariables</key>
		<key>BooterConfig</key>
		<string>0x28</string>
		<key>CsrActiveConfig</key>
		<string>0x0</string>
	<key>SystemParameters</key>
		<key>InjectKexts</key>
		<true/>
Geekbench - i5-3470
Cinebench - i5-3470
Geekbench - i7-3770K @ 4.5GHz
Cinebench - i7-3770K @ 4.5GHz, GTX 1080
Pics:
Spoiler
The Computer
I was wondering if your sleep/wake works fine with this board? I have the same (v1.0) board and F18 BIOS. I used your Nithy Audio patched DSDT and when I sleep the fans still run. I also can't wake with my power button or keyboard (although I have a Microsoft wireless keyboard and I think the sleep cuts the USB dongle so I'm not entirely surprised by this).
It's not a huge deal because I rarely sleep my computer at all but.. I'd kind of like it to be just right. Fussy, I know.
It's been awhile since I've put this computer to sleep, and since then, I've installed a new graphics card and updated to 10.8.3.
I'll try later today, then update this post on my sleep.
Update: It just shutdown, then started back up saying "My computer shut down because of a problem." I really don't care, anyways. :P
Update 2:?Sleep works. ?It's working flawlessly in Mavericks, but Yosemite doesn't seem to want to sleep when I manually tell it to. ?So:
  • Mavericks: Full sleep
  • Yosemite: As far as I've tested, automatic sleep only.
Edited by Antien
I had a the same motherboard, but once after my 1st installation , i would have kernel panic after using the multi beast.
Please advise how should i select for the MB{censored}. Do you manage to get wifi working as well, i was using TP Link TL-951N Wireless Wifi Adapter earlier when on Lion
Please advise how should i select for the multibeast. Do you manage to get wifi working as well, i was using TP Link TL-951N Wireless Wifi Adapter earlier when on Lion
Sorry, Idnas2, I don't use Multibeast. As you can see, with the minimal steps I took to get it running, there was no need for a post-installation tool.
I used (and am currently using) an X86 Wifi adapter I put together using this guide. It worked OOB since Snow Leopard, so I didn't need to make any modifications there.
Hi!!!
Please, explain how to install Chameleon to EFI partition with bs=4096 (for hard drive with 4k sectoring).
My WD drive with 4k sectoring. After installation Chameleon:
boot0: GPTboot0: testingboot0: testingboot0: error
HELP!!!
