Rene
[Guide] HD5450 1GB (0x68f9 and 0x68e5) in 10.8.3
For using this card with?Clover:?http://www.hackintoshosx.com/topic/23421-clover-fake-id-hd5450-yosemite/
ASUS - EAH5450 SILENT/DI/1GD3(LP)
How to activate your HD5450 in OSX 10.8.3
Copy /System/Library/Extensions/ATI5000Controller.kext to your Desktop.
ATI5000Controller.kext > Show Package Contents > Info.plist
find <key>IOPCIMatch</key>
and add
<string>0x68F91002 0x68981002 0x68991002 0x68E01002 0x68E11002 0x68D81002 0x68C01002 0x68C11002 0x68D91002 0x68B81002 0x68B01002 0x68B11002 0x68A01002 0x68A11002 </string>
Copy /System/Library/Extensions/AMDRadeonAccelerator.kext to your Desktop
The 5450 codename is Cedar: Radeon HD 5000 Series - Wikipedia, the free encyclopedia
AMDRadeonAccelerator.kext > Show Package Contents > Info.plist
find <key>AMDCedarGraphicsAccelerator</key>
and then look for the first <key>IOPCIMatch</key>
add
<string>0x68F91002 0x68E01002</string>
Save exit and install with Kext Wizard?in /System/Library/Extensions.
And select Backup kexts just to be save.
Graphics Enabler=Yes
Ati Config=Eulemur
Chameleon v2.1 svn r1820
In terminal type:
kextstat | grep AMD
These kexts must load:
com.apple.kext.AMDSupport (8.1.0) <60 10 9 7 5 4 3 1>
com.apple.kext.AMD5000Controller (8.1.0) <61 60 10 9 5 4 3 1>
com.apple.AMDRadeonAccelerator (1.0.6) <64 63 60 10 7 5 4 3 1>
com.apple.kext.AMDFramebuffer (8.1.0) <61 60 10 9 7 5 4 3 1>
Before
Type: GPUBus: PCIePCIe Lane Width: x16VRAM (Total): 3 MBVendor: ATI (0x1002)Device ID: 0x68f9Revision ID: 0x0000Kernel Extension Info: No Kext LoadedDisplays:[B]Display:[/B]Resolution: 1024 x 768Pixel Depth: 32-Bit ColorMain Display: YesMirror: OffOnline: Yes
After
[B]ATI Radeon HD 5000:[/B]Chipset Model:ATI Radeon HD 5000Type: GPUBus: PCIePCIe Lane Width: x16VRAM (Total): 1024 MBVendor: ATI (0x1002)Device ID: 0x68f9Revision ID: 0x0000Displays:[B]Cinema HD Display:[/B]Display Type: LCDResolution: 1920 x 1200Pixel Depth: 32-Bit ColorMain Display: YesMirror: OffOnline: YesRotation: Supported
Here are the kexts for Mountain Lion 10.8.3: http://www.osx86.net/files/file/373-asus-hd5450-1083/
For Mountain Lion 10.8.5:?http://www.osx86.net/files/file/3546-asus-hd5470-ml1085/
Credits to arthur-pt olarila.com ? View topic - ATI Graphics
[Edit1]
Added Device ID: 0x68e5 > 0x68E51002
ASUS HD5450 10.8.3_0x68E51002.zip
Mountain Lion 10.8.5 with Device ID :?0x68f9 and?0x68E5:?http://cl.ly/SUKR
For Mavericks follow this link: http://www.hackintoshosx.com/topic/18235-guide-hd5450-1gb-0x68f9-on-mavericks-109/
Watch the video from preet noor for Device ID 0x68f9:
Thanks preet noor
That will not help. What is your Device ID?
What are you getting from terminal with:
kextstat | grep AMD
Did you put it in the right place because there are more than one <key>IOPCIMatch</key> in AMDRadeonAccelerator.kext
add
Everything is working fine now.. After adding my gpu ID to the ATI5000controller and AMDradeonaccelerator, I fixed my permission and rebooted.. At first was almost working, cause I had some random freezing.. I fixed my permissions, rebooted again and everything is working fine..
