xappleyard
Issue with Sound :motherboar P17G chipset intel 945GC with Audio IDT 92HD202
Hi
I find a quiclky solution with the sound after install iAtkos ML2 on my Intel Chipset 945GC motherboard.
Before, I had iAtkos L2 and sound worked well.
Now after installation the sound has been lost.
Audio hardware description is : IDT 92HD202 6-channel High Definition audio Codec
to fix this problem you need to download a pkg (that I grabbed from iAtkos L2).
here is : https://www.4shared.com/zip/6SjzGX6M/vhda273pkg.html?
-unzip
-put on your desktop, execute and install it.
-after reboot
-go to settings > sound
-select 'Speakers'
done!
I hope this helps to someone.
PD: sorry for my english, I'm from another country ;)
Thanks!
