hallowman
intel gma 950 solution
Hi guys
My card is gma 950 (27a2)
its working on Lion 10.7.2 , 10.7.3 also works snow leo 10.6.3, 10.6.8
I ve made a tutorial about how to doin it..
hope it helps you
5 answers to this question
My embedded GMA is 2772 device id, i've tried to replace intelframebuffer with new ones, and result is same.. no q/e enabled.
but with hacking dsdt.aml and include him into my boot.plist and boot into arch=i386.. the result is fantastic.. all resolution display is appeared with Q/E enabled. no inject or replacing the kext.
i used Lion 10.7.3 also work in 10.7.2 too.
if used snow leopard, u should to install PC.EFI.. and add/replacing the kext from above link.. dont forget.. to boot into 32 arch..
Edited by Koentji
today i've managed to install my GMA950 27a2 on a Vaio VGN-N31s fully working with http://www.osx86.net/view/2141-gma950_+_lion.html
And fully menas with QE CI
;o) YIPIEHHHE
Installed iAtkos L2 (10.7.2)
disabled GraphicsEnabler.
enabled 32 bit (arch=i386)
After install i booted directly into Sigleuser -> bootloader "-s"
mv AppleIntelGMA950* /Users/Shared/
mv AppleIntelIntegratedFramebuffer.kext /Users/Shared/
rebooted and installed with the kexthelper the /Users/Shared/AppleIntelGMA950* and the AppleIntelIntegratedFramebuffer.kext downlod from the link.
Reboot and it runs in 1280x800 with QE/CI
