tereptimbut1978
IDT Audio Kext ⎜Yosemite ⎜IDT92HD87B1⎜Intel HD Audio⎜Dell Inspiron N5110
After a long search & googling I got the kext for my Audio Hardware [Click Here - To check], but Unable to Install it. Actually I am not understanding how to do that. However, I can get sound through Voodoo Method by?Hackintosh.Zone {All In One Audio Solution},?but couldn't have any control on it, (e.g Volume Down, Volume Up or Mute doesn't affect the Volume [Master Volume] & also Balancing doesn't work too!), only gets the sound.
Another Help!
I also got driver for my audio card from "Hackintosh Vietnam Tool" (Continue >?Continue >?Continue > Agree > Kexts > Sound > Patch AppleHDA > Laptop > IDT > IDT7605 > IDT7605 v2) which is for N5050 series [Laptop which have same audio card as mine - checked from Dell official website]. But It asks for "require vanilla AppleHDA.kext in S/L/E and inject audio layout 12". But couldn't do this (LayoutID=12 - no success). Later, got ?the Vanilla Apple HDA.?And after hitting (Continue > Install) getting the files "AppleHDAIDT7605.kext" & "AppleHDAIDT7605.xml", Now, I don't know where to copy this files, Specially the .xml file. Please Help!
Thanks in Advance!
Files:
AppleHDA-2.6.1f2-IDT92HD87B1.zip
All in One Audio Solution.mpkg.zip
AppleHDAIDT7605.kext.zip
AppleHDAIDT7605.xml
Images (System Information):
1.tiff
2.tiff
Thnx, but from windows I got 111D_76D1 instead of 111D_7605 ?& couldn't ?create my DSDT?@walkman8196
And solved the Voodoo Slider and ?Mute by editing its Info.plist - by luck. But balance still doesn't work.
The Volume Slider & Mute Fix For Voodoo:
VoodooHDA.kext.zip
Edited by tereptimbut1978
VoodooHDA very bad sound.
if you 111D_76D1, then you have 92HD87B1 / 3 (111D 76D1)
Man! Ok, agree Voodoo is bad! But I am getting sound only through voodoo.
Unable to do as u told. Unable to patch...
Please help with more details... (I already got those files u shared) I need Instructions...! :):(
Update:
After edit DSDT (Not sure I edited correctly or not):
Untitled.tiff - Image
DSDT.aml.zip - DSDT - N5110 (Mine)
To help us know what drivers you need, we need to know a little more about you specs:
Use the following as a guide:
Try these kext from:
http://www.insanelymac.com/forum/topic/298663-applehda-for-yosemite/
AppleHDA-269.25-ALC887VD.zip -?AppleHDA.kext for your Codec
AppleHDA-269.25-IDT92HD87B1.zip
HDAEnabler3.kext.zip -?Kext that enables AppleHDA.kext for Laptops, use instead of the DSDT for ?Audio injection
HDAEnabler3.kext.zip9
Remove the DSDT you modified for Audio. -?If you used a DSDT before the one you modified, use it, otherwise a DSDT is not needed.?
Remove VoodooHDA kext ?and the modified DSDTfrom System/Library/Extensions and installed the kext using Kext Wizard app, rebooted in safe mode and ran the following commands:
/sbin/mount -uw /?/sbin/kextcache -prelinked-kernel - (If it returns "segmentation fault 11" ?Rerun both commands until it runs clean.)exit
Helpful hint for this forum:
Add your specs to your signature, and it will always show up on every post. (See Mine Below)
