Yeah,
F.24 is buggy and F.26 fixes a bunch of issues. F.24's bugs are more if you have an ssd. F.26 is safe though.
I am upgrading to it now. I suggest everyone else does then. Good deal gsavoldi, thank AJ for the bios info. I would start with removing the geforce kexts like in the guide.
I finally got my system up and running again in os x 10.8.3, now I am going to work on some things and update the guide. Weird is that now multi touch just works without me needing to install a kext.
what guide do you mean? links?
what should i do get my geforce working?
Edited by gsavoldi
The guide that I made, which will give you the tested and working system until now. http://www.osx86.net/notebooks/21947-guide-hp-dv6-7000-a.html
You will not be able to get the GeForce working until HP brings out their new BIOS which gives us the option to turn off one of the graphics cards. But since we don't know when they will do this we will have to settle with the HD4000. The guide will tell you how to get that working. But you will need to delete the 4 GeForce kexts otherwise nothing will work.
David
@David does the audio work now or does it still give KPs? I noticed it looks like you're recommending a different audio kext in the guide.
Yes the audio works with VooDooHDA, but it could be better. I am thinking of making a custom patch for our audio so the subwoofer also works. I don't know if and when I will do this but until that time VooDooHDA will work.
