Could anyone send me the whole install package (app file) of Moutain Lion 10.8.2? I can't find it on the internet... I have just set up a virtual machine (with virtual box) for using U{censored} with iAtkos.
Ok it is taking a while but you will get it, don't worry :)
hadnt thought of that, that should sort it! thanks
No problem, hope it works for you. I am just waiting until I have some more time to try and update it. Hopefully apple will not update it allot so we can just have a system without having to fix updates :)
So i have osx installed on a flash drive, it boots up slow and runs slow, does anybody else have this problem, if not is it because i am working off of a 8g flashdrive
USB 2.0 flash speeds are much, much slower than USB 3.0. If you run it off an external hard drive, you're getting almost SATA level performance, whereas with USB 2.0, you're probably getting 7-27 mb/s read/write, which is pretty miserable.
ok well if you want to try and get a fully working system with 10.8.2 and i can try to find out what has to be done to succesfully boot 10.8.3?
Sounds like a plan. But I will have to work very hard on my school work if I don't want to fail the year, no reason I should fail just have allot of work to catch up. So I am not sure when I will have time again to work on it.
