kali2000
GUIDE FOR MSI CX61 2PC
Tested on 10.13.5
Hi my friends…
This is a complete guide for MSI CX61 2PC.
System features:
Ø  CPU: 4th generation Intel® Core™ i7-4712MQ Processor  :encouragement:
Ø  RAM: 16GB DDR3 1600MHz :encouragement:
Ø  SATA: Intel(R) 8 Series Chipset Family SATA AHCI Controller :encouragement:
Ø  Graphics: Intel HD 4600 up patch to 2048MB :encouragement:
Ø  Optimus: nVidia GeForce 820M; disabled by DSDT :thumbsdown_anim:
Ø  Audio: Realtek ALC269 :encouragement:
Ø  HDMI: Audio & video work fine :encouragement:
Ø  LCD: 15.6" HD (1366x768) / FHD(1920x1080) LED backlight :encouragement:
Ø  Lan: Qualcomm Atheros AR8161 PCI-E Gigabit Ethernet Controller :encouragement:
Ø  WiFi & Bluetooth: replaced with compatible device...  :whistling: I use Broadcom BCM4352 Azurewave AW-CE123H WiFi + BT 867Mbps Bluetooth 4.0 :encouragement:
Ø  Trackpad: Elan :encouragement:
Ø  Optical device: BD Combo / DVD Super Multi... :encouragement: I replace it with SSD disc, now optical device is external. (Optional) :P
Ø  Card Reader: Realtek :encouragement:
Ø  USB: 1 USB2.0 & 2 USB3.0 :encouragement:
Ø  Web Cam: HD type (30fps@720p) :encouragement:
-      First off all, you have to do a OSx bootable USB.
-      Format USB Stick. Use Mac OS  Extended (Journaled) & GUID table partitions. Rename it to USB.
-      You can get the OSx pkg installer from the AppStore, make it bootable on your USB Stick via terminal, not with the help of any other third party tool. You can use this in terminal to do bootable USB...
sudo /Applications/Install\ macOS\ High\ Sierra.app/Contents/Resources/createinstallmedia --applicationpath /Applications/Install\ macOS\ High\ Sierra.app  --volume /Volumes/USB/ —nointeraction
      To use this, is necessary, rename USB stick to USB and Install macOS High Sierra pkg must located in Applications.
-      Install clover in the USB Stick. Use UEFI. You can download last clover version there
-      Once this is done, we begin the explanation.
       ·      Mount EFI partition from bootable USB Stick.
       ·      Replace completely CLOVER folder, do not combine, replace. Located in Install pen folder from my pack.
       ·      Now you have a MSI CX61 2PC USB Stick install.
-      BIOS configuration.
       ·     Use E16GDIMS.50Q BIOS version.
       ·     PCI Latency: 32.
       ·     Intel SpeedStep: Enabled.
       ·     Sata mode: AHCI
       ·     USB configuration: Only during installation, you have change BIOS USB3.0 Support to Disabled. Then, you can return to Enable it. Others use Enabled.
       ·     Boot mode select: UEFI with CSM
-      Boot USB and do install.
-      Then install clover in the OSx disc. Use UEFI.
-      Mount EFI partition from OSx disc.
-      Replace completely CLOVER folder, do not combine, replace. Located in Post-Install folder from my pack.
-      Install all kext located in Post-Install folder with your preferred method.
Congratulations… reboot and enjoy OSx…
Thanks to my friend Dinesh and MaLd0n for all the support... And thanks to RehabMan for support and her kexts...
Download MSI CX61 2PC pack
Some pictures...
559338549_Capturadepantalla2018-06-14alas21_39_46.png.4d6f0f4ed1f138be5e851340a6ff1233.png
684246401_Capturadepantalla2018-06-14alas21_40_42.png.23ea1d64b1695f3f909ee2c5af04f6d1.png
904465021_Capturadepantalla2018-06-14alas21_39_00.png.a8c3320f71756bf1fe480085c0242331.png
1011719570_Capturadepantalla2018-06-14alas21_42_00.png.a1b8d714907ffeb87292e99b6ddf01d3.png
1094896962_Capturadepantalla2018-06-14alas21_41_09.png.09ced20d43e1a34f484001763428a5af.png
