guidorosso
Speedstep Issues
Hello All,
I've been trying to get speedstepping to work on my q9950 (quad core 2.83ghz) and my ga-ep45-ud3p. I'm using Chameleon 2 RC3 and everything is running fine except for speedstepping. These are my kexts:
CPUi.kext (to be able to use the CPUi app to monitor my cpu)
CPUInjector.kext
fakesmc.kekt
LegacyHDA.kext
OpenHaltRestart.kext
PlatformUUID.kext
My processor is constantly running at 58 degrees Celsius, so I'd like to get this figured out.
I've tried running with voodoopowermini.kext but still no luck.
I also tried to follow the guide here http://www.insanelymac.com/forum/index.php?showtopic=181631&st=20&start=20 to get speedstep working natively through my DSDT. However, I get no PStates when running PStateChanger (even after rebooting with VoodooPState.kext). The PState table is simply empty.
Any ideas or tips? Is there any other way to get my PStates? Any help would be most appreciated, thanks!
Is speedstepping enabled in your BIOS? C1E, etc? I don't mean to insult by something obvious, but it's also easy to overlook...
Hi Richiem,
Yep I have C1E, C2/C2E, C4/C4E enabled in the bios.
However, your post reminded me that I initially had to increase the voltage on my RAM (per the manufacturer's recommendation) as apparently the auto settings are incorrect and could cause stability issues. Would this cause speedstepping to be automatically disabled?
X-EFI-X'er,
I'll certainly post the DSDT when I'm back in the office (at home right now). However, you won't see any of these values in there yet.
I was trying to follow the guide I linked to in my first post, but I'm getting stuck at the part where I have to run the PStateChanger app to get the values for my processor. The app is simply empty and shows no info in the tables. I added VoodooPState.kext to my extras folder, as the guide suggests, but I still don't get the values.
I'll post my full DSDT later today or tomorrow. Thanks!
