The wireless card is the Broadcom BCM94322HM8L, you should be able to find it on ebay. It is strange that you need -x, it ight be that kext you used but the screenshot you sent doesn't seem to have a problem, at that stage it sometimes takes some time, but as it is checking the drive there. At the moment I don't know what would be causing that, it might be that kext but as you are not the only one using that kext I hope that isn't the problem. You could look at the page you downloaded it and see if other people are having problems with the kext, or you could just try another kext straight away. Hope you solve your problem soon. If you could keep me up to date with your work that would be great.
David
Last I heard Aj was working in it as he already had it working once.
That's what I thought. I guess I will hold off until I hear back from him.
So im free for the summer and gonna get back into getting this thing fully working, im looking to get that wireless card you mentioned (the BCM94322HM8L), however on the ebay page it specifically states that it isnt for hp laptops due to bios whitelisting! any ideas why? BroadCom BCM94322HM8L BCM4322 Half Size Mini PCI-E 802.11 a/b/g/n WLAN Card W001 | eBay
