esse76
Snow Leopard RetailDVD img Boot from USB wont work...
Hi everyone...probably somebody already posted a topic like mine..wasn't able to see something like..
if somebody already posted that kind i do my apologize...
perhaps i'm a noob on mac and related or perhaps i don't get the right way to run things right..
since i saw it is possible install snow leopard on Asus P5K in the following link:
HCL 10.6.3 - OSx86
i'm trying to make a Snow Leopard USB bootable.
i did tried to find a solution to get it up and running from usb.. followed tutorial how to so searched quiet well with google but couldn't find a way to make the USB bootable..
the first 2 times "following 2 different tutorials" as soon as PC boot up and launched the set up from USB
got black screen and saw kernel panic so crashed i do believe....
tried other tutorial... one wouldn't even make boot the usb black screen and blinking cursor..
tried another and finally could boot from USB without crash panic or blinking cursor..
but that one get stuck on gray screen with apple in the middle and no sign of something is loading....
is there a way to create a snow leopard usb bootable is working??with retail .img of snow leopard
didn't mentioned i have an up and running leopard 10.5.1..."and can't get rid on update it but doesn't matter"...
Edited by esse76
GEEEEEEEEEEEZZZZZZZZ finally got retail snow running but when i get the set up cant find any HDD just the USB
and say i did dropped in some kext even jmicron ata satainjector "what ever is"
dont know what is missing now...
might be missing intel ICH something
any suggestion?
Intel ICH is natively supported by OS X.
Is AHCI on?
And is the SATA cable on the AHCI controller?
hmm still having problems with installation...
and rebuild extension.mkext..
with kext utility wont build the new one end of the process give me an error..
with terminal im not the best...
did tried without mkext but seems it takes way long time to run the installation.....
about the end of installation well i got the install log :
Dec 13 05:33:13 localhost LCA[81]: Folder Manager is being asked to create a folder (cach) while running as uid 0
Dec 13 05:33:18 localhost LCA[81]: Launching the Installer using language code "English"
Dec 13 05:33:18 localhost OSInstaller[154]: Mac OS X Installer application started
Dec 13 05:33:18 localhost OSInstaller[154]: 1 display(s) found.
Dec 13 05:33:18 localhost OSInstaller[154]: Display[1] is NOT using OpenGL acceleration.
Dec 13 05:33:18 localhost OSInstaller[154]: @(#)PROGRAM:Install PROJECT:Install-572
Dec 13 05:33:18 localhost OSInstaller[154]: @(#)PROGRAM:Mac OS X Installer PROJECT:OSInstaller-255
Dec 13 05:33:18 localhost OSInstaller[154]: Hardware: iMac8,1 @ 3.48 GHz (x 2), 4096 MB RAM
Dec 13 05:33:18 localhost OSInstaller[154]: Running OS Build: Mac OS X 10.6 (10A432)
Dec 13 05:33:18 localhost OSInstaller[154]: Env: DYLD_NO_FIX_PREBINDING=1
Dec 13 05:33:18 localhost OSInstaller[154]: Env: PATH=/usr/bin:/bin:/usr/sbin:/sbin
Dec 13 05:33:18 localhost OSInstaller[154]: Env: PWD=/
Dec 13 05:33:18 localhost OSInstaller[154]: Env: SHLVL=1
Dec 13 05:33:18 localhost OSInstaller[154]: Env: OS_INSTALL=1
Dec 13 05:33:18 localhost OSInstaller[154]: Env: _=/System/Installation/CDIS/LCA.app/Contents/MacOS/LCA
Dec 13 05:33:18 localhost OSInstaller[154]: Using install media product at /System/Installation/Packages
Dec 13 05:33:18 localhost OSInstaller[154]: Opening OSInstall package '/System/Installation/Packages/OSInstall.mpkg'.
Dec 13 05:33:21 localhost OSInstaller[154]: Memory statistics for 'Install Mac OS X' pane:
Dec 13 05:33:21 localhost OSInstaller[154]: Physical Memory Allocation: 490 MB wired, 3 MB trapped, 51 MB active, 70 MB inactive, 3482 MB free, 3603 MB usable, 4096 MB total
Dec 13 05:33:21 localhost OSInstaller[154]: Not loading AirPort MenuExtra because this machine does not have wireless networking available.
Dec 13 05:33:25 localhost Unknown[82]: 2012-12-13 05:33:25.648 Disk Utility[162:903] **********
Dec 13 05:33:25 localhost Unknown[82]: 2012-12-13 05:33:25.659 Disk Utility[162:903] Disk Utility started.
Dec 13 05:34:21 localhost Unknown[82]: 2012-12-13 05:34:21.842 Disk Utility[162:903] Preparing to partition disk: ?ÄúST3160815AS?Äù
Dec 13 05:34:21 localhost Unknown[82]: 2012-12-13 05:34:21.854 Disk Utility[162:903] Partition Scheme: Master Boot Record
Dec 13 05:34:21 localhost Unknown[82]: 2012-12-13 05:34:21.855 Disk Utility[162:903] 1 partition will be created
Dec 13 05:34:21 localhost Unknown[82]: 2012-12-13 05:34:21.856 Disk Utility[162:903]
Dec 13 05:34:21 localhost Unknown[82]: 2012-12-13 05:34:21.858 Disk Utility[162:903] Partition 1
Dec 13 05:34:21 localhost Unknown[82]: 2012-12-13 05:34:21.859 Disk Utility[162:903] Name : ?ÄúSnow Leopard?Äù
Dec 13 05:34:21 localhost Unknown[82]: 2012-12-13 05:34:21.861 Disk Utility[162:903] Size : 160.04 GB
Dec 13 05:34:21 localhost Unknown[82]: 2012-12-13 05:34:21.862 Disk Utility[162:903] Filesystem : Mac OS Extended (Journaled)
Dec 13 05:34:21 localhost Unknown[82]: 2012-12-13 05:34:21.864 Disk Utility[162:903]
Dec 13 05:34:21 localhost Unknown[82]: 2012-12-13 05:34:21.969 Disk Utility[162:903] Unmounting disk
Dec 13 05:34:34 localhost Unknown[82]: 2012-12-13 05:34:34.732 Disk Utility[162:903] Creating partition map
Dec 13 05:34:36 localhost Unknown[82]: 2012-12-13 05:34:36.188 Disk Utility[162:903] Waiting for disks to reappear
Dec 13 05:34:36 localhost Unknown[82]: 2012-12-13 05:34:36.191 Disk Utility[162:903] Formatting disk1s1 as Mac OS Extended (Journaled) with name Snow Leopard
Dec 13 05:34:42 localhost Unknown[82]: 2012-12-13 05:34:42.990 Disk Utility[162:903] Partition complete.
Dec 13 05:34:42 localhost Unknown[82]: 2012-12-13 05:34:42.991 Disk Utility[162:903]
Dec 13 05:34:50 localhost Unknown[82]: 2012-12-13 05:34:50.323 Disk Utility[162:903]
Dec 13 05:34:50 localhost Unknown[82]: Name : ST3160815AS
Dec 13 05:34:50 localhost Unknown[82]: Type : Disk
Dec 13 05:34:50 localhost Unknown[82]: Partition Map Scheme : Master Boot Record
Dec 13 05:34:50 localhost Unknown[82]: Disk Identifier : disk1
Dec 13 05:34:50 localhost Unknown[82]: Media Name : ST3160815AS ST3160815AS
Dec 13 05:34:50 localhost Unknown[82]: Media Type : Generic
Dec 13 05:34:50 localhost Unknown[82]: Connection Bus : SATA
Dec 13 05:34:50 localhost Unknown[82]: Device Tree : IODeviceTree:/PCI0@0/SAT1@1F,5/CHN0@0
Dec 13 05:34:50 localhost Unknown[82]: Writable : Yes
Dec 13 05:34:50 localhost Unknown[82]: Ejectable : No
Dec 13 05:34:50 localhost Unknown[82]: Location : Internal
Dec 13 05:34:50 localhost Unknown[82]: Total Capacity : 160.04 GB (160,041,885,696 Bytes)
Dec 13 05:34:50 localhost Unknown[82]: S.M.A.R.T. Status : Verified
Dec 13 05:34:50 localhost Unknown[82]: Disk Number : 1
Dec 13 05:34:50 localhost Unknown[82]: Partition Number : 0
Dec 13 05:35:01 localhost Unknown[82]: 2012-12-13 05:35:01.545 Disk Utility[162:903] NSDocumentController's invocation of -[NSFileManager URLForDirectory:inDomain:appropriateForURL:create:error:] returned nil for NSAutosavedInformationDirectory. Here's the error:
Dec 13 05:35:01 localhost Unknown[82]: Error Domain=NSCocoaErrorDomain Code=642 UserInfo=0x61e4c30 "You can?Äôt save the file ?ÄúAutosave Information?Äù because the volume ?ÄúMac OS X Install DVD?Äù is read only." Underlying Error=(Error Domain=NSPOSIXErrorDomain Code=30 "The operation couldn?Äôt be completed. Read-only file system")
Dec 13 05:35:06 localhost OSInstaller[154]: Allowing machine sleep.
Dec 13 05:35:14 localhost OSInstaller[154]: Memory statistics for 'Install Mac OS X' pane:
Dec 13 05:35:14 localhost OSInstaller[154]: Physical Memory Allocation: 464 MB wired, 3 MB trapped, 60 MB active, 88 MB inactive, 3481 MB free, 3629 MB usable, 4096 MB total
Dec 13 05:35:19 localhost Unknown[82]: 2012-12-13 05:35:19.119 Disk Utility[174:903] **********
Dec 13 05:35:19 localhost Unknown[82]: 2012-12-13 05:35:19.126 Disk Utility[174:903] Disk Utility started.
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.241 Disk Utility[174:903] Preparing to partition disk: ?ÄúST3160815AS?Äù
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.264 Disk Utility[174:903] Partition Scheme: Apple Partition Map
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.266 Disk Utility[174:903] 1 partition will be created
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.267 Disk Utility[174:903]
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.268 Disk Utility[174:903] Partition 1
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.269 Disk Utility[174:903] Name : ?ÄúSnow Leopard?Äù
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.270 Disk Utility[174:903] Size : 160.04 GB
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.271 Disk Utility[174:903] Filesystem : Mac OS Extended (Journaled)
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.272 Disk Utility[174:903]
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.372 Disk Utility[174:903] Unmounting disk
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.542 Disk Utility[174:903] Creating partition map
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.550 Disk Utility[174:903] Waiting for disks to reappear
Dec 13 05:35:58 localhost Unknown[82]: 2012-12-13 05:35:58.801 Disk Utility[174:903] Formatting disk1s3 as Mac OS Extended (Journaled) with name Snow Leopard
Dec 13 05:36:05 localhost Unknown[82]: 2012-12-13 05:36:05.601 Disk Utility[174:903] Partition complete.
Dec 13 05:36:05 localhost Unknown[82]: 2012-12-13 05:36:05.602 Disk Utility[174:903]
Dec 13 05:36:13 localhost Unknown[82]: 2012-12-13 05:36:13.362 Disk Utility[174:903] NSDocumentController's invocation of -[NSFileManager URLForDirectory:inDomain:appropriateForURL:create:error:] returned nil for NSAutosavedInformationDirectory. Here's the error:
Dec 13 05:36:13 localhost Unknown[82]: Error Domain=NSCocoaErrorDomain Code=642 UserInfo=0x61d8590 "You can?Äôt save the file ?ÄúAutosave Information?Äù because the volume ?ÄúMac OS X Install DVD?Äù is read only." Underlying Error=(Error Domain=NSPOSIXErrorDomain Code=30 "The operation couldn?Äôt be completed. Read-only file system")
Dec 13 05:36:14 localhost OSInstaller[154]: Allowing machine sleep.
Dec 13 05:36:19 localhost OSInstaller[154]: Memory statistics for 'Install Mac OS X' pane:
Dec 13 05:36:19 localhost OSInstaller[154]: Physical Memory Allocation: 464 MB wired, 2 MB trapped, 58 MB active, 89 MB inactive, 3483 MB free, 3630 MB usable, 4096 MB total
Dec 13 05:36:23 localhost Unknown[82]: 2012-12-13 05:36:23.257 Disk Utility[184:903] **********
Dec 13 05:36:23 localhost Unknown[82]: 2012-12-13 05:36:23.264 Disk Utility[184:903] Disk Utility started.
Dec 13 05:36:48 localhost Unknown[82]: 2012-12-13 05:36:48.241 Disk Utility[184:903] Preparing to partition disk: ?ÄúST3160815AS?Äù
Dec 13 05:36:48 localhost Unknown[82]: 2012-12-13 05:36:48.252 Disk Utility[184:903] Partition Scheme: Apple Partition Map
Dec 13 05:36:48 localhost Unknown[82]: 2012-12-13 05:36:48.253 Disk Utility[184:903] 1 partition will be created
Dec 13 05:36:48 localhost Unknown[82]: 2012-12-13 05:36:48.254 Disk Utility[184:903]
Dec 13 05:36:48 localhost Unknown[82]: 2012-12-13 05:36:48.256 Disk Utility[184:903] Partition 1
Dec 13 05:36:48 localhost Unknown[82]: 2012-12-13 05:36:48.257 Disk Utility[184:903] Name : ?ÄúSnow Leopard?Äù
Dec 13 05:36:48 localhost Unknown[82]: 2012-12-13 05:36:48.258 Disk Utility[184:903] Size : 160.04 GB
Dec 13 05:36:48 localhost Unknown[82]: 2012-12-13 05:36:48.260 Disk Utility[184:903] Filesystem : Mac OS Extended (Journaled)
Dec 13 05:36:48 localhost Unknown[82]: 2012-12-13 05:36:48.261 Disk Utility[184:903]
Dec 13 05:36:48 localhost Unknown[82]: 2012-12-13 05:36:48.361 Disk Utility[184:903] Unmounting disk
Dec 13 05:36:49 localhost Unknown[82]: 2012-12-13 05:36:49.970 Disk Utility[184:903] Creating partition map
Dec 13 05:36:51 localhost Unknown[82]: 2012-12-13 05:36:51.559 Disk Utility[184:903] Waiting for disks to reappear
Dec 13 05:36:51 localhost Unknown[82]: 2012-12-13 05:36:51.562 Disk Utility[184:903] Formatting disk1s3 as Mac OS Extended (Journaled) with name Snow Leopard
Dec 13 05:36:57 localhost Unknown[82]: 2012-12-13 05:36:57.020 Disk Utility[184:903] Partition complete.
Dec 13 05:36:57 localhost Unknown[82]: 2012-12-13 05:36:57.021 Disk Utility[184:903]
Dec 13 05:37:03 localhost Unknown[82]: 2012-12-13 05:37:03.982 Disk Utility[184:903] NSDocumentController's invocation of -[NSFileManager URLForDirectory:inDomain:appropriateForURL:create:error:] returned nil for NSAutosavedInformationDirectory. Here's the error:
Dec 13 05:37:03 localhost Unknown[82]: Error Domain=NSCocoaErrorDomain Code=642 UserInfo=0x1aa145e0 "You can?Äôt save the file ?ÄúAutosave Information?Äù because the volume ?ÄúMac OS X Install DVD?Äù is read only." Underlying Error=(Error Domain=NSPOSIXErrorDomain Code=30 "The operation couldn?Äôt be completed. Read-only file system")
Dec 13 05:37:05 localhost OSInstaller[154]: Allowing machine sleep.
Dec 13 05:37:28 localhost Unknown[82]: 2012-12-13 05:37:28.565 Disk Utility[194:903] **********
Dec 13 05:37:28 localhost Unknown[82]: 2012-12-13 05:37:28.572 Disk Utility[194:903] Disk Utility started.
Dec 13 05:37:59 localhost Unknown[82]: 2012-12-13 05:37:59.196 Disk Utility[194:903]
Dec 13 05:37:59 localhost Unknown[82]: Name : ST3160815AS
Dec 13 05:37:59 localhost Unknown[82]: Type : Disk
Dec 13 05:37:59 localhost Unknown[82]: Partition Map Scheme : Apple Partition Map
Dec 13 05:37:59 localhost Unknown[82]: Disk Identifier : disk1
Dec 13 05:37:59 localhost Unknown[82]: Media Name : ST3160815AS ST3160815AS
Dec 13 05:37:59 localhost Unknown[82]: Media Type : Generic
Dec 13 05:37:59 localhost Unknown[82]: Connection Bus : SATA
Dec 13 05:37:59 localhost Unknown[82]: Device Tree : IODeviceTree:/PCI0@0/SAT1@1F,5/CHN0@0
Dec 13 05:37:59 localhost Unknown[82]: Writable : Yes
Dec 13 05:37:59 localhost Unknown[82]: Ejectable : No
Dec 13 05:37:59 localhost Unknown[82]: Mac OS 9 Drivers Installed : No
Dec 13 05:37:59 localhost Unknown[82]: Location : Internal
Dec 13 05:37:59 localhost Unknown[82]: Total Capacity : 160.04 GB (160,041,885,696 Bytes)
Dec 13 05:37:59 localhost Unknown[82]: S.M.A.R.T. Status : Verified
Dec 13 05:37:59 localhost Unknown[82]: Disk Number : 1
Dec 13 05:37:59 localhost Unknown[82]: Partition Number : 0
Dec 13 05:38:33 localhost Unknown[82]: 2012-12-13 05:38:33.385 Disk Utility[194:903] Preparing to partition disk: ?ÄúST3160815AS?Äù
Dec 13 05:38:33 localhost Unknown[82]: 2012-12-13 05:38:33.397 Disk Utility[194:903] Partition Scheme: GUID Partition Table
Dec 13 05:38:33 localhost Unknown[82]: 2012-12-13 05:38:33.398 Disk Utility[194:903] 1 partition will be created
Dec 13 05:38:33 localhost Unknown[82]: 2012-12-13 05:38:33.399 Disk Utility[194:903]
Dec 13 05:38:33 localhost Unknown[82]: 2012-12-13 05:38:33.401 Disk Utility[194:903] Partition 1
Dec 13 05:38:33 localhost Unknown[82]: 2012-12-13 05:38:33.402 Disk Utility[194:903] Name : ?ÄúSnow Leopard?Äù
Dec 13 05:38:33 localhost Unknown[82]: 2012-12-13 05:38:33.403 Disk Utility[194:903] Size : 160.04 GB
Dec 13 05:38:33 localhost Unknown[82]: 2012-12-13 05:38:33.404 Disk Utility[194:903] Filesystem : Mac OS Extended (Journaled)
Dec 13 05:38:33 localhost Unknown[82]: 2012-12-13 05:38:33.405 Disk Utility[194:903]
Dec 13 05:38:33 localhost Unknown[82]: 2012-12-13 05:38:33.552 Disk Utility[194:903] Unmounting disk
Dec 13 05:38:35 localhost Unknown[82]: 2012-12-13 05:38:35.069 Disk Utility[194:903] Creating partition map
Dec 13 05:38:36 localhost Unknown[82]: 2012-12-13 05:38:36.723 Disk Utility[194:903] Waiting for disks to reappear
Dec 13 05:38:36 localhost Unknown[82]: 2012-12-13 05:38:36.741 Disk Utility[194:903] Formatting disk1s2 as Mac OS Extended (Journaled) with name Snow Leopard
Dec 13 05:38:41 localhost Unknown[82]: 2012-12-13 05:38:41.967 Disk Utility[194:903] Partition complete.
Dec 13 05:38:41 localhost Unknown[82]: 2012-12-13 05:38:41.969 Disk Utility[194:903]
Dec 13 05:38:48 localhost Unknown[82]: 2012-12-13 05:38:48.600 Disk Utility[194:903] NSDocumentController's invocation of -[NSFileManager URLForDirectory:inDomain:appropriateForURL:create:error:] returned nil for NSAutosavedInformationDirectory. Here's the error:
Dec 13 05:38:48 localhost Unknown[82]: Error Domain=NSCocoaErrorDomain Code=642 UserInfo=0x606fc20 "You can?Äôt save the file ?ÄúAutosave Information?Äù because the volume ?ÄúMac OS X Install DVD?Äù is read only." Underlying Error=(Error Domain=NSPOSIXErrorDomain Code=30 "The operation couldn?Äôt be completed. Read-only file system")
Dec 13 05:38:48 localhost OSInstaller[154]: Target volume disappeared.
Dec 13 05:39:25 localhost OSInstaller[154]: Preventing machine sleep.
Dec 13 05:39:25 localhost OSInstaller[154]: ================================================================================
Dec 13 05:39:25 localhost OSInstaller[154]: Choices selected for installation:
Dec 13 05:39:25 localhost OSInstaller[154]: Install: "Mac OS X"
Dec 13 05:39:25 localhost OSInstaller[154]: Install: "Essential System Software"
Dec 13 05:39:25 localhost OSInstaller[154]: BaseSystem.pkg : com.apple.pkg.BaseSystem : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: Essentials.pkg : com.apple.pkg.Essentials : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: BootCamp.pkg : com.apple.pkg.BootCamp : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: BSD.pkg : com.apple.pkg.BSD : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: iPodSupport.pkg : com.apple.pkg.iPodSupport : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: PodcastCapture.pkg : com.apple.pkg.PodcastCapture : 1.0.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: JavaTools.pkg : com.apple.pkg.JavaTools : 1.0.0.9000000000.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: AdditionalEssentials.pkg : com.apple.pkg.AdditionalEssentials : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: AdditionalSpeechVoices.pkg : com.apple.pkg.AdditionalSpeechVoices : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: AsianLanguagesSupport.pkg : com.apple.pkg.AsianLanguagesSupport : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: MediaFiles.pkg : com.apple.pkg.MediaFiles : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: MigrationAssistant.pkg : com.apple.pkg.MigrationAssistant : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: Mail.pkg : com.apple.pkg.Mail : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: AddressBook.pkg : com.apple.pkg.AddressBook : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: iCal.pkg : com.apple.pkg.iCal : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: Automator.pkg : com.apple.pkg.Automator : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: DVDPlayer.pkg : com.apple.pkg.DVDPlayer : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: iTunes.pkg : com.apple.pkg.iTunes : 8.2.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: iChat.pkg : com.apple.pkg.iChat : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: Java.pkg : com.apple.pkg.Java : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: Safari.pkg : com.apple.pkg.Safari : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: OxfordDictionaries.pkg : com.apple.pkg.OxfordDictionaries : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: Install: "X11"
Dec 13 05:39:25 localhost OSInstaller[154]: X11User.pkg : com.apple.pkg.X11User : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: Install: "Rosetta"
Dec 13 05:39:25 localhost OSInstaller[154]: Rosetta.pkg : com.apple.pkg.Rosetta : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: Install: "QuickTime 7"
Dec 13 05:39:25 localhost OSInstaller[154]: QuickTimePlayer7.pkg : com.apple.pkg.QuickTimePlayer7 : 10.6.0.1.1.1249291854
Dec 13 05:39:25 localhost OSInstaller[154]: OSInstall.pkg : com.apple.pkg.OSInstall : 10.6.0.1
Dec 13 05:39:25 localhost OSInstaller[154]: It took 0.01 seconds to summarize the package selections.
Dec 13 05:39:25 localhost OSInstaller[154]: Memory statistics for 'Installing' pane:
Dec 13 05:39:25 localhost OSInstaller[154]: Physical Memory Allocation: 562 MB wired, 2 MB trapped, 59 MB active, 85 MB inactive, 3388 MB free, 3532 MB usable, 4096 MB total
Dec 13 05:39:25 localhost OSInstaller[154]: Remote Install Assistant found at 1024:(null)
Dec 13 05:39:25 localhost runner[158]: Administrator authorization granted.
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/BaseSystem.pkg (1122186240 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/Essentials.pkg (1428633600 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/BootCamp.pkg (6888448 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/BSD.pkg (623410176 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/iPodSupport.pkg (636928 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/PodcastCapture.pkg (7599104 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/JavaTools.pkg (40564736 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/AdditionalEssentials.pkg (37269504 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/AdditionalSpeechVoices.pkg (279709696 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/AsianLanguagesSupport.pkg (4487168 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/MediaFiles.pkg (81670144 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/MigrationAssistant.pkg (37026816 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/Mail.pkg (56292352 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/AddressBook.pkg (13938688 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/iCal.pkg (38872064 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/Automator.pkg (26067968 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/DVDPlayer.pkg (23887872 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/iTunes.pkg (104758272 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/iChat.pkg (38499328 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/Java.pkg (151608320 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/Safari.pkg (31858688 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/OxfordDictionaries.pkg (44351488 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/X11User.pkg (91569152 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/Rosetta.pkg (1467392 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/QuickTimePlayer7.pkg (21947392 B)
Dec 13 05:39:25 localhost OSInstaller[154]: PK will install package file://localhost/System/Installation/Packages/OSInstall.pkg (0 B)
Dec 13 05:39:25 localhost OSInstaller[154]: Total install size including padding: 5388943360 b
Dec 13 05:39:26 localhost OSInstaller[154]: Starting installation:
Dec 13 05:39:26 localhost OSInstaller[154]: Calculating expected install size requirements
Dec 13 05:39:26 localhost Unknown[82]: 2012-12-13 05:39:26.447 Mac OS X Installer[154:b003] Looking for system packages
Dec 13 05:39:26 localhost Unknown[82]: 2012-12-13 05:39:26.458 Mac OS X Installer[154:b003] no system packages found
Dec 13 05:39:26 localhost Unknown[82]: 2012-12-13 05:39:26.460 Mac OS X Installer[154:b003] No or Invalid system receipts found on /Volumes/Snow Leopard
Dec 13 05:39:26 localhost Unknown[82]: 2012-12-13 05:39:26.461 Mac OS X Installer[154:b003] Attempting fallback using: /System/Library/PrivateFrameworks/SystemMigration.framework/Resources/FallbackSystemFiles.plist
Dec 13 05:39:26 localhost Unknown[82]: 2012-12-13 05:39:26.613 Mac OS X Installer[154:b003] Finding system files...
Dec 13 05:39:27 localhost Unknown[82]: 2012-12-13 05:39:27.073 Mac OS X Installer[154:b003] Writing system path cache.
Dec 13 05:39:27 localhost Unknown[82]: 2012-12-13 05:39:27.078 Mac OS X Installer[154:b003] Error writing cache to /Volumes/Snow Leopard/Library/Caches/com.apple.FindSystemFiles.plist
Dec 13 05:39:27 localhost Unknown[82]: 2012-12-13 05:39:27.093 Mac OS X Installer[154:b003] Failed to enumerate /Volumes/Snow Leopard/Library/Caches, cannot prune (
Dec 13 05:39:27 localhost Unknown[82]: "com.apple.user*pictureCache*"
Dec 13 05:39:27 localhost Unknown[82]: )
Dec 13 05:39:27 localhost OSInstaller[154]: Initial free size : 159.4 GB
Dec 13 05:39:27 localhost OSInstaller[154]: Expected system size : Zero KB
Dec 13 05:39:27 localhost OSInstaller[154]: Reserving 5388943360 for extraction
Dec 13 05:39:27 localhost OSInstaller[154]: Reserving 2821249188 for download
Dec 13 05:39:27 localhost OSInstaller[154]: Performing volume consistency check on 'Snow Leopard'.
Dec 13 05:39:38 localhost OSInstaller[154]: Checking Volume
Dec 13 05:39:38 localhost OSInstaller[154]: Checking Journaled HFS Plus volume.
Dec 13 05:39:38 localhost OSInstaller[154]: Checking extents overflow file.
Dec 13 05:39:38 localhost OSInstaller[154]: Checking catalog file.
Dec 13 05:39:40 localhost OSInstaller[154]: Checking multi-linked files.
Dec 13 05:39:40 localhost OSInstaller[154]: Checking catalog hierarchy.
Dec 13 05:39:40 localhost OSInstaller[154]: Checking extended attributes file.
Dec 13 05:39:42 localhost OSInstaller[154]: Checking volume bitmap.
Dec 13 05:39:42 localhost OSInstaller[154]: Checking volume information.
Dec 13 05:39:42 localhost OSInstaller[154]: The volume Snow Leopard appears to be OK.
Dec 13 05:39:43 localhost OSInstaller[154]: Volume repair complete.
Dec 13 05:39:43 localhost OSInstaller[154]: Updating boot support partitions for the volume as required.
Dec 13 05:39:43 localhost OSInstaller[154]: Volume passed consistency checks.
Dec 13 05:39:43 localhost OSInstaller[154]: Copying/Downloading selected packages locally
Dec 13 05:39:43 localhost OSInstaller[154]: Creating mutable product on /Volumes/Snow Leopard/Mac OS X Install Data
Dec 13 05:39:43 localhost OSInstaller[154]: Using packages from product at /Volumes/Snow Leopard/Mac OS X Install Data
Dec 13 05:39:43 localhost OSInstaller[154]: Linked to PackageKit-65
Dec 13 05:39:43 localhost OSInstaller[154]: Remote package size (2821249188) : available size (159397322752)
Dec 13 05:39:43 localhost OSInstaller[154]: Copying remote packages (26) to mutable product.
Dec 13 05:39:43 localhost OSInstaller[154]: Retrieved package com.apple.pkg.AddressBook
Dec 13 05:39:44 localhost OSInstaller[154]: Retrieved package com.apple.pkg.JavaTools
Dec 13 05:39:44 localhost OSInstaller[154]: Retrieved package com.apple.pkg.iPodSupport
Dec 13 05:40:20 localhost OSInstaller[154]: Retrieved package com.apple.pkg.BaseSystem
Dec 13 05:40:23 localhost OSInstaller[154]: Retrieved package com.apple.pkg.iTunes
Dec 13 05:40:24 localhost OSInstaller[154]: Retrieved package com.apple.pkg.iCal
Dec 13 05:40:30 localhost OSInstaller[154]: Retrieved package com.apple.pkg.MediaFiles
Dec 13 05:40:32 localhost OSInstaller[154]: Retrieved package com.apple.pkg.Mail
Dec 13 05:40:38 localhost OSInstaller[154]: Retrieved package com.apple.pkg.Java
Dec 13 05:40:39 localhost OSInstaller[154]: Retrieved package com.apple.pkg.DVDPlayer
Dec 13 05:40:39 localhost OSInstaller[154]: Retrieved package com.apple.pkg.OSInstall
Dec 13 05:40:39 localhost OSInstaller[154]: Retrieved package com.apple.pkg.AsianLanguagesSupport
Dec 13 05:40:41 localhost OSInstaller[154]: Retrieved package com.apple.pkg.MigrationAssistant
Dec 13 05:40:42 localhost OSInstaller[154]: Retrieved package com.apple.pkg.AdditionalEssentials
Dec 13 05:40:45 localhost OSInstaller[154]: Retrieved package com.apple.pkg.X11User
Dec 13 05:41:01 localhost OSInstaller[154]: Retrieved package com.apple.pkg.BSD
Dec 13 05:41:02 localhost OSInstaller[154]: Retrieved package com.apple.pkg.BootCamp
Dec 13 05:41:02 localhost OSInstaller[154]: Retrieved package com.apple.pkg.PodcastCapture
Dec 13 05:41:03 localhost OSInstaller[154]: Retrieved package com.apple.pkg.iChat
Dec 13 05:41:03 localhost OSInstaller[154]: Retrieved package com.apple.pkg.Automator
Dec 13 05:41:04 localhost OSInstaller[154]: Retrieved package com.apple.pkg.Safari
Dec 13 05:41:07 localhost OSInstaller[154]: Retrieved package com.apple.pkg.OxfordDictionaries
Dec 13 05:41:07 localhost OSInstaller[154]: Retrieved package com.apple.pkg.Rosetta
Dec 13 05:41:30 localhost OSInstaller[154]: Retrieved package com.apple.pkg.AdditionalSpeechVoices
Dec 13 05:41:31 localhost OSInstaller[154]: Retrieved package com.apple.pkg.QuickTimePlayer7
Dec 13 05:42:20 localhost OSInstaller[154]: Retrieved package com.apple.pkg.Essentials
Dec 13 05:42:21 localhost OSInstaller[154]: Configuring volume "Snow Leopard"
Dec 13 05:42:21 localhost OSInstaller[154]: Preparing disk for Netbooted OS Install.
Dec 13 05:42:21 localhost OSInstaller[154]: Volume disk1s2 mounted at /Volumes/Snow Leopard is ready
Dec 13 05:42:21 localhost OSInstaller[154]: Preparing disk for local booted OS Install.
Dec 13 05:42:21 localhost OSInstaller[154]: Physical memory statistics immediately before turning on virtual memory backing store:
Dec 13 05:42:21 localhost OSInstaller[154]: Physical Memory Allocation: 559 MB wired, 2 MB trapped, 60 MB active, 2663 MB inactive, 812 MB free, 3535 MB usable, 4096 MB total
Dec 13 05:42:21 localhost OSInstaller[154]: Activated virtual memory backing store at mount point '/Volumes/Snow Leopard'
Dec 13 05:42:21 localhost OSInstaller[154]: Preparing disk for local booted install.
Dec 13 05:42:21 localhost OSInstaller[154]: Creating installation log on volume "Snow Leopard"
Dec 13 05:42:21 localhost OSInstaller[154]: IFPKInstallElement (26 packages)
Dec 13 05:42:22 localhost OSInstaller[154]: PackageKit: ----- Begin install -----
Dec 13 05:42:22 localhost OSInstaller[154]: PackageKit: request=PKInstallRequest <26 packages, destination=/Volumes/Snow Leopard>
Dec 13 05:42:22 localhost OSInstaller[154]: PackageKit: packages=(\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/BaseSystem.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/Essentials.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/BootCamp.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/BSD.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/iPodSupport.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/PodcastCapture.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/JavaTools.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/AdditionalEssentials.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/AdditionalSpeechVoices.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/AsianLanguagesSupport.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/MediaFiles.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/MigrationAssistant.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/Mail.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/AddressBook.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/iCal.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/Automator.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Snow%20Leopard/Mac%20OS%20X%20Install%20Data/DVDPlayer.pkg>",\n "PKLeopardPackage <file://localhost/Volumes/Dec 13 05:42:23 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/BaseSystem.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:43:42 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/Essentials.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:45:39 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/BootCamp.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:45:40 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/BSD.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:46:52 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/iPodSupport.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:46:52 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/PodcastCapture.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:46:54 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/JavaTools.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:46:56 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/AdditionalEssentials.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:47:00 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/AdditionalSpeechVoices.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:47:31 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/AsianLanguagesSupport.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:47:32 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/MediaFiles.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:47:41 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/MigrationAssistant.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:47:45 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/Mail.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:47:53 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/AddressBook.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:47:55 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/iCal.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:47:59 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/Automator.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:48:02 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/DVDPlayer.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:48:05 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/iTunes.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:48:14 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/iChat.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:48:19 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/Java.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:48:32 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/Safari.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:48:36 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/OxfordDictionaries.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:48:40 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/X11User.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:48:50 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/Rosetta.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:48:50 localhost OSInstaller[154]: PackageKit: Extracting /Volumes/Snow Leopard/Mac OS X Install Data/QuickTimePlayer7.pkg (destination=/Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root, uid=0)
Dec 13 05:48:53 localhost OSInstaller[154]: PackageKit: Executing script "./preinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.BaseSystem.GSJ6y7
Dec 13 05:48:53 localhost OSInstaller[154]: PackageKit: Executing script "./preinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.Essentials.LwinOe
Dec 13 05:48:53 localhost OSInstaller[154]: PackageKit: Executing script "./preinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.BSD.GJTceb
Dec 13 05:48:53 localhost OSInstaller[154]: PackageKit: Executing script "./preinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.PodcastCapture.xbW1CK
Dec 13 05:48:53 localhost OSInstaller[154]: PackageKit: Executing script "./preinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.AdditionalEssentials.Q1QZUT
Dec 13 05:48:53 localhost OSInstaller[154]: PackageKit: Executing script "./preinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.MigrationAssistant.VaozRI
Dec 13 05:48:54 localhost root[232]: Running Install Scripts . . .
Dec 13 05:48:54 localhost root[234]: 0 Install Scripts run.
Dec 13 05:48:54 localhost OSInstaller[154]: PackageKit: Executing script "./preinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.Automator.bH5kgq
Dec 13 05:48:54 localhost OSInstaller[154]: PackageKit: Executing script "./preinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.X11User.WGgZ0Y
Dec 13 05:48:54 localhost OSInstaller[154]: PackageKit: Executing script "./preinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.Rosetta.2hRs5N
Dec 13 05:48:54 localhost OSInstaller[154]: PackageKit: Executing script "./preinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.OSInstall.k1MTNp
Dec 13 05:48:54 localhost root[243]: Running Install Scripts . . .
Dec 13 05:48:54 localhost root[245]: Begin script: preinstall
Dec 13 05:48:54 localhost root[247]: End script: preinstall
Dec 13 05:48:54 localhost root[248]: 1 Install Scripts run.
Dec 13 05:48:54 localhost OSInstaller[154]: PackageKit: update_dyld_shared_cache -root /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root
Dec 13 05:49:22 localhost OSInstaller[154]: PackageKit: Shoving /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Root (18 items) to /Volumes/Snow Leopard
Dec 13 05:49:23 localhost OSInstaller[154]: PackageKit: kextcache -update-volume /Volumes/Snow Leopard
Dec 13 05:49:30 localhost OSInstaller[154]: kextcache: JMicronATA.kext does not declare a kernel dependency; using com.apple.kernel.6.0.
Dec 13 05:49:38 localhost OSInstaller[154]: kextcache: /Volumes/Snow Leopard: no supported helper partitions to update.
Dec 13 05:49:38 localhost OSInstaller[154]: PackageKit: Executing script "./postinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.BaseSystem.GSJ6y7
Dec 13 05:49:38 localhost root[255]: Running Install Scripts . . .
Dec 13 05:49:38 localhost root[257]: Begin script: permissions
Dec 13 05:49:38 localhost root[260]: End script: permissions
Dec 13 05:49:38 localhost root[261]: 1 Install Scripts run.
Dec 13 05:49:38 localhost OSInstaller[154]: PackageKit: Executing script "./postinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.Essentials.LwinOe
Dec 13 05:49:38 localhost root[264]: Running Install Scripts . . .
Dec 13 05:49:38 localhost root[266]: Begin script: aclmodify.pl
Dec 13 05:49:38 localhost OSInstaller[154]: ./postinstall: /Volumes/Snow Leopard/System/Library/User Template/English.lproj
Dec 13 05:49:39 localhost OSInstaller[154]: ./postinstall: /Volumes/Snow Leopard/System/Library/User Template/Non_localized
Dec 13 05:49:39 localhost root[312]: End script: aclmodify.pl
Dec 13 05:49:39 localhost root[313]: Begin script: addLoginItem.pl
Dec 13 05:49:39 localhost root[316]: End script: addLoginItem.pl
Dec 13 05:49:39 localhost root[317]: Begin script: createDSStore
Dec 13 05:49:39 localhost root[322]: End script: createDSStore
Dec 13 05:49:39 localhost root[323]: Begin script: createJavaExtDir.sh
Dec 13 05:49:39 localhost root[329]: End script: createJavaExtDir.sh
Dec 13 05:49:40 localhost root[330]: Begin script: createPPDsDirectory
Dec 13 05:49:40 localhost root[335]: End script: createPPDsDirectory
Dec 13 05:49:40 localhost root[336]: Begin script: createSIUDir.sh
Dec 13 05:49:40 localhost root[344]: End script: createSIUDir.sh
Dec 13 05:49:40 localhost root[345]: Begin script: createSynthesizersDir
Dec 13 05:49:40 localhost root[352]: End script: createSynthesizersDir
Dec 13 05:49:40 localhost root[353]: Begin script: deleteSA.sh
Dec 13 05:49:40 localhost root[355]: End script: deleteSA.sh
Dec 13 05:49:40 localhost root[356]: Begin script: moveAsideHome
Dec 13 05:49:40 localhost OSInstaller[154]: ./postinstall: rmdir: /Volumes/Snow Leopard/home: No such file or directory
Dec 13 05:49:40 localhost root[359]: End script: moveAsideHome
Dec 13 05:49:40 localhost root[360]: Begin script: runChrooted.sh
Dec 13 05:49:51 localhost OSInstaller[154]: ./postinstall: umount: /Volumes/Snow Leopard/dev: not currently mounted
Dec 13 05:49:51 localhost root[379]: End script: runChrooted.sh
Dec 13 05:49:51 localhost root[380]: 10 Install Scripts run.
Dec 13 05:49:51 localhost OSInstaller[154]: PackageKit: Executing script "./postinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.BSD.GJTceb
Dec 13 05:49:51 localhost root[383]: Running Install Scripts . . .
Dec 13 05:49:51 localhost root[385]: Begin script: dumpemacs.sh
Dec 13 05:49:52 localhost OSInstaller[154]: ./postinstall: umount: /Volumes/Snow Leopard/dev: not currently mounted
Dec 13 05:49:52 localhost root[393]: End script: dumpemacs.sh
Dec 13 05:49:52 localhost root[394]: Begin script: fixnortinst.sh
Dec 13 05:49:52 localhost root[397]: End script: fixnortinst.sh
Dec 13 05:49:52 localhost root[398]: Begin script: postfixChrooted
Dec 13 05:49:58 localhost OSInstaller[154]: ./postinstall: umount: /Volumes/Snow Leopard/dev: not currently mounted
Dec 13 05:49:58 localhost root[1052]: End script: postfixChrooted
Dec 13 05:49:58 localhost root[1053]: 3 Install Scripts run.
Dec 13 05:49:58 localhost OSInstaller[154]: PackageKit: Executing script "./postinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.PodcastCapture.xbW1CK
Dec 13 05:49:58 localhost root[1056]: Running Install Scripts . . .
Dec 13 05:49:58 localhost root[1058]: Begin script: pcastint.sh
Dec 13 05:49:58 localhost root[1061]: End script: pcastint.sh
Dec 13 05:49:59 localhost root[1062]: 1 Install Scripts run.
Dec 13 05:49:59 localhost OSInstaller[154]: PackageKit: Executing script "./postinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.AdditionalEssentials.Q1QZUT
Dec 13 05:49:59 localhost root[1065]: Running Install Scripts . . .
Dec 13 05:49:59 localhost root[1067]: 0 Install Scripts run.
Dec 13 05:49:59 localhost OSInstaller[154]: PackageKit: Executing script "./postinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.MigrationAssistant.VaozRI
Dec 13 05:49:59 localhost OSInstaller[154]: PackageKit: Executing script "./postinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.Automator.bH5kgq
Dec 13 05:49:59 localhost OSInstaller[154]: PackageKit: Executing script "./postinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.X11User.WGgZ0Y
Dec 13 05:49:59 localhost root[1074]: Running Install Scripts . . .
Dec 13 05:49:59 localhost root[1076]: Begin script: setupX11.sh
Dec 13 05:49:59 localhost OSInstaller[154]: ./postinstall: font_cache: Scanning system font directories to generate X11 font caches
Dec 13 05:49:59 localhost OSInstaller[154]: ./postinstall: font_cache: Making fonts.dir for updated directories.
Dec 13 05:50:10 localhost OSInstaller[154]: ./postinstall: font_cache: Updating FC cache
Dec 13 05:50:50 localhost OSInstaller[154]: ./postinstall: font_cache: Done
Dec 13 05:50:50 localhost OSInstaller[154]: ./postinstall: umount: /Volumes/Snow Leopard/dev: not currently mounted
Dec 13 05:50:50 localhost root[1143]: End script: setupX11.sh
Dec 13 05:50:50 localhost root[1144]: 1 Install Scripts run.
Dec 13 05:50:50 localhost OSInstaller[154]: PackageKit: Executing script "./postinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.Rosetta.2hRs5N
Dec 13 05:50:50 localhost root[1147]: Running Install Scripts . . .
Dec 13 05:50:50 localhost root[1149]: Begin script: registerRosetta
Dec 13 05:50:50 localhost root[1151]: End script: registerRosetta
Dec 13 05:50:50 localhost root[1152]: 1 Install Scripts run.
Dec 13 05:50:50 localhost OSInstaller[154]: PackageKit: Executing script "./postinstall" in /Volumes/Snow Leopard/.OSInstallSandbox-tmp/Scripts/com.apple.pkg.OSInstall.k1MTNp
Dec 13 05:50:50 localhost root[1155]: Running Install Scripts . . .
Dec 13 05:50:51 localhost root[1157]: Begin script: RemoveClientLicense.sh
Dec 13 05:50:51 localhost root[1159]: End script: RemoveClientLicense.sh
Dec 13 05:50:51 localhost root[1160]: Begin script: postinstall
Dec 13 05:50:51 localhost root[1163]: Running kextcache -k /Volumes/Snow Leopard/System/Library/Extensions
Dec 13 05:51:21 localhost root[1165]: Running ifcstart
Dec 13 05:51:22 localhost root[1167]: End script: postinstall
Dec 13 05:51:22 localhost root[1168]: 2 Install Scripts run.
Dec 13 05:52:43 localhost OSInstaller[154]: Installed "Mac OS X" ()
Dec 13 05:52:43 localhost OSInstaller[154]: PackageKit: ----- End install -----
Dec 13 05:52:44 localhost OSInstaller[154]: Running install actions
Dec 13 05:52:44 localhost OSInstaller[154]: Writing installation cookies
Dec 13 05:52:44 localhost OSInstaller[154]: InstallType cookie file was successfully written for Setup Assistant to pick up.
Dec 13 05:52:44 localhost OSInstaller[154]: Finalize disk "Snow Leopard" for OS Installation
Dec 13 05:52:44 localhost OSInstaller[154]: Finalizing Disk for OS Install
Dec 13 05:52:44 localhost OSInstaller[154]: Unable to set 'Snow Leopard' as boot disk: The bless tool was unable to set the current boot disk
Dec 13 05:52:44 localhost OSInstaller[154]: Install failed: The Installer could not start up the computer from the disk ?ÄúSnow Leopard?Äù. Try selecting your disk using the Startup Disk utility.
Dec 13 05:52:45 localhost OSInstaller[154]: Allowing machine sleep.
Dec 13 05:52:45 localhost OSInstaller[154]: Memory statistics for 'Install Failed' pane:
Dec 13 05:52:45 localhost OSInstaller[154]: Physical Memory Allocation: 530 MB wired, 3 MB trapped, 337 MB active, 60 MB inactive, 3166 MB free, 3563 MB usable, 4096 MB total
Dec 13 05:53:07 localhost Unknown[82]: 2012-12-13 05:53 Mac OS X Installer[154] (CarbonCore.framework) FSEventStreamStart: ERROR: FSEvents_connect() => Unknown service name (1102)
when installation is done give me error seems cant make bootable the HDD or file havent been installed correctly..
