XoVoX
Gigabyte GA-Z77-D3H fully working incl. sound on 10.7.4!
First attempt and instant success with this motherboard, everything just works fine!
Hardware:
Motherboard: Gigabyte GA-Z77-D3H <-- iATKOS L2 boots to installer without any problems
CPU: Intel i7 2600k <-- Fully supported
Memory: 4 GB Ram DDR3 1333MHz <-- Fully recognized
Audio: On board VIA VT2021 <-- Fully works with VoodooHDA from MB{censored} 4.5.2
Network: On board Atheros GbE Lan <-- Fully supported with MB{censored} 4.5.2
Graphic: Gigabyte Nvidia GTS450 <-- Works out of the box!
Software used:
iAtkos L2 (10.7.2)
Combo update 10.7.4
MB{censored} 4.5.2 Lion edition
Booted from iATKOS L2, installed on a GUID Harddisk
Installed the MacOSX 10.7.4 combo update, without rebooting started the MB{censored} 4.5.2 Lion edition.
At MB{censored} I used easybeast option + VoodooHDA latest edition + Atheros driver
Rebooted and well, everything just works fine!
To prepare the iatkos l2 , do I need to use a working mac to restore on a USB?
What are the options u choose during options for bootloader and stuff? :)
Hardware:
Software used:
iAtkos L2 (10.7.2)
Combo update 10.7.4
Anyway which voodooHDA did you choose, i have the same motherboard but diff graphic card though..using 6870...no issue with graphics..i choose the latest Voodoo but got kernel panic..
Thank you for the quick reply , so you install the easy beast + voodooHDA and the bridgehelper all after installing the combo update and before restart?did you remove applehda as well? :)
Still not able to work...realised I'm on sandy instead of ivy....not sound facing problem... :(
Still not able to work...realised I'm on sandy instead of ivy....only sound facing problem... :(
