marcoz
ALC892 - ALC887 - Voodoo.kext optimized for Yosemite
Hi guys, after a lot of research i found this kext that work very very well .. i try it on mob with ALC892 and another with ALC887 .. no noise .. it's perfect.
I have done so:
1. Install Voodoo.kext 2.7.3 with MB{censored} for Yosemite.
2. After a reboot you hear a big noise on the speakers
3. Install with your favorite utility (kextutility,kexthelper etc.) the attached kext.
4. Restart and enjoy the audio clean.
It works on Yosemite but i think also on Mavericks.
VoodooHDA.kext.zip
Thanx for your work. I did above. had the noise, restarted, still had the noise, installed the voodooHDA.kext. had noise and sound....
restarted........ silence.....
what went wrong???
what to do??
thanx in advance
Edit: before i did above, i tried this method of getting the sound to work:http://www.hackintoshosx.com/files/file/4139-alc892-with-hdaenabler1-1010/
maybe on startup the second time those kext are bugging the voodooHDA??
i removed the first 2 kext, AppleHDA892.kext and the HDAEnabler1.kext, but can i/should i remove the AppleHDA.kext also??
Edit (again): i can't find the appleHDA.kext in s/l/e..... Did MB{censored} remove that?? should i put that back there??
Edited by flatfeet
Hi flatfeet, first of all .. what system you have? Yosemite? Maveriks?
Second .. in S/L/E you must remove the AppleHDA.kext
Third .. you must also remove all the enablers you have installed
Four .. with MB{censored} for Yosemite (or Maveriks if you have it) you must use Voodoo.kext 2.7.3
and the last thing .. what chipset you have? I tried with success only for alc892 and alc887.
Let me know ..?
OK, deleted kexts
installed voodoo via MB{censored}
restart -> Noise
edit, voodooHDA.kext from this post installed, sound!, but also still NOISE.
Now restart.....
Edited by flatfeet
Sound!!!!! NO NOISE. Thank you.
only stupid thing, my BT magic mouse is now not working as a magic mouse, but only as a normal mouse...... didn't do that before..... and als jumps up to the top of the screen....
Remembrer to fix permission on hd
if help you i use a Chameleon boot loader version Enoch r2403 and a flag inside chameleon.boot.plist kext-dev-mode=1
