antoniodapc
SpeedStep and Turbo Boost as The Turn-On of Hackintosh Mountain Lion
I wish I could figure out how to implement these two functions on my Hakintosh ( Samsung Rc 530 S06 Core I 5 2450 )
I tried to read the FAQ but honestly I knew very little about how exactly to do.
I Give A Hand?
I wish to figure out how to implement these two functions
This Is MB{censored}Option
customization // ssdt option/ ssdt SanBridge I5 3.8 Ghz.
I Suggested to set chameleon with Generate PState & CState = Yes
Edited by antoniodapc
Check back post #15, hope you will know where to start before applying those options.
Nothing wrong with SSDT from that beast. It's universal for sandy bridge i5. Meaning that it's a custom SSDT. So most likely you need DropSSDT=Yes in your boot.plist (Remove GeneratePStates and CStates).
Test and tell the result here...:encouragement:
Most of the times you require a correct version of patched kext. Because Apple frequently updates this kext (not happened in ML yet). Use MB{censored} is your shortcut to get already patched versions.
To enable speedstepper, there are few steps you may or may not apply, btw remove nullcpupm is a must.
1. Without SSDT, just use GeneratePStates=Yes in boot.plist. It will use your stock ACPI table.
2. With custom SSDT, use DropSSDT=Yes. It will relocate the ACPI table to point to the custom one in /Extra.
3. Review your DSDT if you have used it to macth with your custom DSDT especially your CPU identifiers.
Good luck
is It correct ?
<key>GeneratePStates</key>
<string>No</string>
<key>GenerateCStates</key>
<string>No</string
<key>DroppSSDT</key>
<string>Yes</string
