Hello,
I am having some issues installing mac through VirtualBox, VMWare and even tried to install to the computer itself. I may need some kext's, bootflags, something to help. I have tried everything. Cant get it to boot after installing with apple logo, or i get kernal panic, or constant reboots.
System Specs:
Computer: Samsung Series 3: NP365E5C-S05US
CPU: AMD A6-4400M
HDD: 500GB
Ram: 8GB
Attempts Made and results:
iTAKOS v2 (Snow Leopard):
Computer Install: Installs fine, but gets stuck at bootloading screen, with no loader circle.
VMWare/VirtualBox: Attempts Install, Kernel Panics.
SnowLeopard by Hazard:
Computer Install: Kernel Panics at install, sometimes may install successfully. But kernel panics at boot screen.
Can anyone help me find a proper kext, bootflag, whatever to help me to fix this? At least so i can try to install either on VMWare or VirtualBox, or even regular computer install (Most perfered). I need help badly. If help isnt possible, well please tell me that its just impossible on this AMD System. -Thanks
