Martonijus
[resolved] Problem after kexts installing
Posted (edited)
Hello, using hackintosh - Yosemite for months. I got all working except battery indicator. I followed some tutorial on youtube and downloaded battery kexts and installed. After that Hackintosh didn't boot, got some kernel panic, over the apple logo screen and coulnd't boot normaly neither in -x mode. Finally I boot when I used UseKernelCache=No -x. I deleted the battery kexts, restore the old ones.. Then I had no kernel panic on apple logo however it boots only in -x mode. In -v mode I got the message, see the image below.. Thank you in advance for any help
Edited by Martonijus
7 answers to this question
Those errors are telling you that the 'Dependency' files are either missing or they are incorrect versions or that they are not compatible in some other way.
My personal experience with these kind of errors is to start from the last one reported, so in this case the voodoo ps2controller - If it's missing, add it, if it's there remove it and see if you can boot without it. If removing it don't let you boot, then seek help from RehabMan and replace it with whatever version/fix he supplies or recommends.
Martin
Thank you Martin for your reply. I deleted voodoo ps2 controller, didn't help, I installed new one, didn't help. I post on Rehabman's forum but it's difficult to get reply there. Actually I post on many forums. Except you no one replied yet.
This might help, no promises as it's a different model but it seems very thorough
Martin
Thanks, but these are tutorials for installation new OS X if I understood correctly.. I have OS X already installed, worked normally for months, just need it to fix it to boot it normaly
I fixed it. I remember after I installed OS X for the first time successfully, I wrote down all the steps I did as well I backup all the files, kexts etc that I used during installation. There was a step that I already forgot that installation of AppleACPIPlatform.kext solved my issue with not booting to normal mode.. So I just found the AppleACPIPlatform.kext file, installed and it works
I noticed that very same kext being mentioned as a possible fix in the link I provided too. I provided the link not as a how to install, but to follow the fixes that the poster has tried and used to get things working.
It's great to know you have it up n running again and well done for remembering you took notes from when you first installed things, there's a lesson right there for anyone reading this :)
When you get chance could you please change your post title to [fixed] or [resolved] thanks - Have a great 2017 and enjoy your hack!
Martin
