I am working on the DSDT (and trying to patch) as this *should* fix the ethernet and USB issues (it has for me in the past). However, a caveat of this is that everyone will need to make their own (it's not tooo difficult) as it is specific to the bios (HP curse you) and graphics cards.
However, I think we might be ok if we are disabling the nvidia cards (since optimus WONT work on these laptops). Currently I am backing up my OS (windows 8, yes I have a start menu, haven't seen teh start screen for 3 months (since install).) and then I'll be trying to install OSX 10.8.3 (lets aim high here).
WIth the LAPIC (spell?) does imessage/ichat/facetime/whatever work?
Thanks,
AJ
The lapic will fix the cpus=1 for sure, but iMessage seems to be something with the registration and serial codes, iMessage is fixen in the new Chameleon, chimera and clover bootloaders, so with one of those it should work, without it wont.
Ok, thats good to hear. Im having some issues with 10.8.3 not seeing my hdd's. working on fixing this and im getting close but i might be doing something wrong.
I am also extracting my dsdt today and i will be seeing how much that fixes. In addition, has anyone tried the applehda for idt thats posted here?
i want to buy a laptop that i can hackintosh on i found a HP pavilion g6 here is its specs
Barcode (GTIN)887758185919
Product TypeLaptops
BrandHP
ModelD5F56PA
Perfect ForEveryday
ColourWhite
Processor
Processor BrandIntel
Processor TypeCore i3
Processor Model3120M
Processor Speed (GHz)2.50
Memory
Installed RAM4GB
RAM Configuration1 x 4GB
RAM Expandable To (GB)8
RAM TypeDDR3
Cache Memory Size (M)3
Disk Drives
Hard Drive Size500GB
Hard Drive TypeSATA
Hard Drive Speed (RPM)5400
Digital Media Cards ReaderMMC, SD Memory Card, SDHC, SDXC
Optical Drive TypeDVD Super Multi
Optical Drive Speed8 x
Optical Drive FormatDual Layer Support, DVD+R, DVD+RW, DVD-R, DVD-RW
Screen
Screen Size15.6"
Screen TypeLED LCD
Screen DefinitionHigh Definition
Screen Resolution1366 x 768
Graphics & Video Support
Graphics Card BrandIntel
Graphics Card TypeHD Graphics 4000
Graphics Card Memory TypeShared
Audio
MicrophoneIntegrated
SpeakersAltec Lansing Speakers
Networking & Internet
Wireless NetworkingIEEE 802.11b, IEEE 802.11g, IEEE 802.11n
NetworkingEthernet 10/100
Power
Battery TypeLithium Ion
Connections and Expansion
Audio PortsHeadphone Jack, Microphone Jack
USB Ports2
Video PortsHDMI, VGA
Software
Operating SystemWindows 8
Dimensions
Product Width (cm)37.6
Product Depth (cm)24.4
Product Height (cm)3.6
Manufacturers Warranty
Manufacturers Express Warranty (months)12
will it work to put mountain lion on it?
It should, keyword being should. Therewll probably be an issue with it and detecting the hdd, if i (or smeone) can find the kexts for it i will sendthem to you.
Thanks,
AJ
Indeed we might have to make our own anyway, but maybe we should all consider updating to the latest bios for simplicity. I think it's F.23 if I'm not mistaken. I haven't noted any changes or problems with it since I updated from my older one. I guess that's up to the user, though personally I don't see something not working between bios revisions.
Also AJ, it's good to have you back. I'm sorry about what happened--I had an ex gf go through a similar circumstance...it was rough. For the record, I can boot with zero flags and so far, zero KPs. I used david's guide. I wasn't able to boot 10.8.3 after a clean install (which installed without issues, but couldn't boot), however you might have better luck.
Edited by montag
