maniman
Little question about PCMCIA & EXPRESSCARD
Hi guys , my first post , I'm running iATKOS v7 on a HP Compaq 6720s laptop since near 2 years ago , all well and very happy , I'm thinking in replace battery and maybe get a ExpressCard54/Firewire update.
The obvious questions
Work o no Work
- Is a thing related with the motherboard itself ? (must understand if entire chipset are well recognized no reason to no work ?)
- Or is a thing more related with the manufacturer of the chip in the plugged card ?
- or both ¿?
- I dont have the card actually , exist some way to verify if the system recognize the expresscard port ?
- Some conrete chip especially recommended ?
I use 98% for audio works and with new battery and firewire I would be a happy man.
Best Regards
Hola maniman, welcome to the forum.
I think both is correct.
Basically you will need a kext for the PCI to ExpressCard bridge chip as well as a kext for your FW plugin.
Of course OSX will support FW cards naively, if you pick the right one.
Something like this might work, Gembird Europe B.V. - but its only FW400.
This one may be worth a shot, as the TI chipset is supported natively in OSX: DeLock-61538 Cardbus-FireWire
(I never had issues returning stuff to Amazon)
Try system_info to find out the nature of you bridge chip and whether a kext is already loaded.
I had a Intel bridge which was running and a Ricoh bridge which was not working, so it was hit and miss for me. :(
Best wishes!
PS: You may read here for the experiences of a German user with the card from Amazon: Firewire 800 an PCMCIA (German)
