Mirone
Can I Help you?
3 minutes ago, spainter10 said:
yes, and yes
After downloading the installer, connect your Mac to the USB flash drive or other volume that will be used as the bootable installer. Make sure that it has at least 12GB of available storage.
Open Terminal, which is in the Utilities folder of your Applications folder.
Type or paste one of the following commands in Terminal. These assume that the installer is still in your Applications folder, and the name of your volume is MyVolume. If it's named differently, replace MyVolume accordingly.
sudo /Applications/Install\ macOS\ High\ Sierra.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume --applicationpath /Applications/Install\ macOS\ High\ Sierra.app
PS: MyVolume =  Your Pendrive name.
After mounting the installer you must install clover on your usb stick,
you are already familiar with these steps?
