Rene
[Guide] iMessage Fix with Chameleon
Thanks to Cosmo1t & Meklort
OLD
iMessage not working - iCloud/Internet etc working - Changed boot.plist file and network.plist file - Help - Page 14 - OSx86 10.8 (Mountain Lion) - InsanelyMac Forum
Update Chameleon to "Chameleon v2.2 svn r2168" with Chameleon Wizard.
Copy/make folder /Extra/modules and put "FileNVRAM.dylib" in folder modules.
If you have "ACPICodec.dylib" in/Extra/modules, delete it!
Restart to make the file "nvram.5002e503-4904-ed05-e306-560700080009.plist"
In terminal type:
ioreg -lw0 | grep PlatformUUID
to get your "PlatformUUId"
Open with text Edit "nvram.5002e503-4904-ed05-e306-560700080009.plist"
Replace:
<key>4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14</key>
with your "PlatformUUId".
Update: New FileNVRAM-1.1.3: FileNVRAM 1.1.3 Released - Chameleon - InsanelyMac Forum
Download: FileNVRAM-1.1.3.zip
Requirements: Chameleon r2181 or newer.
Download latest Chameleon: http://www.osx86.net/view/3603-chameleon-enoch_r2187_daily_updates.html
NEW
Working with Mountain Lion 10.8.3
Just update Chameleon with Chameleon Wizard and restart:
Download: Hackintosh Chameleon Wizard 4.2.1 - Downloads - OSx86.net?or newer version.
All credits to Janec202, ifabio meklort and cosmo1t
Edited by Rene
In terminal type:
Replace:
Reboot and enjoy, iMessage is working again :)
Do you think this'll work with AMD? There appears to be a separate fix, that's why... http://www.insanelymac.com/forum/topic/282821-icloud-for-amd-hackintoshes-a-workaround/
No Working!!! :((
[ATTACH=CONFIG]3839[/ATTACH]
Jason,
What I did is really simple.
1. Install Chameleon r2170 to the boot partition.
2. Check/Remove ACPICodec.dylib from /Extra/modules
3. Copy FileNVRAM.dylib to /Extra/modules
Just reboot and it will create the nvram-******.plist file under /Extra. I don't need to change anything for that autogen-ed file.
And iMessage just works along with other iCloud stuff.
Hope it helps.
-Salado
Jason,
Hope it helps.
-Salado
I looked at your screen shot again. It was not the same error message as mine before the fix.
My error message is something like "can not connect to iMessage service". Is your Apple ID a new one?
Yes i know!
I followed steps but no working!
My Apple id is old! (Working on my MacBook Pro) Using with app store etc...
Edited by JasonHUN
