Site Under Maintenence - Downloads Not available Read more... ×
Steptov2lol
Fails to enumerate and hangs at 18 minutes
im installing iatkos s3 v2 and it hangs at 18 minutes installing i will have the log here asa i get into it, im on a dell inspiron 1545 with a core 2 duo at 2.20 gz 3 gb of ram bios set to ahci by default i use -v and nothing else to boot because all goes well up to that point also im running a 500 gb wd hard drive with a 100gb partition formatted with mac osx journal extended
LOG
Mar 24 05:24:11 localhost Unknown[77]: Launching the Language Chooser for an OS Install
Mar 24 05:27:39 localhost LCA[78]: Folder Manager is being asked to create a folder (cach) while running as uid 0
Mar 24 05:28:45 localhost LCA[78]: Launching the Installer using language code "English"
Mar 24 05:29:17 localhost OSInstaller[138]: Mac OS X Installer application started
Mar 24 05:29:17 localhost OSInstaller[138]: 1 display(s) found.
Mar 24 05:29:17 localhost OSInstaller[138]: Display[1] is NOT using OpenGL acceleration.
Mar 24 05:29:17 localhost OSInstaller[138]: @(#)PROGRAM:Install PROJECT:Install-572
Mar 24 05:29:17 localhost OSInstaller[138]: @(#)PROGRAM:Mac OS X Installer PROJECT:OSInstaller-255
Mar 24 05:29:17 localhost OSInstaller[138]: Hardware: MacBookPro4,1 @ 2.16 GHz (x 2), 3072 MB RAM
Mar 24 05:29:17 localhost OSInstaller[138]: Running OS Build: Mac OS X 10.6 (10A432)
Mar 24 05:29:17 localhost OSInstaller[138]: Env: DYLD_NO_FIX_PREBINDING=1
Mar 24 05:29:17 localhost OSInstaller[138]: Env: PATH=/usr/bin:/bin:/usr/sbin:/sbin
Mar 24 05:29:17 localhost OSInstaller[138]: Env: PWD=/
Mar 24 05:29:17 localhost OSInstaller[138]: Env: SHLVL=1
Mar 24 05:29:17 localhost OSInstaller[138]: Env: OS_INSTALL=1
Mar 24 05:29:17 localhost OSInstaller[138]: Env: _=/System/Installation/CDIS/LCA.app/Contents/MacOS/LCA
Mar 24 05:29:58 localhost OSInstaller[138]: Using install media product at /System/Installation/Packages
Mar 24 05:29:58 localhost OSInstaller[138]: Opening OSInstall package '/System/Installation/Packages/OSInstall.mpkg'.
Mar 24 05:30:24 localhost OSInstaller[138]: Memory statistics for 'Install Mac OS X' pane:
Mar 24 05:30:24 localhost OSInstaller[138]: Physical Memory Allocation: 222 MB wired, 3 MB trapped, 52 MB active, 26 MB inactive, 2769 MB free, 2847 MB usable, 3072 MB total
Mar 24 05:30:25 localhost OSInstaller[138]: Not loading AirPort MenuExtra because this machine does not have wireless networking available.
Mar 24 05:31:34 localhost Unknown[79]: 2013-03-24 05:31:34.422 Disk Utility[145:903] **********
Mar 24 05:31:34 localhost Unknown[79]: 2013-03-24 05:31:34.480 Disk Utility[145:903] Disk Utility started.
Mar 24 05:32:21 localhost Unknown[79]: 2013-03-24 05:32:21.983 Disk Utility[145:903] Verifying volume ?MAC?
Mar 24 05:32:21 localhost Unknown[79]: 2013-03-24 05:32:21.997 Disk Utility[145:903] Starting verification tool:
Mar 24 05:32:39 localhost Unknown[79]: 2013-03-24 05:32:39.843 Disk Utility[145:903] Checking Journaled HFS Plus volume.
Mar 24 05:32:39 localhost Unknown[79]: 2013-03-24 05:32:39.848 Disk Utility[145:903] Checking extents overflow file.
Mar 24 05:32:39 localhost Unknown[79]: 2013-03-24 05:32:39.850 Disk Utility[145:903] Checking catalog file.
Mar 24 05:32:40 localhost Unknown[79]: 2013-03-24 05:32:40.924 Disk Utility[145:903] Checking multi-linked files.
Mar 24 05:32:40 localhost Unknown[79]: 2013-03-24 05:32:40.935 Disk Utility[145:903] Checking catalog hierarchy.
Mar 24 05:32:40 localhost Unknown[79]: 2013-03-24 05:32:40.936 Disk Utility[145:903] Checking extended attributes file.
Mar 24 05:32:42 localhost Unknown[79]: 2013-03-24 05:32:42.736 Disk Utility[145:903] Checking volume bitmap.
Mar 24 05:32:42 localhost Unknown[79]: 2013-03-24 05:32:42.833 Disk Utility[145:903] Checking volume information.
Mar 24 05:32:42 localhost Unknown[79]: 2013-03-24 05:32:42.847 Disk Utility[145:903] The volume MAC appears to be OK.
Mar 24 05:32:43 localhost Unknown[79]: 2013-03-24 05:32:43.119 Disk Utility[145:903] Repair tool completed:
Mar 24 05:32:43 localhost Unknown[79]: 2013-03-24 05:32:43.123 Disk Utility[145:903]
Mar 24 05:32:43 localhost Unknown[79]: 2013-03-24 05:32:43.156 Disk Utility[145:903]
Mar 24 05:32:52 localhost Unknown[79]: 2013-03-24 05:32:52.019 Disk Utility[145:903] Preparing to erase : ?MAC?
Mar 24 05:32:52 localhost Unknown[79]: 2013-03-24 05:32:52.020 Disk Utility[145:903] Partition Scheme: Master Boot Record
Mar 24 05:32:52 localhost Unknown[79]: 2013-03-24 05:32:52.020 Disk Utility[145:903] 1 volume will be erased
Mar 24 05:32:52 localhost Unknown[79]: 2013-03-24 05:32:52.021 Disk Utility[145:903] Name : ?MAC?
Mar 24 05:32:52 localhost Unknown[79]: 2013-03-24 05:32:52.023 Disk Utility[145:903] Size : 107.36 GB
Mar 24 05:32:52 localhost Unknown[79]: 2013-03-24 05:32:52.024 Disk Utility[145:903] Filesystem : Mac OS Extended (Journaled)
Mar 24 05:32:52 localhost Unknown[79]: 2013-03-24 05:32:52.110 Disk Utility[145:903] Unmounting disk
Mar 24 05:32:52 localhost Unknown[79]: 2013-03-24 05:32:52.964 Disk Utility[145:903] Erasing
Mar 24 05:32:55 localhost Unknown[79]: 2013-03-24 05:32:55.808 Disk Utility[145:903] Initialized /dev/rdisk2s5 as a 100 GB HFS Plus volume with a 8192k journal
Mar 24 05:32:55 localhost Unknown[79]: 2013-03-24 05:32:55.811 Disk Utility[145:903] Mounting disk
Mar 24 05:32:56 localhost Unknown[79]: 2013-03-24 05:32:56.423 Disk Utility[145:903] Erase complete.
Mar 24 05:32:56 localhost Unknown[79]: 2013-03-24 05:32:56.424 Disk Utility[145:903]
Mar 24 05:33:01 localhost Unknown[79]: 2013-03-24 05:33:01.580 Disk Utility[145:903] NSDocumentController's invocation of -[NSFileManager URLForDirectory:inDomain:appropriateForURL:create:error:] returned nil for NSAutosavedInformationDirectory. Here's the error:
Mar 24 05:33:01 localhost Unknown[79]: Error Domain=NSCocoaErrorDomain Code=642 UserInfo=0x605b5e0 "You can?t save the file ?Autosave Information? because the volume ?iATKOS S3 version 2? is read only." Underlying Error=(Error Domain=NSPOSIXErrorDomain Code=30 "The operation couldn?t be completed. Read-only file system")
Mar 24 05:33:08 localhost OSInstaller[138]: Allowing machine sleep.
Mar 24 05:35:14 localhost OSInstaller[138]: Preventing machine sleep.
Mar 24 05:35:15 localhost OSInstaller[138]: ================================================================================
Mar 24 05:35:15 localhost OSInstaller[138]: Choices selected for installation:
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Mac OS X"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "iATKOS S3 Main System"
Mar 24 05:35:15 localhost OSInstaller[138]: 10.6.3.Intel.pkg : com.uphuck.pkg.10.6.3.Intel : 10.6.3
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Bootloader"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "AsereBLN v1.1.9"
Mar 24 05:35:15 localhost OSInstaller[138]: aserebln119.pkg : com.uphuck.pkg.aserebln119 : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Patches"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "/Extra directory"
Mar 24 05:35:15 localhost OSInstaller[138]: extra.pkg : com.uphuck.pkg.extra : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "fakesmc"
Mar 24 05:35:15 localhost OSInstaller[138]: fakesmc.pkg : com.uphuck.pkg.fakesmc : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Disabler"
Mar 24 05:35:15 localhost OSInstaller[138]: disabler.pkg : com.uphuck.pkg.disabler : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "RTC"
Mar 24 05:35:15 localhost OSInstaller[138]: rtc.pkg : com.uphuck.pkg.rtc : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "EVO Reboot"
Mar 24 05:35:15 localhost OSInstaller[138]: evoreboot.pkg : com.uphuck.pkg.evoreboot : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: dsdtonroot.pkg : com.uphuck.pkg.dsdtonroot : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Drivers"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Main Hardware"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "SATA/IDE"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Intel SATA/IDE"
Mar 24 05:35:15 localhost OSInstaller[138]: ichx.pkg : com.uphuck.pkg.ichx : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Sound"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Voodoo HDA"
Mar 24 05:35:15 localhost OSInstaller[138]: voodoohda.pkg : com.uphuck.pkg.voodoohda : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Apple HDA 10.6.2"
Mar 24 05:35:15 localhost OSInstaller[138]: applehda1062.pkg : com.uphuck.pkg.applehda1062 : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "PS/2"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Voodoo PS/2"
Mar 24 05:35:15 localhost OSInstaller[138]: voodoops2.pkg : com.uphuck.pkg.voodoops2 : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "CPU Power Management"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Voodoo P-State"
Mar 24 05:35:15 localhost OSInstaller[138]: voodoopstate.pkg : com.uphuck.pkg.voodoopstate : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Laptop Hardware"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Battery"
Mar 24 05:35:15 localhost OSInstaller[138]: voodoobattery.pkg : com.uphuck.pkg.voodoobattery : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Card Reader"
Mar 24 05:35:15 localhost OSInstaller[138]: voodoosdhc.pkg : com.uphuck.pkg.voodoosdhc : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "TSC Sync"
Mar 24 05:35:15 localhost OSInstaller[138]: voodootscsync.pkg : com.uphuck.pkg.voodootscsync : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "ACPI Thermal (32bit)"
Mar 24 05:35:15 localhost OSInstaller[138]: thermal.pkg : com.uphuck.pkg.thermal : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Network"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Wireless"
Mar 24 05:35:15 localhost OSInstaller[138]: Install: "Broadcom"
Mar 24 05:35:15 localhost OSInstaller[138]: bcmids.pkg : com.uphuck.pkg.bcmids : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: OSUpgrade.pkg : com.apple.pkg.OSUpgrade : 10.6.0.1
Mar 24 05:35:15 localhost OSInstaller[138]: OSInstall.pkg : com.apple.pkg.OSInstall : 10.6.0.1
Mar 24 05:35:15 localhost OSInstaller[138]: scripts_a.pkg : com.uphuck.pkg.scripts_a : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: scripts_b.pkg : com.uphuck.pkg.scripts_b : 1.0
Mar 24 05:35:15 localhost OSInstaller[138]: It took 0.01 seconds to summarize the package selections.
Mar 24 05:35:15 localhost OSInstaller[138]: Memory statistics for 'Installing' pane:
Mar 24 05:35:15 localhost OSInstaller[138]: Physical Memory Allocation: 217 MB wired, 3 MB trapped, 56 MB active, 39 MB inactive, 2757 MB free, 2852 MB usable, 3072 MB total
Mar 24 05:35:15 localhost OSInstaller[138]: Remote Install Assistant found at 1024:(null)
Mar 24 05:35:15 localhost runner[143]: Administrator authorization granted.
Mar 24 05:35:16 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/10.6.3.Intel.pkg (5709692928 B)
Mar 24 05:35:16 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/bootloader/aserebln119.pkg (16384 B)
Mar 24 05:35:17 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/extra.pkg (24576 B)
Mar 24 05:35:17 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/fakesmc.pkg (159744 B)
Mar 24 05:35:18 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/disabler.pkg (98304 B)
Mar 24 05:35:18 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/rtc.pkg (106496 B)
Mar 24 05:35:18 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/evoreboot.pkg (114688 B)
Mar 24 05:35:19 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/booter_options/dsdtonroot.pkg (20480 B)
Mar 24 05:35:19 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/sata_pata/ichx.pkg (335872 B)
Mar 24 05:35:20 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/voodoohda.pkg (614400 B)
Mar 24 05:35:20 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/applehda1062.pkg (7421952 B)
Mar 24 05:35:21 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/voodoops2.pkg (708608 B)
Mar 24 05:35:21 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/voodoopstate.pkg (331776 B)
Mar 24 05:35:21 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/voodoobattery.pkg (188416 B)
Mar 24 05:35:22 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/voodoosdhc.pkg (114688 B)
Mar 24 05:35:23 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/voodootscsync.pkg (118784 B)
Mar 24 05:35:23 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/thermal.pkg (114688 B)
Mar 24 05:35:24 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/network/wireless/bcmids.pkg (36864 B)
Mar 24 05:35:24 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/OSUpgrade.pkg (0 B)
Mar 24 05:35:24 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/OSInstall.pkg (0 B)
Mar 24 05:35:25 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/scripts_a.pkg (0 B)
Mar 24 05:35:25 localhost OSInstaller[138]: PK will install package file://localhost/System/Installation/Packages/scripts_b.pkg (0 B)
Mar 24 05:35:25 localhost OSInstaller[138]: Total install size including padding: 6793961472 b
Mar 24 05:35:25 localhost OSInstaller[138]: Starting installation:
Mar 24 05:35:25 localhost OSInstaller[138]: Calculating expected install size requirements
Mar 24 05:35:26 localhost Unknown[79]: 2013-03-24 05:35:26.087 Mac OS X Installer[138:af03] Looking for system packages
Mar 24 05:35:26 localhost Unknown[79]: 2013-03-24 05:35:26.476 Mac OS X Installer[138:af03] no system packages found
Mar 24 05:35:26 localhost Unknown[79]: 2013-03-24 05:35:26.477 Mac OS X Installer[138:af03] No or Invalid system receipts found on /Volumes/MAC
Mar 24 05:35:26 localhost Unknown[79]: 2013-03-24 05:35:26.478 Mac OS X Installer[138:af03] Attempting fallback using: /System/Library/PrivateFrameworks/SystemMigration.framework/Resources/FallbackSystemFiles.plist
Mar 24 05:35:27 localhost Unknown[79]: 2013-03-24 05:35:27.587 Mac OS X Installer[138:af03] Finding system files...
Mar 24 05:35:28 localhost Unknown[79]: 2013-03-24 05:35:28.545 Mac OS X Installer[138:af03] Writing system path cache.
Mar 24 05:35:28 localhost Unknown[79]: 2013-03-24 05:35:28.550 Mac OS X Installer[138:af03] Error writing cache to /Volumes/MAC/Library/Caches/com.apple.FindSystemFiles.plist
Mar 24 05:35:28 localhost Unknown[79]: 2013-03-24 05:35:28.561 Mac OS X Installer[138:af03] Failed to enumerate /Volumes/MAC/Library/Caches, cannot prune (
Mar 24 05:35:28 localhost Unknown[79]: "com.apple.user*pictureCache*"
Mar 24 05:35:28 localhost Unknown[79]: )
Mar 24 05:35:28 localhost OSInstaller[138]: Initial free size : 107.15 GB
Mar 24 05:35:28 localhost OSInstaller[138]: Expected system size : Zero KB
Mar 24 05:35:29 localhost OSInstaller[138]: Reserving 6793961472 for extraction
Mar 24 05:35:29 localhost OSInstaller[138]: Reserving 2787445927 for download
Mar 24 05:35:29 localhost OSInstaller[138]: Performing volume consistency check on 'MAC'.
Mar 24 05:35:44 localhost OSInstaller[138]: Checking Volume
Mar 24 05:35:44 localhost OSInstaller[138]: Checking Journaled HFS Plus volume.
Mar 24 05:35:44 localhost OSInstaller[138]: Checking extents overflow file.
Mar 24 05:35:44 localhost OSInstaller[138]: Checking catalog file.
Mar 24 05:35:46 localhost OSInstaller[138]: Checking multi-linked files.
Mar 24 05:35:46 localhost OSInstaller[138]: Checking catalog hierarchy.
Mar 24 05:35:46 localhost OSInstaller[138]: Checking extended attributes file.
Mar 24 05:35:48 localhost OSInstaller[138]: Checking volume bitmap.
Mar 24 05:35:48 localhost OSInstaller[138]: Checking volume information.
Mar 24 05:35:48 localhost OSInstaller[138]: The volume MAC appears to be OK.
Mar 24 05:35:48 localhost OSInstaller[138]: Volume repair complete.
Mar 24 05:35:48 localhost OSInstaller[138]: Updating boot support partitions for the volume as required.
Mar 24 05:35:48 localhost OSInstaller[138]: Volume passed consistency checks.
Mar 24 05:35:48 localhost OSInstaller[138]: Copying/Downloading selected packages locally
Mar 24 05:35:48 localhost OSInstaller[138]: Creating mutable product on /Volumes/MAC/Mac OS X Install Data
Mar 24 05:35:48 localhost OSInstaller[138]: Using packages from product at /Volumes/MAC/Mac OS X Install Data
Mar 24 05:35:49 localhost OSInstaller[138]: Linked to PackageKit-65
Mar 24 05:35:49 localhost OSInstaller[138]: Remote package size (2787445927) : available size (107151536128)
Mar 24 05:35:49 localhost OSInstaller[138]: Copying remote packages (22) to mutable product.
Mar 24 05:35:49 localhost OSInstaller[138]: Retrieved package com.uphuck.pkg.aserebln119
Mar 24 05:36:20 localhost Unknown[79]: 2013-03-24 05:36 Mac OS X Installer[138] (CarbonCore.framework) FSEventStreamStart: ERROR: FSEvents_connect() => Unknown service name (1102)
Mar 24 05:36:37 localhost OSInstaller[138]: NetworkBrowser failed to launch "/usr/bin/nmblookup" (No such file or directory)
anyone
Edited by Steptov2lol
2 answers to this question
