Ok at the moment I am busy with the DSDT, SSDT, and powermanagment. I didn't try the 10.8.3 yet as the download was going slow and didn't finish. I think I will first work on getting this system working on 10.8.2 and then I'll look at the update.
Update: Just so you guys know, when you use chameleon wizard also make a org.chameleon.Boot. You dont need to fill any of the options in just save the blank one in /Extra. Once you have the blank org.chameleon.Boot in /Extra open it if you want to edit it. It is nice to get the right resolution so go to the right and look for Graphics Mode, then select the one you need (720p is 1366x768x32 and 1080p is 192x1080x32) and save that. So the next time you boot into OS X the resolution will be correct and it will look allot nicer :).
Update: So I am still busy with getting the dsdt, ssdt and powermanagment, BUT I do already have the cpus=1 fixed. Download this lapic fix and follow the instructions provided by iGebriel. After following all his instructions you should be able to boot with just using GraphicsEnabler=No.
Hackintosh ML 10.8.2 mach_kernel_lapic_fix.zip - Downloads - OSx86.net
Update: Ok so I just tried booting without GraphicsEnabler=No and it worked. So ill see what I can get working. Now I also have audio working. Download this and follow the instructions in the folder. I know it says Lion but trust me it works. Hackintosh LION IDT92HD75B3 HP 8540w Audio kext - Downloads - OSx86.net
Edited by david105396
ok guys I got full graphics support HD4000. 512mb VRam. add this string to org.chameleon.Boot. Use text editor
<key>device-properties</key>
<string>5e00000001000000010000005200000001000000 02 010c00d041030a000000000101060000027fff04002c000000 4100410050004c002c00690067002d0070006c006100740066 006f0072006d002d006900640000000800000003006601</string>
2 questions, so can you dual boot with this turtorial, and also can you install it onto one of those flashdrives that you can leave in your computer?
You should be able to dual boot, I havent tried as I can't risk losing my data. I recommend googling a little to see if that works. If you can't find it tell me and ill try for you. Sorry I'm not sure what you mean with "one of those flashdrives". If you mean a usb stick or an external hard drive then yes you can.
Also, the lapic fix kernel works. I get all 4 cores and threads responding. Feel free to use it. I would like a better solution but for now it is great.
Update: Ok guys so the last few times I have been getting weird kp's. Don't know what the problem is. I'm pretty it's just me being sloppy. Please try and see what you guys get. Just some tips. Always boot with -v. If your boot fails and you get back to U{censored} try -v again, it should work. If you get a kp reboot and try again. If it then doesn't work we'll need to figure something out.
