jcgalveza
Help on HP Pavilion p6390es
Hello every one, I'm very new in all of this, in fact I have never even use a mac. But now I need to install OS X (not sure which version) on my HP pavilion p6390 desktop (buying a mac would be much better but since that's out of my reach I'm exploring the hackingtosh way). So the first thing I would like to know is if that installing any version on my pc is even possible.
Any help will be greatly appreciated.
Thank you very much in advance.
6 answers to this question
Your rig might work with nawcom´s mod and 10.6.8 if you can follow this guide:
http://www.osx86.net/desktops/9746-guide-os-x-10-6-amd.html
I cant tell whether the 9100 mGPU will be supported. Best try to install on a seperate sATA HDD, if you can source one.
If you would like to probe your hardware in advance, run this: System Info - Downloads - OSx86.net
Note that suitable JAVA runtime is needed in Windows. If you got now or few or no :( , I would give it a try.
Hello noway, thank you very much for your response, I've just seen the guide, it is intended for AMD systems, mine is Intel, processor is intel core 2 quad q8300 and my graphics is AMD Radeon HD 4350.
I downloaded the tool and will try it today, then I will post all the info.
Thaks again
Seems there were a few flavours of the 6390 available over time. A Q8300 will make things a lot easier!
Basically you can follow the guide though. Nawcom´s mod should be fine for you too.
Best submit all your hardware specs in your signature.
People will find it easier to help you along that way.
Edited by noway
Thanks again noway, well I've been looking on the net for some info, and there are a lot of things and terms I don't understand, it seems I need kext (which I suppose are the equivalents of drivers in windows) so I went here Kexts and search on the list they have and I found com.apple.kext.ATISupport (7.0.2) has been tested on Mountain Lion successfully for my video card (radeon HD4350) so, my question is:
Should I download that file from somewhere? if so, then from where?
There are also some other indications on installing a boot loader using a pkg installer (boot loader is clover) so:
what is pkg installer and how do I run that? should I use something in the ML installer?
Thanks
Your graphic chip has been covered here: http://www.osx86.net/desktops/11515-guide-installing-ati-radeon-hd4350-graphics-card-mac-os-x-lion.html
and here: [GUIDE] ATI Radeon HD 4350 and Mac OS X 10.6 (and 10.7)
But first things first. Get yourself a copy of the Snow Leopard retail DVD from Apple and install 10.6.
Afterwards you can enable graphics hardware acceleration in 10.6 and try to install (Mountain) Lion.
Hello noway, thanks for your reply, Ok I'll do that, by the way, yesterday I ran sys info on my pc but could not export because of exceptions, today I'll try to solve that problem.
