macnoob
Mountain Lion HD5650 won´t work.. . :(
Hello,
After my laptop with 10.7.3 Lion yes to sleep on clean runs, I try to install the Mountain Lion. The installation runs smoothly by U{censored}. But now listen. Once I "Chameleon 2034" install I get a black screen source or it hangs when booting. wowevent ... = 2 (1) ....
I unfortunately do not get the graphics card (5650) .. to run! When booting, it is properly recognized by OSX / Chameleon, but OSX itself .. 3 MB graphics card .. : (
Camera videos and run!
I hope you can help me :)
LG
Hello guys, I have same black screen problem.
I install iAtkos ML 10.8.2, If i use a external monitor it works with no problem bu identifed as HD 5750M. On the other hand if i try to use laptop display i got black screen than i type PciRoot=1 there is no problem for working screen however this time vga has identified as 3mb standart vga with no acc. So what's wrong or where i am wrong? Also , i tried to edid display ID, Framebuffer was Hoolock and graphicsEnabler=Yes.
17.3'' Display on laptop with 1600x900 res.
Hi. I have some problems with my graphics too..
I have a Hd5650 0x68c1 1002.
I had OSx 10.8.3 fully working QE_CI 1366x768 .
I accidentaly update my OSx to 10.8.4. (12E55) Now the system reconize my Graphic but i don't have full QE_CI support. Somebody know what do i have to do?
Thanks in advance.
This is very strange. Your Device Id 0x68c1 is in 10.8.3 kext but also in the 10.8.4 kexts.
Type in terminal:
kextstat | grep ATI
Output should be:
ATIxxxxController (kext for the graphics controller)
ATISupport (kext responsible for supporting the ATI in mac os x)
Type in terminal:
kextstat | grep AMD
Output should be:
AMDRadeonAccelerator (kext responsible for graphics acceleration)
Thanks for your reply Rene.
On grep ATI, nothing appears
On grep AMD the output is:
com.apple.kext.AMDSupport
com.apple.kext.AMD5000Controller
com.apple.kext.AMDFramebuffer
what should i do.
Thank you.
So only "AMDRadeonAccelerator.kext" doesn't load. Can't tell way because the Device ID is in it????
Are you using GraphicsEnabler=yes?
Which framebuffer? You can try Eulemur and Hoolock.
Maybe you can run myFix from myHack and run a Full fix.
How did you install and what hardware do you have? If you want help it's better to make a signature.
Edited by Rene
