We are currently experiencing problems with some external links - please bear with us while we fix this!
You can find your file using the site search - or post in the forums if you can't and we will find it for you :)
Sa-ROG
[Guide] Asus G750 Sierra 10.12.3
Sa-ROG
[Guide] Asus G750JW Sierra 10.12.3
INSTALL 10.12.3
Create an USB Drive Installer of macOS Sierra 10.12.3 with Clover Bootloader
In EFI/CLOVER/kexts/Others add FakeSMC.kext to recognize the System Management Controller
and ApplePS2SmartTouchPad.kext to recognize keyboard and touch-pad during installation
Start installation in SafeMode (-x)
When you finish, install the last version of Clover to start-up from HDD
NVIDIA GTX 765M
Use any Clover configurator to change the system definition in config.plist
In SMBIOS section choose iMac14,2
In Boot section add the Custom Flag nvda_drv=1 to enable graphics Nvidia with Web Driver
Graphic card will work natively!
AUDIO ALC282
Use any kext installer to install to S/L/E folder these kexts:
AppleHDA.kext (to recognize ALC282 audio)
HDAEnabler13.kext (to assign Layout ID=13)
(Otherwise, you can use the new AppleHDA Patcher.app
to directly patch AppleHDA.kext in S/L/E)
ETHERNET QUALCOMM ATHEROS QCA8171
Install ALXEthernet.kext to S/L/E folder using any kext installer
CARD READER
Install AppleStorageDrivers.kext to S/L/E folder using any kext installer
Though it seems not be recognized, don't worry! It will work correctly!
WI-FI BROADCOM BCM94352
From Os X Mavericks to macOS Sierra I needed to change the WiFi card
In my case, I’ve used a Broadcom BCM94352 half-mini card
For correct working, I needed to install to EFI folder these kexts:
FakePCIID_Broadcom_WiFi.kext
FakePCIID.kext
Using any Clover configurator, add in config.plist these strings:
<key>Comment</key>
<string>Brcm4360 Sierra fvco init</string>
<key>Disabled</key>
<false/>
<key>Find</key>
<data>81F952AA00007529=</data>
<key>Name</key>
<string>AirPortBrcm4360</string>
<key>Replace</key>
<data>81F952AA00006690=</data>
Change in S/L/E folder the IO80211Family.kext with the same kext you can found in Os X Yosemite Installer
BLUETOOTH BROADCOM BCM20702A0
Install to EFI folder these kexts:
BrcmFirmwareData.kext
BrcmFirmwareRepo.kext
BrcmNonPatchRAM.kext
BrcmNonPatchRAM2.kext
BrcmPatchRAM.kext
BrcmPatchRAM2.kext
MONITORING HWSENSORS
Before to use HWMonitor.app
you need to install to EFI folder these kexts:
FakeSMC_ACPISensors.kext
FakeSMC_CPUSensors.kext
FakeSMC_GPUSensors.kext
FakeSMC_LPCSensors.kext
If you'd like your monitoring appears like this:
you need to go to HWMonitor.app/Contents/Resources/ and change these files:
CUSTOMIZE
To change logo on About This Mac
Simply you need to modify this file:
/Applications/Utilities/System Information.app/Contents/Resources/SystemLogo.tiff
For example:
TOOLS
Meanwhile I'm working on keyboard's kexts to fix Brightness, Backlight and Fn Key...
...you can use this app to adjust Brightness:
KEYBOARD
***COMING SOON***
FOR ANY QUESTIONS, CONTACT ME.
I WILL BE HAPPY TO HELP YOU!
IF YOU WANT TO CONTRIBUTE TO MY WORK
YOU CAN MAKE AN OFFER HERE:
PayPal.Me/SaROG
MANY THANKS
Sa-ROG
Archive.zip
Edited by Sa-ROG
Thank you for GREAT GUIDE!
I have Asus G701VO and making that boot macOS.
So far have boot, nvidia, lan, wifi, ethernet, cardreader, web-cam.
Don't have PCIe NVMe, sleep/wake, DSDT. Working on that now.
Did you figure out Keyboard brightness, screen brightness?
Edited by emdirector
Thanks emdirector,
I already got a Asus G750JW Fully Working with Mavericks 10.9.5 (I use it for my DAW)
I was trying to do a new installation with macOS Sierra, but I've decide to wait the last update to complete my guide. bye
i have asus g751jy, seems to be almost the same. i have problems with HDMI, monitor works nice (nvidia web driver), if i plug in hdmi cable, the screen jumps to the connected TV (everything fine). BUT: my laptop screen gets black, even if i unplug HDMI cable the laptop screen is black, only way to get back screen is plug in hdmi again so the screen is on my TV, restart laptop and unplug hdmi, then i have screen on laptop again. (also in settings -- monitors) i have no option to use 2 screens, extend, mirror etc
Zitat
