I think I understand what happend. When I format my USB stick to mac os x extended (journaled), I can't unmount it properly. So U{censored} and myHack can't unmount it. I tried both VirtualBox and VMWare and faced the same problem. Could you figure out how to solve this?
try MBR,not GUID then choose hfs+ extend journaled to partition
New problem with U{censored} and myHack. I pass the unmount process. But then U{censored} stucks at "Running script package" (the USB light flashes for 10 mins and then hangs on there forever). Otherwise, myHack stucks at 51% and hangs up there too. I try both MBR and GPT but no luck. Still run on VMWare. Anyone has a solution for this?
It's no use. I let it run over night but it still stuck there (for 6 hours +).
Here is the install log of U{censored}
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: @(#)PROGRAM:Install PROJECT:Install-735
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: @(#)PROGRAM:Installer PROJECT:Installer-614
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Hardware: VMware7,1 @ 2.19 GHz (x 6), 4096 MB RAM
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Running OS Build: Mac OS X 10.8.2 (12C60)
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: PATH=/usr/bin:/bin:/usr/sbin:/sbin
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: TMPDIR=/var/folders/ss/y5tnlg0x0gq5cmqh3b42tqv80000gn/T/
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: SHELL=/bin/bash
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: HOME=/Users/minhhikari
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: USER=minhhikari
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: LOGNAME=minhhikari
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: SSH_AUTH_SOCK=/tmp/launch-PyVG0Q/Listeners
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: Apple_Ubiquity_Message=/tmp/launch-3QrBPD/Apple_Ubiquity_Message
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: Apple_PubSub_Socket_Render=/tmp/launch-1aJlsG/Render
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: COMMAND_MODE=unix2003
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Env: __CF_USER_TEXT_ENCODING=0x1F5:0:0
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: U{censored} Mac App Store Mountain Lion Installation Log
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Opened from: /Users/minhhikari/Desktop/U{censored}_Fixed.pkg
Apr 15 21:42:49 Minhs-Mac.local Installer[735]: Product archive /Users/minhhikari/Desktop/U{censored}_Fixed.pkg trustLevel=100
Apr 15 21:42:56 Minhs-Mac.local Installer[735]: InstallerStatusNotifications plugin loaded
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: ================================================================================
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: User picked Custom Install
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: Choices selected for installation:
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: Install: "U{censored} Mac App Store Mountain Lion"
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: U{censored}_Fixed.pkg#dsmos.pkg : com.{censored}.U{censored}-ML.U{censored}.pkg : 1.0
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: U{censored}_Fixed.pkg#v111.pkg : com.{censored}.U{censored}-ML.Chimera.pkg : 1.0
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: U{censored}_Fixed.pkg#extra.pkg : com.{censored}.U{censored}-ML.Extra.pkg : 1.0
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: Install: "Legacy USB Support"
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: U{censored}_Fixed.pkg#usb.pkg : com.{censored}.U{censored}-ML.LegacyUSB.pkg : 1.0
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: Install: "Laptop Support"
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: U{censored}_Fixed.pkg#extra-1.pkg : com.{censored}.U{censored}-ML.Lapptop.pkg : 1.0
Apr 15 21:43:00 Minhs-Mac.local Installer[735]: It took 0.00 seconds to summarize the package selections.
Apr 15 21:43:05 Minhs-Mac.local runner[739]: Administrator authorization granted.
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: ================================================================================
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: User picked Standard Install
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Choices selected for installation:
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Install: "U{censored} Mac App Store Mountain Lion"
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: U{censored}_Fixed.pkg#dsmos.pkg : com.{censored}.U{censored}-ML.U{censored}.pkg : 1.0
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: U{censored}_Fixed.pkg#v111.pkg : com.{censored}.U{censored}-ML.Chimera.pkg : 1.0
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: U{censored}_Fixed.pkg#extra.pkg : com.{censored}.U{censored}-ML.Extra.pkg : 1.0
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Install: "Legacy USB Support"
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: U{censored}_Fixed.pkg#usb.pkg : com.{censored}.U{censored}-ML.LegacyUSB.pkg : 1.0
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Install: "Laptop Support"
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: U{censored}_Fixed.pkg#extra-1.pkg : com.{censored}.U{censored}-ML.Lapptop.pkg : 1.0
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: It took 0.00 seconds to summarize the package selections.
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: -[iFDInstallController(Private) _buildInstallPlan]: location = file://localhost
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: -[iFDInstallController(Private) _buildInstallPlan]: file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#dsmos.pkg
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: -[iFDInstallController(Private) _buildInstallPlan]: file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#v111.pkg
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: -[iFDInstallController(Private) _buildInstallPlan]: file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#extra.pkg
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: -[iFDInstallController(Private) _buildInstallPlan]: file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#usb.pkg
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: -[iFDInstallController(Private) _buildInstallPlan]: file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#extra-1.pkg
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Set authorization level to root for session
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Will use PK session
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Starting installation:
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Configuring volume "MACOSXINS"
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Preparing disk for local booted install.
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Free space on "MACOSXINS": 7.93 GB (7929380864 bytes).
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Create temporary directory "/var/folders/ss/y5tnlg0x0gq5cmqh3b42tqv80000gn/T//Install.7351M5G4n"
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: IFPKInstallElement (5 packages)
Apr 15 21:43:05 Minhs-Mac.local Installer[735]: Using authorization level of root for IFPKInstallElement
Apr 15 21:43:05 Minhs-Mac.local installd[742]: installd: Starting
Apr 15 21:43:05 Minhs-Mac.local installd[742]: installd: uid=0, euid=0
Apr 15 21:43:06 Minhs-Mac.local installd[742]: PackageKit: ----- Begin install -----
Apr 15 21:43:06 Minhs-Mac.local installd[742]: PackageKit: request=PKInstallRequest <5 packages, destination=/Volumes/MACOSXINS>
Apr 15 21:43:06 Minhs-Mac.local installd[742]: PackageKit: packages=(
"PKLeopardPackage <file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#dsmos.pkg>",
"PKLeopardPackage <file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#v111.pkg>",
"PKLeopardPackage <file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#extra.pkg>",
"PKLeopardPackage <file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#usb.pkg>",
"PKLeopardPackage <file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#extra-1.pkg>"
Apr 15 21:43:06 Minhs-Mac.local installd[742]: PackageKit: Extracting file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#dsmos.pkg (destination=/Volumes/MACOSXINS/.PKInstallSandboxManager/1.sandbox/Root/tmp, uid=0)
Apr 15 21:43:06 Minhs-Mac.local installd[742]: PackageKit: Extracting file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#v111.pkg (destination=/Volumes/MACOSXINS/.PKInstallSandboxManager/1.sandbox/Root, uid=0)
Apr 15 21:43:06 Minhs-Mac.local installd[742]: PackageKit: Extracting file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#extra.pkg (destination=/Volumes/MACOSXINS/.PKInstallSandboxManager/1.sandbox/Root, uid=0)
Apr 15 21:43:18 Minhs-Mac.local installd[742]: PackageKit: Extracting file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#usb.pkg (destination=/Volumes/MACOSXINS/.PKInstallSandboxManager/1.sandbox/Root/Extra/Extensions, uid=0)
Apr 15 21:43:27 Minhs-Mac.local installd[742]: PackageKit: Extracting file://localhost/Users/minhhikari/Desktop/U{censored}_Fixed.pkg#extra-1.pkg (destination=/Volumes/MACOSXINS/.PKInstallSandboxManager/1.sandbox/Root/Extra, uid=0)
Apr 15 21:43:28 Minhs-Mac.local installd[742]: PackageKit: prevent user idle system sleep
Apr 15 21:43:28 Minhs-Mac.local installd[742]: PackageKit: suspending backupd
Apr 15 21:43:28 Minhs-Mac.local installd[742]: PackageKit: Executing script "./preinstall" in /private/tmp/PKInstallSandbox.3MW3Fd/Scripts/com.{censored}.U{censored}-ML.U{censored}.pkg.oPKAkX
Apr 15 21:43:28 Minhs-Mac.local installd[742]: ./preinstall: U{censored} Phase 1 of 7 Starting
Apr 15 21:43:45 Minhs-Mac.local installd[742]: ./preinstall: U{censored} Phase 2 of 7 Starting
Apr 16 01:38:01 Minhs-Mac.local UserEventAgent[11]: SUNotificationPlugin[uid=0]: trigger from periodic
Apr 16 01:38:03 Minhs-Mac.local Software Update[1174]: SoftwareUpdateCheck: checking for updates
Apr 16 01:38:03 Minhs-Mac.local Software Update[1174]: SoftwareUpdate: Scan for client pid 1174 (/System/Library/CoreServices/Software Update.app/Contents/Resources/SoftwareUpdateCheck)
Apr 16 01:38:03 Minhs-Mac.local UserEventAgent[109]: SUNotificationPlugin[uid=501]: trigger from periodic
Apr 16 01:38:03 Minhs-Mac.local Software Update[1174]: SUCheckService: acquired a peer (current trigger: SUCheckServiceTriggerTypePeriodic)
Apr 16 01:40:03 Minhs-Mac.local Software Update[1174]: SoftwareUpdate: Error encountered in scan: Error Domain=NSURLErrorDomain Code=-1001 "The request timed out." UserInfo=0x7f947144b5d0 {NSUnderlyingError=0x7f9472617380 "The request timed out.", NSErrorFailingURLStringKey=https://swscan.apple.com/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog, NSErrorFailingURLKey=https://swscan.apple.com/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog, NSLocalizedDescription=The request timed out.}
Apr 16 01:40:03 Minhs-Mac.local Software Update[1174]: The request timed out.
Apr 16 01:40:03 Minhs-Mac.local Software Update[1174]: SUCheckService: sending result 3 to peer
Apr 16 01:40:03 Minhs-Mac.local UserEventAgent[109]: SUNotificationPlugin[uid=501]: check done with result SUCheckServiceResultCheckFailed
Apr 16 01:40:03 Minhs-Mac.local UserEventAgent[11]: SUNotificationPlugin[uid=0]: check done with result SUCheckServiceResultCheckFailed
Apr 16 01:40:03 Minhs-Mac.local UserEventAgent[11]: SUNotificationPlugin[uid=0]: Not notifying appstoreupdateagent for user 0
Apr 16 01:40:03 Minhs-Mac.local UserEventAgent[109]: SUNotificationPlugin[uid=501]: Not notifying appstoreupdateagent for user 501
Apr 16 01:40:03 Minhs-Mac.local Software Update[1174]: SUCheckService: okay to stop (did timeout=0)
Apr 16 05:38:01 Minhs-Mac.local UserEventAgent[11]: SUNotificationPlugin[uid=0]: trigger from periodic
Apr 16 05:38:03 Minhs-Mac.local Software Update[1584]: SoftwareUpdateCheck: checking for updates
Apr 16 05:38:03 Minhs-Mac.local Software Update[1584]: SoftwareUpdate: Scan for client pid 1584 (/System/Library/CoreServices/Software Update.app/Contents/Resources/SoftwareUpdateCheck)
Apr 16 05:38:03 Minhs-Mac.local UserEventAgent[109]: SUNotificationPlugin[uid=501]: trigger from periodic
Apr 16 05:38:03 Minhs-Mac.local Software Update[1584]: SUCheckService: acquired a peer (current trigger: SUCheckServiceTriggerTypePeriodic)
Apr 16 05:40:03 Minhs-Mac.local Software Update[1584]: SoftwareUpdate: Error encountered in scan: Error Domain=NSURLErrorDomain Code=-1001 "The request timed out." UserInfo=0x7fd1eb81b1c0 {NSUnderlyingError=0x7fd1e9c29500 "The request timed out.", NSErrorFailingURLStringKey=https://swscan.apple.com/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog, NSErrorFailingURLKey=https://swscan.apple.com/content/catalogs/others/index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog, NSLocalizedDescription=The request timed out.}
Apr 16 05:40:03 Minhs-Mac.local Software Update[1584]: The request timed out.
Apr 16 05:40:03 Minhs-Mac.local Software Update[1584]: SUCheckService: sending result 3 to peer
Apr 16 05:40:03 Minhs-Mac.local UserEventAgent[109]: SUNotificationPlugin[uid=501]: check done with result SUCheckServiceResultCheckFailed
Apr 16 05:40:03 Minhs-Mac.local UserEventAgent[109]: SUNotificationPlugin[uid=501]: Not notifying appstoreupdateagent for user 501
Apr 16 05:40:03 Minhs-Mac.local UserEventAgent[11]: SUNotificationPlugin[uid=0]: check done with result SUCheckServiceResultCheckFailed
Apr 16 05:40:03 Minhs-Mac.local UserEventAgent[11]: SUNotificationPlugin[uid=0]: Not notifying appstoreupdateagent for user 0
Apr 16 05:40:03 Minhs-Mac.local Software Update[1584]: SUCheckService: okay to stop (did timeout=0)
Edited by rockmanexe1994
