Just before i install, would it be possible to remove the nvidia kexts before installing?
You install it on your drive and then before you do the initial boot where you fill in your info you need to remove the geforce kexts.
I haven't tried but you should be able to delete the geforce kexts before they are installed. But again I can't say if this works or not, feel free to try though. Just open the U{censored} USB and find those kexts and then delete them.
Update: Just as I was about to lose hope and contact ebay, my wireless card came in. So naturally I opened up my laptop and put in the card. First I booted into windows 8 and it instantly uses the card without drivers, you will need to fill in your wireless password for the network again though but thats no biggy. Now I just booted OS X and it instantly sees it and uses it, no need for kexts or even settings just boot up, fill in your password and it work. I am this from OS X with this wireless chip. The card is preforming just as good as the intel card I had. So it is a win win. Here is a link to the exact card I bought, do note it took 2 months to get to me in the netherlands.
http://www.ebay.com/itm/300778771732?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Edited by david105396
OK so I'm booted into mountain lion but was wondering how you got Ethernet to work?
ok turn off your computer. then when it is off attach the ethernet cable. Now boot back into OS X and you have ethernet.
