partenio
Driver/kext ATI Radeon HD4350
Good evening to all friends of the forum. I managed to install sierra 10.12, the only problem I have is related to the video card: this is an ATI Radeon HD 4350. How do I install the drivers so as to make them work properly? It points out that currently the pc works with the basic drivers injet ATI I thank everyone in advance
4 answers to this question
This is what you have to do
Go>Computer>System>Library>Extensions> and copy ATI4600Controller.kext
Create new folder on desktop and paste the item (ATI4600Controller.kext).
Now Right-click on the ATI4600Controller.kext (copied one) and select "Show Package Contents". Check if the info.plist shows the Graphic Card PCI ID of ATI 4350 model (0x954F1002). If not add it. Then save the plist and install the edited kext with Kext Wizard.
It should work now
It should work now
Thank you for the information, but I can not find the file ATI4600Controller.kext;
Another thing I did several tests with other kext but as soon as I copy it in System> Library> Extensions, it is copied and it says, with 10:12 sierra, which can not be applied to its operation.
You may dictate manual procedure and obtain permission for the application?
It should work now
Thank you so much for the information, I was able to find the kext I changed with the id of my scehda video and now it works great.
Thank you so much for the help given
Hi ı have hd4350 pls help me. I use El Capitan
