macnoob
Mountain Lion HD5650 won´t work.. . :(
Hello,
After my laptop with 10.7.3 Lion yes to sleep on clean runs, I try to install the Mountain Lion. The installation runs smoothly by U{censored}. But now listen. Once I "Chameleon 2034" install I get a black screen source or it hangs when booting. wowevent ... = 2 (1) ....
I unfortunately do not get the graphics card (5650) .. to run! When booting, it is properly recognized by OSX / Chameleon, but OSX itself .. 3 MB graphics card .. : (
Camera videos and run!
I hope you can help me :)
LG
For Audio
olarila.com ? View topic - AppleHDA
if your audio device is 8086:3b56 this is the kext that you need BUT: It only work the audio and mic. the headphone plug and the volume control doesn't work. http://www.osx86.net/view/2509-voodoohda_2.7.3_installer_for_10.6-10.7-10.8.html
For ATI 5650 - I used
Fixing Scrambled,Stretched, or Wrong Resolution Laptop Display Problems - Intel - InsanelyMac Forum
If you have the same problem as me.
My problem was that the iOS doesn't reconized my screen, only the graphic card. I have to install SwitchResX to work properly. and set the resolution with an HDMI or an external monitor in order to work.
good luck.
Hi arthurmasiero, I have done a installation with only the DisplayProductID-717 edited, but I'm still having com.apple.iokit.IOAcceleratorFamily not found, same the photo:
The System information show the name of Graphic Card, but no info about memory. Using 4MB yet
What bootloader are you using? Can you send the link?
thanks
Edited by edipo2s
Very Strange..
I use Chameleon bootloader. witch one do you use.
In your bootloader, did you change the configuration?
You have to set Graphics enabler = Yes
and ATI Config= Baboon
Type in terminal:
kextstat | grep ATI
Output should be:
ATIxxxxController (kext for the graphics controller)
ATISupport (kext responsible for supporting the ATI in mac os x)
Type in terminal:
kextstat | grep AMD
Output should be:
AMDRadeonAccelerator (kext responsible for graphics acceleration)
Tell me what do you see.
Edited by arthurmasiero
Yes, I'm using GraphicEnabler and AtiConfig=Baboon.
The screenshot show you the Graphic Card without VRAM and kextstat result
https://dl.dropboxusercontent.com/u/18542301/Screenshots/Captura%20de%20Tela%202013-08-08%20%C3%A0s%2020.04.28.png
bdmensg:
Chameleon 2.2svn (svn-r2248) [2013-06-20 04:16:43]
11.0
CPU: Brand String: AMD Phenom II N970 Quad-Core Processor
CPU: Vendor/Family/ExtFamily: 0x68747541/0xf/0x1
CPU: Model/ExtModel/Stepping: 0x5/0x0/0x3
CPU: MaxCoef/CurrCoef: 0xf/0x16
CPU: MaxDiv/CurrDiv: 0x0/0x2
CPU: TSCFreq: 2194MHz
CPU: FSBFreq: 199MHz
CPU: CPUFreq: 2194MHz
CPU: NoCores/NoThreads: 4/4
CPU: Features: 0x0000024f
Read HFS+ file: [hd(0,5)/System/Library/CoreServices/SystemVersion.plist] 478 bytes.
Read HFS+ file: [hd(0,5)/Extra/org.chameleon.Boot.plist] 597 bytes.
Module 'Symbols.dylib' by 'Chameleon' Loaded.
Description: Chameleon symbols for linking
Version: 0
Compat: 0
Read HFS+ file: [hd(0,5)/Extra/modules/ACPICodec.dylib] 86768 bytes.
Module 'ACPICodec.dylib' by 'Unknown' Loaded.
Description:
Version: 0
Compat: 0
Read HFS+ file: [hd(0,5)/Extra/modules/FileNVRAM.dylib] 56136 bytes.
Module 'FileNVRAM.dylib' by 'Unknown' Loaded.
Description:
Version: 0
Compat: 0
Read HFS+ file: [hd(0,5)/Extra/modules/HDAEnabler.dylib] 22196 bytes.
Module 'HDAEnabler.dylib' by 'Unknown' Loaded.
Description:
Version: 0
Compat: 0
Read HFS+ file: [hd(0,5)/Extra/modules/KernelPatcher.dylib] 31272 bytes.
Module 'KernelPatcher.dylib' by 'Unknown' Loaded.
Description:
Version: 0
Compat: 0
Read HFS+ file: [hd(0,5)/Extra/modules/klibc.dylib] 44260 bytes.
Module 'klibc.dylib' by 'Unknown' Loaded.
Description:
Version: 0
Compat: 0
Read HFS+ file: [hd(0,5)/Extra/modules/Resolution.dylib] 26528 bytes.
Module 'Resolution.dylib' by 'Unknown' Loaded.
Description:
Version: 0
Compat: 0
Resolution:
Unknown chipset type: 96011022.
Read HFS+ file: [hd(0,5)/Extra/modules/Sata.dylib] 12980 bytes.
Module 'Sata.dylib' by 'Unknown' Loaded.
Description:
Version: 0
Compat: 0
Read HFS+ file: [hd(0,5)/Extra/modules/uClibcxx.dylib] 85200 bytes.
Module 'uClibcxx.dylib' by 'Unknown' Loaded.
Description:
Version: 0
Compat: 0Loading Darwin 10.8
Loading kernel /mach_kernel
Read HFS+ file: [hd(0,5)/mach_kernel] 4096 bytes.
Read HFS+ file: [hd(0,5)/mach_kernel] 10223824 bytes.
kernel_patcher.c[534]: Patching 64bit XNU Kernel 12.3.0
Darwin Kernel Version 12.3.0: –≤—Ç–æ—Ä–Ω–??–∫, 25 –??—é–Ω—è 2013 –≥. 20:52:16 (MSK); *patched-2050.22.13_amd/BUILD/obj//RELEASE_X86_64
cpuid_patch.c[52]: Attempting to patch 64bit kernel for unknown cpu
cpuid_patch.c[115]: Panic call removed.
commpage_patch.c[87]: _commpage_stuff_routine patched.
lapic_patch.c[76]: lapic_init panic removed.
bootstrap_patch.c[167]: KLDBootstrap::readBooterExtensions() call injected into KLDBootstrap::readPrelinkedExtensions(void* section_64)
ACPI table not found: DSDT.aml
No DSDT found, using 0 as uid value.
Using PCI-Root-UID value: 0
Unsupported ATI card! Device ID: [1002:9712] Subsystem ID: [103c:1440]
Framebuffer @0xE0000000 MMIO @0xF0200000 I/O Port @0x00003000 ROM Addr @0x00000000
ATI card POSTed, reading Video BIOS from legacy space
(AtiConfig) Framebuffer set to: Baboon
# of ports set to framebuffer's default: 3
ATI Redwood AMD Radeon HD 6500M/5600/5700 Series 4095MB (Baboon) [1002:68c1] (subsys [103c:1440]):: PciRoot(0x0)/Pci(0x2,0x0)/Pci(0x0,0x0)
===== AUDIO DEVICE INFO ====
Audio controller found! Start Injection
Class code: [0403]
Model name: ATI RV830 HDA Controller (HDMi) [1002:aa60] (rev 00)
Subsystem: [103c:1440]
PciRoot(0x0)/Pci(0x2,0x0)/Pci(0x0,0x1)
device number: 2
=== END AUDIO DEVICE INFO ==
SATA device : [1002:4391 :: 0106], changed to ICH6 ESB2
Class code: [0403]
Model name: ATI SB600 HDA Controller (HDMi) [1002:4383] (rev 40)
PciRoot(0x0)/Pci(0x14,0x2)
device number: 3
No SMBIOS replacement found.
Try to disable your onboard GPU in your BIOS:
GPU On-Board: ATI Mobility Radeon HD 4200 (RS880M)
