goobyjr9, at this point (going from memory) you go to the menu at the top of the screen, and one of your options should be disk utility. Go into there and select the partition or create the partition you want to install on. Ensure the partition format is osx journaled, when you are finished close disk utility which should take you back to installer and should give you a valid disk/partition to install from. then continue with the installation process.
see how it goes. get back if any problems.
Thanks for your quick reply I have the same problem I CANT see the disks to install, my laptop hp dv7t-7000 is the same as dv6-7000 why we cant se the drives, I tried to format an usb with mac osx extended journaled and the same, disk utility cant see it, help please
MMMmmm. Strange. I've not encountered that ever. Logically i guess irrespective of how your drive is formatted, it should show up in disk utility. the sata state is not accesible from the laptop bios settings, so we know that that is acceptable to mac osx, may be an issue in your case. I'll have a look at some related posts later and see if any help is available there.
I forgot to mention that Im using a SSD Sata3 Corsair as principal and unique drive, is there any trouble with SSD drives? and im using U{censored} mountain lion . thanks
Rafael. U{censored} is not being addressed here. I used U{censored} previously and couldn't get anywhere with it. So I'm only covering the installation and lion usb creation as given earlier. Having said that. I'm looking into the missing drive issue so will get back with whatever I find. Give me a few days though as the olympics are on and I'm in london for the next 3 weeks anyway.
