Convalescence101
Power PC applications are no longer supported!?!?!?
Hi There
I am trying to install MAXON Cinema 4D r13 on my iMac (Mac OS X 10.7.2) but the setup of Cinema 4D is "grayed"
out and when i double click it gives me an error message " Power PC applications are no longer supported ". Is there any way to make the software work without going back to an earlier version of Mac OSX ?
Please, any advice or suggestions?
Thnx
System Requirements
Recommended system requirements include Windows XP, Vista or 7 running on Intel or AMD CPU with SSE2-Support; Mac OS X 10.5.8 or higher running on an Intel-based Mac and 1024 MB RAM, DVD ROM drive. Up to 256 threads now supported. Standard DVD installation can take up to 2.5 GB of disk space.
