ssprod
Ati 5450 issues with 10.8.3
Upgrade from 10.8.2-10.8.3 has left me with an unrecognized GPU:(. Worked perfectly in 10.8.2 with edited id's (0x68f9) AMDRadeonAccelerator.kext+ATI5000Controller.kext. Now, in verbose, both kexts are failing to patch. Any suggestions would be appreciated. Thanks!
6 answers to this question
Could it be that the 10.8.3 replaced your patched kexts?
You should always backup your kexts before a major update. ;)
Thanks for your reply. Yes, I replaced these 2 Kexts with my working backup, still no go.
Edited by ssprod
I have also tried to use the old kext with my Sapphire HD5750 (0x68be1002).
Doesn't work ==> I only have 5 MB rather than 1024.
Update 20130318: I fixed my problem!
1. Reinstall OSXUpdCombo10.8.3.dmg
2. Insert 0x68be1002 in ATI5000Controller.kext and AMDRadeonAccelerator.kext
3. run Kext Wizard to install and fix permissions
Edited by Gerhard34
Update
@ssprod same thing happened to me. We've got the same GPU and id 0x68f9! Try these kexts' date=' at least it worked for me:
[url']http://www.osx86.net/view/3725-ati_radeon_hd_5450_-_ml_10.8.x.html
Also, I had to set GraphicsEnabler=No to work out the proper resolution!
ciao anch'io ho lo stesso problema, ho scaricato i 2 kext ma non va faccio partire con graphicsenabler=no -v niente su 10.8.2 ok aggiorno vede la scheda 1024mb ma niente barra traslucida qualcuno può aiutarmi grazie
