macnoob
Mountain Lion HD5650 won´t work.. . :(
Hello,
After my laptop with 10.7.3 Lion yes to sleep on clean runs, I try to install the Mountain Lion. The installation runs smoothly by U{censored}. But now listen. Once I "Chameleon 2034" install I get a black screen source or it hangs when booting. wowevent ... = 2 (1) ....
I unfortunately do not get the graphics card (5650) .. to run! When booting, it is properly recognized by OSX / Chameleon, but OSX itself .. 3 MB graphics card .. : (
Camera videos and run!
I hope you can help me :)
LG
Hey,
I've edited the AMDRadeonAccelerator.kext and ATI5000Controller. You must be wherever the <key> IOPCIMatch </ key> enter your 0x68C11002 in the string! In addition, I use a modified EDID.
The Chameleon WIzard you must still have the framebuffer enabled .. "Hoolock" in my case. I think to you too, because we have the same ID "0x68C11002" have.
Hope i could help.
LG
5650m
How did you manage to get it work?
When i want to edit the AMDRadeonAccelerator.kext i only see that my ID already exists -> 0x68C11002 (Well there are many IOPCIMatch, but in the Redwood family i found my entry)
Are you using ATI5000Injector.kext.zip
Install with Kext Utility
and GraphicsEnabler=Yes
Type in terminal:
kextstat | grep ATI
These must be loaded:
ATIxxxxController (kext for the graphics controller)
ATISupport (kext responsible for supporting the ATI in mac os x)
ATIRadeonXxxxx (kext responsible for graphics acceleration in Lion)
For Mountain Lion:
AMDRadeonAccelerator.kext which will replace the ATIRadeonx3000
Edited by Rene
well i tried to fix it with the EDID thing, but it didn't change anything.
The resolution is low anyway and QEQI isn't working too.
Is the ATI5000Injector.kext necessary for running the 5650m?
This was the easiest way for me to get my 5450 working, just try it :)
Still not working for me :S
i edited the AMDRadeonAccelerator.kext (the info.plist inside the kext) adding 0x68c11002 to every instance on IOPCIMatch fixed permissions, then added the ATI5000injector.kext availble on this thread to S/L/E and fixed permissions once again, i also edited the org.chameleon.boot.plist and added the GraphicsEnabler=yes and Hoolock on the profiles, then replaced the 717 force edid file on the displays folder, but QE/CI is still not working :(
anything else i should do that i am missing?
