rangkok
need help for ati radeon HD 6670 (kext)
Exist any kext for ati radeon hd 6670??? I need it, please.
You should be able to boot with this flags without any special kext...
<key>GraphicsEnabler</key>
<key>AtiConfig</key>
<string>Pithecia</string>
<key>AtiPorts</key>
<string>3</string>
if u use 10.8.2 you should delete ati6000 kext from extensions before instalation...
follow this tutorial for details
Hello!
I have asus radeon HD 6670
ati6000 kext is removed from extensions
org.chameleon.Boot.plist:
<key>SMbiosdate</key>
<string>04/22/11</string>
<key>SMbiosvendor</key>
<string>Apple Inc.</string>
<key>SMbiosversion</key>
<string>IM121.88Z.0047.B0A.1104221555</string>
<key>SMboardproduct</key>
<string>Mac-942B5BF58194151B</string>
<key>SMfamily</key>
<string>iMac</string>
<key>SMmanufacturer</key>
<key>SMproductname</key>
<string>iMac12,1</string>
<key>SMserial</key>
<string>C02J1876DHJT</string>
<key>SMsystemversion</key>
<string>1.0</string>
<key>AtiPorts</key>
<key>Kernel Flags</key>
<string>PCIRootUID=0</string>
<string>3</string>
but my monitor turn off, and i see a black screen when the load is startin
motherboard - Gigabyte GA-Z77-DS3H rev1.0
internal graphics --> disabled
init display first --> PEG
what i do wrong?
ps sorry for my english)
I use a Gigabyte GA-Z77-DS3H rev1.1 Motherboard and use a similar org.chameleon.boot.plist
<string>Duckweed</string>
<key>AtiPorts</key>
<string>5</string>
<key>Graphics Mode</key>
<string>1280x1024x32</string>
Some suggestions:
1. At the chameleon boot screen try and add this boot flag:
"Graphics Mode"="1280x1080x32" -v
Note the placement of the quotes, replace "1280x1080x32" with your default resolution.
2. At the chameleon boot screen try and add this boot flag:
GraphicsEnabler=No "Graphics Mode"="1280x1080x32" -v
3. Try to boot with flag -x to get to the desktop for further troubleshooting.
Hello!
<key>SMfamily</key>
<key>SMserial</key>
<key>AtiPorts</key>
<string>3</string>
what i do wrong?
try to change
<string>No</string>
remove ati6000 kext from usb installer.
than install Os X, and than put back ati6000 kext...
tutorial for this GPU can be found here Ati Radeon Sapphire HD 6670 1GB GDDR5 on OSX 10.7.4 / 10.8.2 | transformNews ? OSX86
and fix this part
<key>AtiPorts</key>
<string>3</string>
like this
<key>AtiPorts</key>
<string>3</string>
try to change
Is there any way to fix this post installation. I already have a running system fully setup. The only issue I am having is my card is not fully recognized "Graphics AMD Radeon HD 6xxx 1024 MB" in system profiler and I have no video output when I wake from sleep.
