Hello everyone,
I have installed snowleopard distro iatkost v2 on my laptop,
here it is specs :
AMD A6 4400M
Radeon HD 7520G
HD 500, RAM 4GB
Some drivers do not work, they are touchpad, USB Driver, sound, VGA and also Wifi
Is there anyone here that can help me about finding suitable kexts for my laptop???
Thank You!
Hello everyone,
here it is specs :
AMD A6 4400M
Radeon HD 7520G
HD 500, RAM 4GB
Thank You!
Touchpad: ApplePS2
Sound: VoodooHDA
Graphics: Highly unlikely to get working with integrated AMD graphics...
Wifi: Depends what your adapter is.
USB: Patched IOUSBFamily.kext
This is just a generic repair plan, they may or may not work. Get your system specs using this, then post your results here. Thanks!
Ok thanx bro, i will looking for that and i will try. i will post th result as soon as i can... thanx so much for your help. well, i am a newbie on hackintosh, and i do not too understand about that, but i will learn to use it. thanx
Hi, i am glad to know if someone can instal Hackintosh in AMD system with those specs. I also have like you but unfortunately i can't instal into my system.
A6-4400M 2.7 GHz
radeon HD7520G
what distro did you use? in which way you instal the thing? dvd or usb? maybe you can share the distro download link and the bootflag you use, i really need your guide thanks :eagerness:
Unfortunately, iATKOS is only available via torrents, which we do not allow on OSx86.net. Having said that, you would need to Google it on your own. :)
oh okay thanks. Ill find it and guide me to instal then :D
