Aj is working on this and as far as i know it will work.
Maybe the guide to get Intel 4000 HD graphics working will help OS X recognize the number of cores. I guess I'm gonna try that and see if it works sometime this week.
Correct me if I'm wrong but I think that the guide Aj is making will have everything but the Nvidia card.
Well you're probably right but the least I can do is help. I was lucky to get the model with the working Nvidia 650 1GB card, so that should work.
You're damn lucky, I'm hoping that hp will update the BIOS so that you can turn the HD 4000 off, this should fix the problems that people are having. I think I'll send them an email tomorrow.
Are you aware of what happens if you have both the Intel graphics on and the Nvidia on? Does it intelligently switch between the two or just use one?
As far as i have come to understand is that the problem there is with the hackintosh is the switching between the cards. Apple uses the cards differently then a normal pc and people say that they might be doing the switching between the 2 cards via hardware (this is not sure). So there is support for the GT 6xx m cards natively in os x but the problem is in the switching. For this reason turning on the HD 4000 should fix the problem. This is what I have understood from my research.
