antoniodapc
SpeedStep and Turbo Boost as The Turn-On of Hackintosh Mountain Lion
I wish I could figure out how to implement these two functions on my Hakintosh ( Samsung Rc 530 S06 Core I 5 2450 )
I tried to read the FAQ but honestly I knew very little about how exactly to do.
I Give A Hand?
I wish to figure out how to implement these two functions
Sorry, I'm clueless with VoodooMonitor. Are the info keep changing in realtime?
Anyway, I'm using MSRDumper and HWMonitor to check/monitor my P-States. Do you use custom SSDT or just let Chameleon generates the P-States?
First, you can check the P-States data (based on PSS in your custom SSDT or stock ACPI tables) through ioreg (AppleACPIPlatformExpert/CPU0@0/AppleACPICPU/ACPI_SMC_PlatformPlugin > PerformanceStateArray). Yet it doesn't mean your speedstepper is working. It only shows available states do you have. You can use Terminal also;
ioreg -lw0 | grep PerformanceStateArray
Then load MSRDumper.kext through Terminal and open Console to see your P-States. Stress your CPU for few minutes. It works when you can see more than 2 multipliers/states in Console.
[ADD INFO]
Here is how to read the data in PerfomanceStateArray. The first entry should be your highest state (max frequency in Mhz). For i5-2450m (obviously like mine), it's up to 3100Mhz (Turbo). Don't bother to that long number. Just look at the first 4, e.g;
<[COLOR="#0000CD"]1c[/COLOR][COLOR="#FF0000"]0c[/COLOR]0000000000000a0000000a000000001f0000001f0000>
1c0c => Read red first then blue. Use calculator app to convert hex to decimal.
Edited by fau7i
Add Info
