rd77
[SOLVED] Need help getting QE CI working with ML
Hello!
I have 4 graphic cards:
NVidia 8600 GT
ATI HD 4850,
ATI HD 4650,
ATI HD 4670.
None of them working fully with QE and CI.
With NVidia and GraphicsEnabler=YES I can boot and work, but no QE. And I can't change screen resolution, even with SwitchResX. Here is System info at monitors section
ATI cards with GraphicsEnabler=YES -v don't show graphics at all. I still see verbose logging of kernel and kexts, I can listen sounds when touch volume+/- keys on my keyboard, but can't see my desktop. Without GraphicsEnabler, I got kernel panic.
Last two weeks I've searched for a solution and tried a lot of ones, but can't get anything.
Please, help me!
Mountain Lion 10.8.2 12C54
Edited by rd77
mark solved
For the ATI HD4850 you can try: http://www.osx86.net/view/3229-qe_ci_exotic_patch_mountain_lion_10.8.2.html
Worked for my ASUS HD4850 very well. Keep in mind that there is for each OS X a separate version.
And always use only ONE method at a time.
Don't use SwitchResX. Your 8600 GT should work without it.
And try to use the DVI port not the VGA.
If you get a black screen try for the 8600 GT to use the "NVDANV50Hal.kext" from DP4:
http://www.osx86.net/10-8-mountain-lion/17287-not-work-qe-ci-mountain-lion-gm-nvidia-geforce-8400-gs-512mb-help.html#post114286
Edited by Rene
I'm sorry, I forget to say important thing: my monitor has no DVI port, so I had to use DVI->VGA adapter.
No, I did not get black screen with NVidia 8600GT. It working without QE. Anyway, I tried to use NVDANV50Hal as you say and nothing is changed (except ROM revision now netkas). Still no QE. Image 2012.11.14 11:16:50.png
Also I tried to use exotic patch with ATI 4850 and only effect is that I get white screen after booting (maybe light gray, like around apple logo during boot). Can't see my desktop again.
After some reboots ROM revision not netkas again..
Something is basically wrong.
Is there any way to check if I'm using only one method? Ok, I tried to say GraphicsEnabler=No in Chameleon, I removed efi string from chameleon plist, anything else?
My system configuration is running without DSDT, do I need it?
Edited by Rene
Show your signature
DVI>VGA is fine :)
Because the ROM revision changed after trying another NVDANV50Hal I think you are using more than one method.
In "Terminal" type:
kextstat
now you can see what kexts are loaded.
Maybe it's better to make a new install on a new or empty disk.
What hardware do you have? Can you make a signature, would help a lot.
My favourite install method is myHack.
Start with the 8600GT with only GraphicsEnabler=Yes.
Always boot with bootflag:
-v
This way you can see what's happening and what errors occurs.
A DSDT is not always needed. This way you need more kexts to install to get things running. But lets wait for you to give us the hardware specs to continue.
I have Gigabyte GA-Z68X-UD3-B3 motherboard, Intel i3-2105 processor. Graphic cards are listed in first post.
Here is kextstat output with NVidia. (also I can't fine MORE tag in this forum so I put it just as is)
Mac1:~ rd$ kextstat
Index Refs Address Size Wired Name (Version) <Linked Against>
1 56 0xffffff80d10b3000 0x686c 0x686c com.apple.kpi.bsd (12.2.0)
2 6 0xffffff80111de800 0x46c 0x46c com.apple.kpi.dsep (12.2.0)
3 81 0xffffff80d10cf000 0x1b7ec 0x1b7ec com.apple.kpi.iokit (12.2.0)
4 87 0xffffff80d10eb000 0x99f8 0x99f8 com.apple.kpi.libkern (12.2.0)
5 75 0xffffff80111ed000 0x88c 0x88c com.apple.kpi.mach (12.2.0)
6 33 0xffffff80d10f5000 0x500c 0x500c com.apple.kpi.private (12.2.0)
7 51 0xffffff80d10ba000 0x23cc 0x23cc com.apple.kpi.unsupported (12.2.0)
8 0 0xffffff7f80741000 0x41000 0x41000 com.apple.kec.corecrypto (1.0) <7 6 5 4 3 1>
9 16 0xffffff7f80782000 0x7000 0x7000 com.apple.iokit.IOACPIFamily (1.4) <7 6 4 3>
10 23 0xffffff7f80789000 0x24000 0x24000 com.apple.iokit.IOPCIFamily (2.7.1) <7 6 5 4 3>
11 1 0xffffff7f807ad000 0x57000 0x57000 com.apple.driver.AppleACPIPlatform (1.6) <10 9 7 6 5 4 3 1>
12 0 0xffffff7f80804000 0x2000 0x2000 org.tgwbd.driver.NullCPUPowerManagement (1.0.0d2) <7 4 3>
13 0 0xffffff7f80808000 0x29000 0x29000 com.apple.driver.AppleIntelCPUPowerManagement (196.0.0) <7 6 5 4 3 1>
14 1 0xffffff7f80832000 0xc000 0xc000 com.apple.driver.AppleKeyStore (28.21) <7 6 5 4 3 1>
15 3 0xffffff7f8083e000 0x25000 0x25000 com.apple.iokit.IOStorageFamily (1.8) <7 6 5 4 3 1>
16 0 0xffffff7f80863000 0x18000 0x18000 com.apple.driver.DiskImages (344) <15 7 6 5 4 3 1>
17 0 0xffffff7f8087b000 0x8000 0x8000 com.apple.nke.applicationfirewall (4.0.39) <7 6 5 4 3 1>
18 2 0xffffff7f80885000 0x4000 0x4000 com.apple.kext.AppleMatch (1.0.0d1) <4 1>
19 1 0xffffff7f80889000 0x11000 0x11000 com.apple.security.sandbox (220) <18 7 6 5 4 3 2 1>
20 0 0xffffff7f8089a000 0x6000 0x6000 com.apple.security.quarantine (2) <19 18 7 6 5 4 2 1>
21 0 0xffffff7f808a1000 0x3000 0x3000 com.apple.security.TMSafetyNet (7) <7 6 5 4 2 1>
22 3 0xffffff7f808a4000 0xf000 0xf000 org.netkas.driver.FakeSMC (4.2.13) <9 7 5 4 3>
23 0 0xffffff7f808b3000 0x3000 0x3000 org.hwsensors.driver.CPUSensors (2.0.0) <22 7 5 4 3>
24 0 0xffffff7f808b8000 0x3000 0x3000 com.apple.driver.AppleAPIC (1.6) <4 3>
25 0 0xffffff7f808bc000 0x4000 0x4000 com.apple.driver.AppleSMBIOS (1.9) <7 4 3>
26 5 0xffffff7f808c1000 0x6c000 0x6c000 com.apple.iokit.IOHIDFamily (1.8.0) <14 7 6 5 4 3 2 1>
27 0 0xffffff7f8092d000 0x4000 0x4000 com.apple.driver.AppleACPIButtons (1.6) <26 11 9 7 6 5 4 3 1>
28 0 0xffffff7f80933000 0x8000 0x8000 com.apple.driver.AppleRTC (1.5) <9 5 4 3 1>
29 1 0xffffff7f8093d000 0x4000 0x4000 com.apple.driver.AppleEFIRuntime (1.6.1) <7 6 5 4 3>
30 8 0xffffff7f80941000 0x56000 0x56000 com.apple.iokit.IOUSBFamily (5.4.0) <10 7 5 4 3 1>
31 0 0xffffff7f80997000 0x18000 0x18000 com.apple.driver.AppleUSBEHCI (5.4.0) <30 10 7 5 4 3 1>
32 0 0xffffff7f809b7000 0x13000 0x13000 org.hwsensors.driver.MotherboardSensors (2.3.4) <22 10 7 5 4 3>
33 2 0xffffff7f809ca000 0x16000 0x16000 com.apple.iokit.IOAHCIFamily (2.2.1) <5 4 3 1>
34 0 0xffffff7f809e0000 0x19000 0x19000 com.apple.driver.AppleAHCIPort (2.4.1) <33 10 5 4 3 1>
36 0 0xffffff7f80a04000 0x3000 0x3000 com.apple.iokit.IOUSBUserClient (5.2.5) <30 7 5 4 3 1>
38 0 0xffffff7f80a27000 0x7000 0x7000 com.apple.driver.AppleEFINVRAM (1.6.1) <29 7 6 5 4 3>
39 0 0xffffff7f80a30000 0x15000 0x15000 com.apple.driver.AppleUSBHub (5.2.5) <30 5 4 3 1>
40 0 0xffffff7f80a45000 0xf000 0xf000 org.hwsensors.driver.GPUSensors (1.0.2) <22 10 7 5 4 3>
41 3 0xffffff7f80a54000 0x2b000 0x2b000 com.apple.iokit.IONetworkingFamily (3.0) <7 6 5 4 3 1>
42 0 0xffffff7f80a7f000 0x33000 0x33000 com.apple.driver.AppleRTL8169Ethernet (1.1.4a5) <41 10 5 4 3 1>
43 0 0xffffff7f809af000 0x3000 0x3000 com.apple.AppleFSCompression.AppleFSCompressionTypeDataless (1.0.0d1) <7 6 4 3 2 1>
44 2 0xffffff7f80ab2000 0x73000 0x73000 com.apple.iokit.IOFireWireFamily (4.5.5) <5 4 3 1>
45 0 0xffffff7f80b25000 0x27000 0x27000 com.apple.driver.AppleFWOHCI (4.9.6) <44 10 7 6 5 4 3 1>
46 0 0xffffff7f80b4c000 0x16000 0x16000 com.apple.iokit.IOAHCIBlockStorage (2.2.2) <33 15 6 5 4 3 1>
47 0 0xffffff7f809b2000 0x4000 0x4000 com.apple.AppleFSCompression.AppleFSCompressionTypeZlib (1.0.0d1) <6 4 3 2 1>
48 0 0xffffff7f80b62000 0x9000 0x9000 com.apple.BootCache (34) <7 6 5 4 3 1>
50 0 0xffffff7f809fb000 0x3000 0x3000 com.apple.driver.XsanFilter (404) <15 5 4 3 1>
51 0 0xffffff7f80a1f000 0x6000 0x6000 com.apple.driver.AppleUSBComposite (5.2.5) <30 4 3 1>
52 0 0xffffff7f80b6b000 0x8000 0x8000 com.apple.iokit.IOUSBHIDDriver (5.2.5) <30 26 5 4 3 1>
53 0 0xffffff7f80b73000 0x2a000 0x2a000 com.apple.iokit.IOSCSIArchitectureModelFamily (3.5.1) <5 4 3 1>
54 1 0xffffff7f80b9d000 0x5000 0x5000 com.apple.kext.triggers (1.0) <7 6 5 4 3 1>
55 0 0xffffff7f80ba2000 0x9000 0x9000 com.apple.filesystems.autofs (3.0) <54 7 6 5 4 3 1>
56 9 0xffffff7f80bab000 0x37000 0x37000 com.apple.iokit.IOGraphicsFamily (2.3.5) <10 7 5 4 3>
57 0 0xffffff7f80be2000 0x2e000 0x2e000 com.apple.driver.AppleIntelSNBGraphicsFB (8.0.0) <56 10 9 7 6 5 4 3 1>
58 4 0xffffff7f80c10000 0x12000 0x12000 com.apple.iokit.IONDRVSupport (2.3.5) <56 10 7 5 4 3>
59 2 0xffffff7f80c22000 0xe000 0xe000 com.apple.iokit.IOSerialFamily (10.0.6) <7 6 5 4 3 1>
60 1 0xffffff7f80c30000 0xd000 0xd000 com.apple.driver.Apple16X50Serial (3.1) <59 10 5 4 3>
61 0 0xffffff7f80c3d000 0x2000 0x2000 com.apple.driver.Apple16X50ACPI (3.1) <60 9 4 3>
62 5 0xffffff7f80c3f000 0x8000 0x8000 com.apple.driver.IOPlatformPluginFamily (5.2.0d16) <9 7 6 5 4 3>
63 0 0xffffff7f80c47000 0x3000 0x3000 com.apple.driver.AppleLPC (1.6.0) <62 10 5 4 3>
65 1 0xffffff7f80c4d000 0x12000 0x12000 com.apple.driver.IOPlatformPluginLegacy (1.0.0) <62 9 7 6 5 4 3>
66 2 0xffffff7f80c5f000 0xc000 0xc000 com.apple.driver.AppleSMC (3.1.4d2) <9 7 5 4 3>
67 0 0xffffff7f80c6b000 0x10000 0x10000 com.apple.driver.ACPI_SMC_PlatformPlugin (1.0.0) <66 65 62 10 9 7 6 5 4 3>
68 1 0xffffff7f80c7b000 0x3000 0x3000 com.apple.driver.AppleGraphicsControl (3.2.11) <58 56 10 9 7 5 4 3 1>
69 0 0xffffff7f80c7e000 0xc000 0xc000 com.apple.driver.ApplePolicyControl (3.2.11) <68 58 56 10 9 7 5 4 3 1>
70 0 0xffffff7f80c8a000 0xd000 0xd000 com.apple.iokit.IOFireWireIP (2.2.5) <44 41 5 4 3 1>
71 2 0xffffff7f80c97000 0xc000 0xc000 com.apple.iokit.IOHDAFamily (2.3.1f2) <5 4 3 1>
72 1 0xffffff7f80ca3000 0x14000 0x14000 com.apple.driver.AppleHDAController (2.3.1f2) <71 56 10 6 5 4 3 1>
73 0 0xffffff7f80cb7000 0x3000 0x3000 com.apple.driver.AppleSMCPDRC (1.0.0) <62 10 6 4 3>
74 1 0xffffff7f80cba000 0x25000 0x25000 com.apple.iokit.AppleBluetoothHCIControllerUSBTransport (4.0.9f33) <30 10 9 7 5 4 3 1>
75 0 0xffffff7f80cdf000 0x5000 0x5000 com.apple.Dont_Steal_Mac_OS_X (7.0.0) <66 7 4 3 1>
76 2 0xffffff7f80ce4000 0x7000 0x7000 com.apple.kext.OSvKernDSPLib (1.6) <5 4>
77 5 0xffffff7f80ceb000 0x2e000 0x2e000 com.apple.iokit.IOAudioFamily (1.8.9fc10) <76 5 4 3 1>
78 1 0xffffff7f80d19000 0xb6000 0xb6000 com.apple.driver.DspFuncLib (2.3.1f2) <77 76 5 4 3 1>
79 0 0xffffff7f80dcf000 0x7b000 0x7b000 com.apple.driver.AppleHDA (2.3.1f2) <78 77 72 71 58 56 6 5 4 3 1>
80 0 0xffffff7f80e4a000 0x5000 0x5000 com.apple.iokit.CSRBluetoothHCIControllerUSBTransport (4.0.9f33) <74 30 7 5 4 3>
82 0 0xffffff7f80e55000 0x10000 0x10000 com.apple.driver.AGPM (100.12.69) <62 58 56 10 5 4 3>
84 4 0xffffff7f80e6e000 0xa0000 0xa0000 com.apple.iokit.IOBluetoothFamily (4.0.9f33) <30 7 5 4 3 1>
86 1 0xffffff7f80f10000 0x3000 0x3000 com.apple.iokit.IOSMBusFamily (1.1) <5 4 3>
87 1 0xffffff7f80f13000 0xe000 0xe000 com.apple.driver.AppleSMBusController (1.0.10d0) <86 10 9 5 4 3>
88 0 0xffffff7f80f21000 0xc000 0xc000 com.apple.driver.AppleMCCSControl (1.0.33) <87 56 10 9 7 5 4 3 1>
89 0 0xffffff7f80f2d000 0xa000 0xa000 com.apple.iokit.IOBluetoothSerialManager (4.0.9f33) <59 7 5 4 3 1>
90 0 0xffffff7f80f37000 0x11000 0x11000 com.apple.iokit.IOSurface (86.0.3) <7 5 4 3 1>
91 0 0xffffff7f80f48000 0x7000 0x7000 com.apple.iokit.IOUserEthernet (1.0.0d1) <41 6 5 4 3 1>
92 0 0xffffff7f80f4f000 0x8000 0x8000 com.apple.driver.IOBluetoothA2DPAudioDriver (4.0.9f33) <84 77 5 4 3 1>
93 0 0xffffff7f80f57000 0xa000 0xa000 com.apple.driver.IOBluetoothSCOAudioDriver (4.0.9f33) <84 77 5 4 3>
94 0 0xffffff7f80f61000 0x5000 0x5000 com.apple.driver.AudioAUUC (1.60) <77 56 10 9 7 5 4 3 1>
95 0 0xffffff7f80f66000 0x5000 0x5000 com.apple.driver.AppleHWSensor (1.9.5d0) <5 4 3>
96 0 0xffffff7f80f6b000 0x7000 0x7000 foo.tap (1.0) <7 5 4 1>
97 0 0xffffff7f80f72000 0x8000 0x8000 foo.tun (1.0) <7 5 4 1>
98 1 0xffffff7f80f7a000 0x12000 0x12000 com.apple.driver.AppleMultitouchDriver (235.28) <26 5 4 3 1>
99 1 0xffffff7f80f8c000 0x12000 0x12000 com.apple.driver.IOBluetoothHIDDriver (4.0.9f33) <84 26 5 4 3>
100 0 0xffffff7f80f9e000 0xe000 0xe000 com.apple.driver.AppleBluetoothMultitouch (75.15) <99 98 84 26 5 4 3>
103 0 0xffffff7f80faf000 0x4000 0x4000 com.evosx86.driver.lspcidrv (1.0) <4 3>
What is signature? Usial signing in any document? Does it includes hardware info? o_O
I can insert here lspci output from linux. lspci in osx outputs a lot of unknown hardware..
I have installed OS X with U{censored} method. Then I have been booting more and more installing needed kexts like NULLCpuPowerManagement. I do not want to repeat it all again as far as I'm not sure it will work perfect.
Here is lspci output from archlinux live disk. I don't know why it says I have Xeon processor, because I'm sure it is i3-2105
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b5)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
00:1c.5 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 6 (rev b5)
00:1c.6 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 (rev b5)
00:1c.7 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 8 (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation Z68 Express Chipset Family LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
01:00.0 VGA compatible controller: NVIDIA Corporation G84 [GeForce 8600 GT] (rev a1)
03:00.0 PCI bridge: Integrated Technology Express, Inc. Device 8892 (rev 10)
04:02.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev c0)
06:00.0 USB controller: Etron Technology, Inc. EJ168 USB 3.0 Host Controller (rev 01)
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
08:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9172 SATA 6Gb/s Controller (rev 11)
