DylanSupertramp
(AIUTO) Installazione Snow Leopard 10.6 build 10a432 su ACER ASPIRE 5738ZG
Hi, as the title I'm looking for help to install Snow Leopard on my notebook
I tried many methods.
I started trying to install Lion, arriving at the installation phase, but the notebook turned off in mid-process. I used both the verbose mode, also using GraphicsEnabler = off, but nothing. All through iATKOS L2.
Then I tried with iATKOS S3 v2 Snow Leopard. After several attempts I managed to install it, but will not start, giving me "error_null_string_ ..."
Finally I tried with iB{censored} + Snow Leopard retail, burn 4.7GB DVD using TransMac, by removing unnecessary files (following a guide found on the internet) and replacing the 2 files "OSInstall.mpkg" and "OSInstall", thinking it was a problem of partition (the drive MBR for windows), so you do not have to format everything in GUI maintained even windows.
Starting in verbose mode and excluding the graphics card, loading seems to be going well but then stop when loading the file "/ System / Library / Extensions / webdav_fs.text," the last of the folder.
Also, since I did the first installation, I can not start the computer normally (without boot from cd), but I always use iB{censored} or iAktos and then select Windows.
boot0: test
boot0: test
boot0: Error
I tried to create a dual boot with Easy BCD but it gives me an opportunity to do so. How do i get back to "normality" to start over with a clean system from previous attempts?
Acer Aspire 5738ZG
Intel Pentium Core Duo T4300 2.10ghz (Socket P478)
motherboard: Asus JV50 chipset Intel GM45/47
Bios: Phoenix Technologies v1.13
RAM: 4gb DDR2
HDD: 320gb
Graphics: ATI Mobility Radeon HD 4570 512Mb
Wireless: Atheros AR5B91 Wireless Network Adapter
Ethernet: Broadcom NetXtreme Gigabit Ethernet
Of course, I had created a primary FAT32 partition to install Mac os
I hope some of you can help me, PLEASE!
THANK YOU IN ADVANCE!
(sorry for imperfect english, i used Google Translate :-) )
Salve, come da titolo cerco aiuto per l'installazione di Snow Leopard sul mio notebook
Ho provato tanti metodi.
Ho cominciato provando ad installare Lion, arrivando alla fase di installazione, ma il notebook si spegneva a metà processo. HO usato sia la modalità verbosa, usando anche GraphicsEnabler=off, ma niente. Tutto tramite iATKOS L2.
Poi ho provato con iATKOS S3 v2 per snow leopard. Dopo vari tentativi sono riuscito ad installarlo, ma non parte, dandomi "error_null_string_..."
Infine ho provato con iB{censored}+Snow Leopard retail, masterizzato su dvd 4.7GB tramite TransMac, eliminando i file non necessari(seguendo una guida trovata su internet) e sostituendo i 2 file "OSInstall.mpkg" e "OSInstall", pensando che fosse un problema di partizione(il drive MBR per windows), così da non dover formattare tutto in GUI, per conservare anche windows.
Partendo in modalità verbosa ed escludendo la scheda grafica, il caricamento sembra procedere bene salvo poi interrompersi quando carica il file "/System/Library/Extension/webdav_fs.text", l'ultimo della cartella.
Inoltre, da quando ho provato la prima installazione, non riesco a far partire il pc normalmente(senza boot da cd), ma devo sempre usare iB{censored} o iAktos e poi selezionare Windows.
boot0: test
boot0: test
boot0: Error
Ho provato a creare un dual boot con Easy BCD ma non mi da la possibilità di farlo. COme torno alla "normalità" per ricominciare da capo con il sistema pulito dai precedenti tentativi?
queste le specifiche del notebook:
Acer Aspire 5738ZG
RAM: 4gb DDR2
HDD: 320gb
Scheda video: ATI Mobility Radeon HD 4570 512Mb
Naturalmente avevo creato una partizione FAT32 primaria per installare Mac os
Spero qualcuno di voi possa aiutarmi, VI PREGO!
GRAZIE MILLE IN ANTICIPO!
Edited by DylanSupertramp
In English too
ciao vai sul mio blog helpdesk32.altervista.org/blog e vai nei miei articoli c'è qualcosa che ti potrebbe essere di aiuto.
Cerca snow leopard e installazione.
